Toshiba Satellite m55-s139
I am taking the laptop apart to change out the fan. I disconnected the cable for the touchpad by pulling it out. How do you get it reconnected. It is very thin and bendable? Is there a trick to this? Thank you/
    Master:
  • 538 Answers
Sure..use a toothpick, to open the small thin lever, that is on top of that connector(like opening a trap door in the floor) then gently insert the ribbon cable, then push the small lever back down. make sure that the cable is centered, and fully inserted..
Posted on Oct 19, 2008
How to book on useing my laptop
Toshiba's website (Support) should offer a downloadable manual
Jun 22, 2011 | Toshiba Satellite M55 / M55-s139 /...
Toshiba satellite m55-s139 problem no screen no beep
Hello.
The most common power reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Feb 01, 2011 | Toshiba Satellite M55-S139 Notebook
How do i store a satellite m55- s1001 to factory settings without disk
to restore to the factory settings press F10 or F11 on startup and then follow the screen prompts you will get two options for recovery destructive and non destructive select the one according to your need destructive will delete your data.
Mar 20, 2010 | Toshiba Satellite M55-S139 Notebook
Toshiba laptop power cable won't charge battery
I had the same problem with my HP laptop some years ago. you have a broken cable/cord and it is the part that is permanently attached with your power pack. If you look at the cord that plugs into your laptop, you can be able to see the faulty part of it. it is usually very flexible or swollen. You can either take it to an electrical technician to change that part of the cord. Your power pack is still ok, but have the technician to check it out first before you change the cord. Else, you may have to get another power pack. below is the full specification of the power pack that is recommended for your laptop.
This Toshiba Global AC Adapter is a 65W external AC adapter designed to work with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers. Get an extra AC adapter to be kept at home, in the office or in your travel case.
Specifications:
* Power: 100-240V/ 50-60Hz Frequency (Universal) input voltage; 19V x 3.42A output voltage
* Dimensions: 4.25" W x 1.34" D x 1.85" H
* Weight: 0.67 lbs
* Power cord included
* Compatible with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers
* One year limited warranty
Note: This AC Adapter is the direct replacement for Toshiba 60W AC Adapter (Mfr. Part#: PA3097U-1ACA) and Toshiba 65W Global AC Adapter (Mfr. Part#: PA3396U-1ACA)
Apr 22, 2009 | Toshiba Satellite M35X-S149 Notebook
Toshiba m55-s135 screen
Hi
Problem with you laptop inverter replace it has shown in pic...
Thanks
Jun 16, 2008 | Toshiba Satellite M55-S135 Notebook
Low brightness to no brightness on the m55-s139 toshiba notebook ;what are the possibility fix?
The backlight has probably gone out in your screen. Replacing a LCD screen is fairly easy and can be done alot cheaper yourself rather than paying 3-400 bucks to hire someone to do it.
This ebay page contains the screen you need and instructions on removal and installation for your screen. It also contains the necessary information to make sure you are purchasing the correct screen.
http://cgi.ebay.com/TOSHIBA-SATELLITE-M55-S139-14-GLOSSY-LAPTOP-LCD-SCREEN_W0QQitemZ180238097667QQihZ008QQcategoryZ31569QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
May 11, 2008 | Computers & Internet
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
