Question about Hotpoint WMA31 Front Load Washer
Door interlock? Have a problem with door lock. Will not recognise door is locked, and hence wont start cleaning cycle. Action so far - have replaced interlock - no effect, have also had door catch assembly apart, seems to be no issue here, and catch looks like it ehgages with interlock correctly and moves contactor - any suggestions for something I have missed or can try?? Have looked at wires, all of which seem to be correctly fitted - saw reference to a door magnet in another posting???? not sure where this would be located, assumed the assembly was based only around the interlock. Any thoughts greatly appreciated
    President:
  • 878 Answers
Rich, I can't bring anything up on that model number but if this is like the other front load models there should be a small magnet on the right side of the detergent drawer. On most front loaders if this magnet is missing, it won't start. As you pull the drawer out look to the right side just behind the front part of the drawer. The magnet itself would be about 1/4 in. by 1/2 inch. If you don't see one and you have a magnet around the house place it on the right side where the drawer would make contact to see if the washer funtions...Good luck,
Posted on Jun 20, 2006
Whirlpool duet ghw9200lw front load washer will not start cycle
Check the door interlock on the washing machine. If it's faulty, the machine won't start its cycle. This page will give you an idea of what interlocks look like.
Door Interlocks
Feb 20, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Our hotpoint wt540 does not work. Choose any cycle and the wash light comes on and stays on. Then theres a small clunk from the machine but thats it. The door locked light is not coming on.
There is a small electronic lock on the inside of the machine where the striker unit of the door locks into and it sounds as though this have malfunctioned. You can change this quite simply.
Power Off machine
Take metal band which hold on door seal
Peel door seal off and you can now put your hand in and take this interlock out
Sometimes the lock will have screws to secure to the body of the machine
The lock might have visible signs where it has burnt but sometimes it wont
You can buy this lock from a parts supplier by quoting the model number and serial or product number found on the inside of the door
If this fails to work you most probably have a fault with the main board not recognising the door lock. For reconditioned modules and mother boards you can goto http://emwelec.co.uk/
Oct 17, 2013 | Washing Machines
I cannot get my washer to release so i can open it up and switch clothes over.. It has finished its cycle i even made it do another cycle to try and get it to release but it wont.. any suggestions? Kat
There are many reasons why the door may be jammed shut -
1. The water hasn't pumped out properly and the washing machine has a pneumatic door safety lock (a rubber hose connected to the door interlock and connected to a pressure chamber bottle on the tub - water forces air up this tube and locks the door)
2. Washing machine won't empty water
3. The water has pumped out properly, but a blockage of gunge inside the pressure chamber bottle is trapping the air that's operating the door lock (if a pneumatic lock is fitted - not many have these days due to cost cutting)
4. Door interlock jammed
5. Door catch, handle, or mechanism broken
Try running Just the rinse spin cycle again,
Jul 05, 2011 | Washing Machines
My zanussi Aquacycle 1100 wont start. A clicking noise starts after I try and start a wash. I heard it could be a door interlock that requires replacing. Is this easy to replace?
door interlock is easy to replace.
undo the plastic clamp that holds door gasket to cabinet. peel back in area of door lock. door lock is held by 2 screws on outside. undo these ans lock comes off. there may also be a small diameter hose as well to door lock which take off as well.
reassembly is just the reverse
Jun 30, 2008 | Washing Machines
How to get access to door interlock mechanism?
IT MIGHT BE EASY FOR YOU TO GET TO THE DOOR LOCK FROM THE TOP OF THE MACHINE.IF YOU HAVE REMOVED THE 2 SCREWS HOLDING THE LOCK IN PLACE YOU SHOULD BE ABLE TO SEE IT HANGGING FROM THE TOP ITS BEST YOU HAVE A NEW LOCK ON HAND TO REPLACE IT.IF ALL FAILS BEST YOU SEEK THE HELP OF A TECHNICIAN.LET ME NO IF YOU NEED EXTRA ASSISTANCE.GOODLUCK.MOHAMED
May 21, 2008 | Hotpoint BWM12 Front Load Washer
Self cleaning oven will not start for cleaning door lock problem
hi alot of people have been having this same problem with either the door locking before clean cycle and not opening or it goes through clean cycle and then the door is stuck shut and wont open.
You could try this it sometimes works before you press start push the door shut and keep pressure on it i mean lean on the door so your pushing it shut further than it is now then whilst putting pressure on the door try pressing start button again if it then starts cleaning cycle keep pushing door for about a minute then gently let go of the door.
This should then allow it to go through clean cycle but remember when clean cycle has finished dont try opening the door strait away as you will then have the problem door stuck and wont open you need to let the oven cool down before the door will open.
If after pushing the door shut a bit further you still have problem then the only thing you can try is switching off at mains for 24 hours this should release the lock let me know how you get on ok
Feb 10, 2008 | Frigidaire FGFB75D Gas Kitchen Range
Door Lock LED flashing
Hello, This depends on how old your machine is mine is now 7 years old so I do not want to invest in long term soltions. So I repaired my own, I bought a new interlock and replaced the old one that did not work. So I shorted out the three links that go to the interlock, the machine now shows the lock is always on and you can open the door during the wash cycle so BEWARE. Also if you have never wired a plug or fixed basic electrics DO NOT DO THIS. 1. Turn off power and unplug. (Very Important) 2. Remove lid you will need torx drivers. 3. Unscrew door interlock from the front of the machine. 4. Lift out interlock. Try replacing the interlock with spare first (about £15). 5. If new interlock does not work do the following. 6. Put Interlock back on without wires attched to it. 7. From car spares shop buy spade conectors and create a three way shorting link (insulate well). 8. Put shorting link into each of the wires that go to interlock. Safely tie up wire to a loom (do not let dangle) 9. Shut the door remove hands and try starting the machine. 10. If that works put the machine back together. And warn people that the DOOR CAN BE OPENED DURING WASH CYCLE and STARTED WITH DOOR OPEN. So check when the machine has stopped properly.
Oct 20, 2006 | Hotpoint WMA58 Front Load Washer
Hotpoint WMA31 Front Load Washer Logo
97 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
