Question about Toshiba 35AFX54 35" TV
Toshiba 27 Inchs, the immage dsiappear after few minutes, then i have to swich the Tv off for a while
Tv keep switching off after I i switching on, it goes for fewminutes, then the picture disappear slowly, but you can still hear the sound ..i have to switch it off for a while then switching it on again , and so on..what is the cause ofthis problems???? so we can try to fix or replace the faults????
    President:
  • 3,130 Answers
If the picture is fading slowly out it could just be a cold solder connection on the ctr board or the Hi voltage circuit that supplys the filiment voltage to the crt. To check this you have the back off and when the pic goes out you look at the crt to see if its still lighting up. if its not then you gotta find out where your missing the filiment voltage at> If there is still a light inside the tube when the picture is dark then it could be a PIP problem or in the video section /video jungle IC on the set. Now these sets have alot of high voltage inside them even when the sets unplugged so I advise against going inside and tweeking with the set unless you know all the safty issues with the Hi voltage and storage capacitors inside this set. there are no real user serviceable parts inside these sets and should only be serviced by a quilified service person. Good Luck
Posted on Jun 16, 2006
Tv keeps switching on and off and will not stop
unplug tv for 2 minutes and plug it back in. problem should go away. if not, call toshiba.
Jul 22, 2009 | Toshiba 27AF41 27" TV
Hi there, with my toshiba 27A33 television ,the picture comes in on both sides about 2 inchs
First thing to check: could it be aspect ratio - source material is old standard 4x3 format, TV is widescreen 16x9, so it only fills center? If so, the images will look properly proportioned - circles round (not ellipses), people neither unduly fat nor skinny.
Second: if the shapes are wrong, it could be settings on source device (check DVD menu, cable/satellite set-up) and/or TV (choices like letterbox, pan and scan, stretch to fill screen, etc.)
Third: if CRT TV, could be defect in horizontal sweep circuitry, requiring repair shop; decide whether the cost is worth it, vs new TV.
Jun 25, 2009 | Toshiba 27A33 27" TV
Turning on and off on it's own
Theres a possibility that the tac switches of your unit got stucked thats why your units function is intermittent. Try to have your buttons removed and have your units circuitry be resoldered.
chris
Feb 14, 2009 | Apex Digital AT2708S 27" TV
Toshiba television
Is it a Toshiba or RCA? What's the model number?? When it "stays on..." do you get a picture and audio okay??? If you continue turning it back on does the lapse in time continue to get longer????
Bill
Nov 27, 2007 | RCA F27450 27" TV
Magnavox mrp43 television
The answer to this depends on the model. My service literature does not reveal the answer, so you will have to call Philips. Try unplugging the TV for a few minutes first. Even if the remote is programmed properly, the lock will still keep it from turning on.
Oct 13, 2007 | Philips Magnavox 27MS343S 27" TV
Toshiba TV 20 AF42
need more info but conect the tv direc to the ac outlet and check again...good luck post back
Aug 06, 2006 | Toshiba MD20FN3 20 in. TV/DVD Combo
Sony Tv 29 Inchs, The Picture Keep Swiching off and replaced by fable shadowi pinky multi colour light
Your symptom description is a little vague. Is there sound? Is there a full screen? Assuming there is a full screen and sound I would look for bad solder joints on the boards. Particularly the CRT board but really just resolder all the connections in the set. The KV series has been plagued with more than their share of bad solder joints. Give this a try first and if this doesn't solve it give us a more detailed explanation of the problem. Good luck.
Jun 17, 2006 | Sony KV-32S26 32" TV
Toshiba 35AFX54 35" TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
