SOURCE: Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
SOURCE: Smoke coming out of my Kenmore Canister Vacuum Model 22550300C
Sounds like a motor err. Could be repaired by a professional but it never be as good as a new one. Also they you might not find anyone to repair it because the replacement motor might cost more than a new vacuum /considering it's age the motor will be hard to find and that makes it more expensive to repair./
I suggest you to buy a new vacuum.
SOURCE: how do you take the canopy cover off of a kenmore cannister vac?
Flip the vac upside down and look for two screws from the underside near the wheels. If they are not visible you will need to remove hidden screws from above by prying gently at the back of the vac where the body panels meet at the bumper. Also look for two vertical screws in the bag area.
SOURCE: Kenmore canister vacuum cleaner won't start
The rigidity of the Power Head/Handle is quite durable, :) but sometimes they give out. Have SEARS ...loL, sears, have Sears have a look at the head. :)
