Question about Proscan PS36800HR 36" TV
TV works fine for about 1hour.....then the picture
Proscan 36in. TV works fine when you first turn it on. THen after about 40min -1hr the picture goes dark. Sound is ok.
  • berniepolo Nov 15, 2007
    My proscan is model ps35123, the vertical capacitor was replaced, but it shorted out after replacement. Serviceman said it is the transformer on the picture tube. Mt tv is black with a 1/2 inch line in the center of the screen. Does the picture tube need to be replaced or is there some other fix for it??
    Bernard
    President:
  • 3,130 Answers
You have a problem in the Hi voltage or horizontal drive circuit most likly. Its a slight possiblity that the video is going out because of a cold solder connection from the flyback transformer blanking pulse to the video/sync separator circuit as it does and has happened in the past. This set should only be serviced by a trained service person as there are no real user serviceable parts inside this set. Good Luck
Posted on Jun 16, 2006
SOURCE:
On my 36in sony the picture goes in and out..from picture to black back and forth constiantly..im just clue less
a picture that blinks in & out every few seconds then it could be a bad tube.
I know the older models the picture would flash in and out with snow etc. that was a tuner problem.
haven't worked on very many sony wega's, maybe another tech here has a better ans.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
New Proscan 40 goes to green screen when using HDMI cables
I have the same problem with a 40" Toshiba LCD, Component cables work fine with FIOS but not HMDI, goes in and out then blank. HDMI with DVD player works fine. Best buy reported this same problem from users with this toshiba lcd but no solution.
Dec 26, 2009 | Proscan PS50700 50" Rear Projection...
TV turns on and I get sound, but no picture.
Try to see if it is on CHNL 3 for cable, that could very well cause it.
Let me know how it goes
Thanks
Justin
Please Rate Me
Jan 07, 2009 | Proscan PS27600 27" TV
No Audio, picture fine
this is a very common problem just unplug tv for 5 minutes it
should fix it . simple fix most of the time with rca and proscan.
If that does not do it go into menu scroll down to audio and then press on .
thanks doctor video leading edge electronics
Apr 28, 2008 | Proscan PS36800HR 36" TV
Proscan tv 36in
Many problems with this unit with the HV transformer (flyback) and also a regulator ic in the power supply. Sorry, nothing easy for this type of problem. You will need a tech to diag. and repair this problem.
Mar 01, 2008 | Proscan PS35660 TV
Tv: why do I only get sound when I turn the TV on?
Exactly i do no the problem in the video section.
Feb 19, 2008 | Proscan 32LA30Q Television
Intermittent loss of picture
You'll have to locate the vertical output IC which should be mounted onto a heatsink, then take out a good magnifier under the printed circuit board and examine the solder connections on the pins of that IC and resolder the ones that are cracked.
Mar 12, 2007 | Proscan PS27125 27" TV
Proscan PS36800HR 36" TV Logo
114 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
