Blocked pump on whirlpool washing machine AWO/D4705
On the front of the washer a light has lit up, it says clean pump. Can you advise me on how to do this?
Washing machine is still full of water?
  • Anonymous Nov 03, 2008
    this is what we have - how do we clean pump ??
  • avbyr Nov 11, 2008
    pump light on in front of washing machine and dont know how to fix it
How do i clean pump
Posted on Dec 03, 2009
What do i do when washing machine stops and the light for clean pump is lit on the whirlpool AWO/D6927
Hi- I think the model # is missing something, it shouldn't have a "/". I can't get the diagrams for that Model #. The drain pump is likely blocked by lint and change. If this unit has a lower panel on the front you can remove it and check to see if the front of the pump screws off. There will always be water in there so be prepared to catch the water with a pan and have towels. If the washer is full of water make sure you bail it out first or you will have many gallons on your floor. If you can get the plug out then see if there are obstructions in there and clean them out. Be sure not to strip the plug when screwing it back in or you will have a leak and need a new pump. This is usually best to have someone do it who has done a few but it will cost you a service call. Hope this helps.
Sep 23, 2010 | Washing Machines
Whirlpool AWO/D 4605 Clean Pump light on, how do I
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
May 11, 2010 | Whirlpool AWOE8748 Front Load Washer
WHIRLPOOL WASHING MACHINE AWO/D 5716 - CANNOT LOCATE PUMP
Remove the bottom casing covering the front of the machine just above the floor. Unscrew the circular cap SLOWLY- beware of vast amounts of water escaping though!
I had to use a low height roasting pan to catch water, and just unscrew the cap enough so as to control the flow of water, and enable to empty water away until its all gone. Incidentally, an old hairgrip was found to be the cause of my problem.
Confusingly, "clean pump" meant clean filter!
May 19, 2009 | Whirlpool AWM8163 Front Load Washer
Clean pump light is flashing where is the pump so i can clean it
The pump is located in that bottom compartment under the door. There are two screws that you need to take out located in that tiny little opening and the panel will come right off. The pump is right there in front. Let me know if you have any other questions and let me know if this was helpful for you. Good luck and I am glad I could help.
Jan 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer
ok unplug the washer remove the three screws across the bottom front of machine if you have a pedistal willbe between the pedistal and the machine. remove the access panell you will see the drain pump it has a threaded cap faceing the front remove this cap and clean out the lint trap attached clean out and debree in the pump housing you can see. reinstall cap, front cover, plug in and test.
Jan 20, 2009 | Whirlpool Washing Machines
Washing machine
whilpool awo/d 4305 light onclean pump can i do this myself
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool door lock
hi
We have a whirlpool AWO?D4705 washing machine. The red light is flashing to say clean pump.wee cannot find our manual , can you help please?
Jan 20, 2008 | Candy CNW136 Front Load Washer/Dryer
Washing Machines Logo
608 people viewed this question
Top Washing Machines Experts
