Question about Canon PowerShot S2 IS Digital Camera
Black pictures when using flash
HI
I HAVE A CANON S2 PURCHASED TWO YEARS AGO AND WAS WORKING FINE. A FEW DAYS AGO IT SUDDENLY STARTED HAVING PROBLEMS. WHEN I TAKE PICTURES WITH THE FLASH THEY ALL COME BLACK. PICTURES TAKEN WITHOUT THE FLASH ARE OK. ALL OTHER FUNCTIONS WORK PROPERLY ONLY THE ONES TAKEN WITH THE FLASH ARE DARK. LCD WORKD FINE I AM BAFFLED CAN YOU HELP?
    Novelist:
  • 164 Answers
The black images with flash mean that the Iris mechanism in the lens is not working properly, and that needs a professional camera repair service.
Best regards,
Posted on Jul 22, 2009
Canon powershot s2 IS suddenly does nothing when powered on
There appears to be an issue with the S2 IS after two years.  See the reviews on Canon's website: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=322&modelid=11368#ModelDetailAct
If yours is two years old then you are probably out-of-luck.  It would probably cost more to repair than to simply replace.
You can at least save your photos by removing the memory card and reading the files using a memory card reader on a PC or MAC.
Apr 19, 2009 | Canon PowerShot S2 IS Digital Camera
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Canon S2 is washed out pictures
Just when I thought my camera was fixed I started experiencing the same problem with my S2 IS. Don't know if it is any help to finding the solution but the camera works fine outdoors when used in video mode.
Aug 15, 2008 | Canon PowerShot S2 IS Digital Camera
Canon powershot s21s problem
I had what Canon suggested was a ccd image sensor problem with my S2 IS, did as they suggested, filled out their form, printed it out, talked to a rep about the problem, sent the camera in to their service repair, only to hear from them that their solution was to let them repair it for $127.00, or purchase a, get this now a "refurbished" newer model S3 IS for $175.00 with a 30 or 90 day warranty on it..HAHAHAHA...why on earth would anyone add an extra expense to what the camera's value was at purchase in my case the cost for the camera was $349.00, or buy the next step up from and S2 to an S3 IS, that has already been refurbished for whatever reasons for $175.00...and hope that this camera screwed up before the limited warranty expired..and by the way I had only had my S2 IS for 18 mos.
In my opinion Canon needs a class action law suit filed against them for not honoring a product that has a history with the image sensor, refering to the S1 IS...and now already wanting to replace an S2 with a refurbished S3...DON'T THINK SO..
Apr 04, 2008 | Canon PowerShot S2 IS Digital Camera
Canon S2 IS black screen
Normal 0 BLACK SCREEN OF DEATH – FIXED AT LAST - After doing several hours of research on the internet, I have been able to eliminate the problem on my Powershot S2 IS. I started with the “fix” as suggested by guidofoc in a post on the “flickr” site. Thanks guidofoc! His procedure did fix the problem for me but it only lasted a day. The next day, back to the same old black screen. For the next few days/weeks, when I wanted to use my camera, I did the same procedure and it would come back to life but would be black again the next time I powered up the camera or a day later.
Back to internet research! On the “Fixya” site, I found a picture of the camera shutter and diaphragm blades. This picture was posted by “andyhutton” who was also having the same “black screen” problem. He had disassembled his camera and found what appeared to be an oil exuding on the shutter diaphragm blades. He disassembled the camera, cleaned it thoroughly, and reassembled it. This fixed his camera. Other information I found indicated that what appeared to be oil was a little “stiffer” than oil, almost hard. It was thought that this was happening after leaving in a hot car other high temperature environment.
All this made sense to me but I didn’t relish the thought of tearing the camera apart and reassembling it. This procedure reportedly took about 6-8 hours. And this was by a person who considered himself, to have a reasonable amount of mechanical ability. I definitely DON’T RECOMMEND this approach unless you have tried all else and are ready to junk your camera. Using this information I theorized that if I used the temporary fix procedure and then repeatedly activated the shutter, perhaps the “wiping action” may wear down the frictional areas and free up the shutter blades to move more freely. I tried it. Voila! It has worked now for the last 6-8 weeks without a failure. Here is my final procedure:
Set the camera in Tv mode, (delayed shutter mode) set the shutter at 15 sec, click to take a picture and during that 15 secs (like, after 7 seconds) open the battery, compartment which cuts contact with the battery circuit. Close the battery cover. At this point the camera works fine for me but only temporarily as noted above. Sometimes however, this procedure had to be performed more than once. Here is the key to the permanent fix. While the camera is working via the temporary fix, take many, many pictures. Hundreds! I probably snapped 400-600 pics. The idea is to wear down the little patches of hardened oil on the shutter blades. For the next three of days I took hundreds of pics each day. Basically, I just aimed the camera at the wall or whatever and snapped off several hundred pics.
Now that I seem to have my camera working permanently, my plan is to NOT leave my camera in a high temperature environment, and to try to use it regularly. Maybe, not unlike many other things, if it gets no regular use, it may start to deteriorate.
No guarantees but I do hope this helps someone.
Dec 12, 2007 | Canon PowerShot S2 IS Digital Camera
Canon S3 no display on LCD screen
This is a common problem that we ( in the camera repair game ) see a lot . The cause is faulty CCD sensor ( see enclosed pic from a Canon camera ) to see what I mean . Canon will repair this ( or replace the camera if they cannot repair it inside 4 weeks ) free of charge. Why does this happen ? Badly manufactured ( produced in 2002-2004 run ) sensor goes in the camera and starts outputting noise after 1 or 2 years instead of working properly for +- 10 years.8abdb4c.jpg
Dec 05, 2007 | Canon PowerShot S2 IS Digital Camera
Canon zoombrowser Ex downloading problem
Go to the "Add and Remove Programs" in your Control panel.
Do a "Change" and do the 'repair program' utility.
That should fix it, good as new.
If that is not a possible option, try uninstalling. (if there is no "Change" and 'repair program') then Run the normal uninstall program.
Oct 28, 2007 | Canon ES-E1 EOS Link (4593a006) for PC
Sound, but no picture. Standby light blinking 5 times
A few weeks ago my set started flashing to a black screen. Now a couple of weeks later, i have no picture, but the set turns on and i have sound. The standby light is flashing. I purchased the set in 2000 so it is seven years old. This is the first problem. Could it be all three of the bulbs? Could it be all three of the bulbs? no as you say that sound is ok that means your power supply &high voltage section is ok. please check chroma ic luminance section or system control section stand by ckt ihanks
Sep 11, 2007 | Sony KP-53HS10 TV
Black screen w/small portion of top of picture showing at bottom of screen
Hello, the problem with your projection TV is in the so called bad soldering in the vertical deflection stage. Please contact a pro in order fot fix the error. If you need more assistance please advice. Arpi
Mar 18, 2007 | Sony KP-57HW40 57" Rear Projection...
Black Screen When Open, but the Picture quality is fine
in the lower right hand corner there is a button that has disp. on it just click that during picture taking mode and it will return to normal
Dec 25, 2006 | Canon PowerShot SD600 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
114 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
