Question about Tascam 2488 Portastudio Multitrack Recorder System
Understanding the multi effects on the 2488
I will first record the drums and then the base. Then when i record the first guitar I will hold down the multi-effect button and press the appropriate channel. I then get a good effect on that channel. However when I do the same thing to record the next guitar on another channel I get a good effect on that channel but lose the effect on the first channel.
Can not figure this out.
Can anyone help
thanks
MIke Kuzma
rmkuzma@insightbb.com
  • 1 more comment
  • rmkuzma Oct 19, 2008
    I thank you very much. I am sorry i dont quite understand, so do you mind telling me exactly what to do to use the multi button on the first channel and then go back and use it on the second channel and then listen to the recording and here the multi effects on both channels.
    thanks
    do I owe for this advise
    thanks
    Mike Kuzma
  • rmkuzma Oct 20, 2008
    thnaks for the reply, but i must repeat my send
    M kuzma
    I do appreciate your help
    heres my thoughts
    I have figured out that I can press the multi-effect button and put an effect (say clean chorus) on lets say a vocal track. Then go back and bounce it to another track and the effect goes with it then go back and put an effect (say dist) on a guitar and then go back abd bounce it to a track and the effect goes with it. Without doing this, I do not know how to put the chorus on one track and the distortion on another. IF you did everything dry then seems to me that you would have to do this same thing at Mixdown. So how do you put a multi-effect of one type on one track and a multi-effect of another type on another track.
    There you have it
    thanks
    Mike Kuzma
  • 1,512 Answers
Hi rmkuzma
You are not recording the effect to track, it is probable that you are perhaps using the effect loop, it will not be recorded to track this way. This how you should really record anyways so that you can go back and change the effect or even just fine tune it in the mix, you can then bounce the track later with effect if you want later. If you want the effect to go to track then
1. Press and hold the MULTI button, then press
the SELECT button on the channel you want to
assign.
2. Press MULTI again to view the effect parameters.
Press the ENTER button to choose an effect
that you want, tweak it for what you want, and it should then go to track
Try that and see how you go. I am happy to talk to you more about it. A FixYa is a good reward for my efforts to help you out. Cheers mate
regards
robotek
Posted on Oct 19, 2008
  • Graeme Ross
    Graeme Ross Oct 20, 2008
    If you select the effect in the manner I have indicated, then you should be recording the effect and instrument to track.
    I was also suggesting that it is good practice to record instruments "dry" without effect, because when it comes to mixing down your song, you cannot undo the effect, nor make any changes to the settings. Having said that, I also understand that you may be using the effect for distortion and so on, so you may be needing to use the effect to get the sound you are looking for from your guitar.
    Have you been able to get the effect to track yet?
    regards
    robotek
  • Graeme Ross
    Graeme Ross Oct 21, 2008
    Hi again, I think understand your problem a little better. From what I remember,(it has been a while) and what the quick start guide(get the full user manual here also) tells us... you should be able to record the signal source AND the effect to the same track using the procedure I gave you with the multieffect as an insert on that channel. Due to processing limitations the unit can only deliver one Multieffect at once with MicX4 effects are being used-none if you have MicX8 engaged.
    Bouncing the recorded track adding the effect later would be my preferred approach so as to take advantage of the effects loop and allow you to still make changes when you do your mixdown. .
    I have just re-read the manual again, page 31 in the manual talks about the multi effect.
    Assigning the multi-effect to a channel or input
    The multi-effect is assigned in the same way as the mic effects: press and hold the MULTI key and press the input or channel SELECT key. Any input or channel assigned when the MULTI key is first pressed flash. Unassigning the multi-effect follows the same proce-dure: press and hold the MULTI key, and press the flashing SELECT key. NOTE The multi-effect can be freely assigned to mono inputs or channels or to linked or stereo input or channels.
    This procedure means you should the effect inserted into your chosen channel. Hope this helps, I dont have a unit in front of me to experiment with, but you do, so I suggest experimenting with it following instructions from the manual Good luck :)
    regards
    robotek
Cant hear audio on tascam 2488i brand new to using it but i do understand how to record a track on my display screen i can see the audio i recorded but no sound what so ever i have my headphones plugged up...
hi
Tascam Digital recording is an effective solution for broadcast-quality home recordings. The Tascam 2488 is a user-friendly tool and useful for home recording situations, especially when writing songs or cutting demos. It even has bus compression and processing for your final mix to give it that "mastered" feel. There are other recorders as well.
Instructions
  1. Learn your gear. The Tascam 2488 DAW offers 24 discrete channels that can be recorded at up to 24-bit resolution. 16 tracks can be recorded simultaneously, via eight XLR balanced inputs and eith 1/4-inch unbalanced inputs. There are several high-quality built-in effects, such as reverb, delay, modulation, compression and a great tool for guitarists: amp and effect modeling. So you can simply plug directly into the console and get live amp tones.
  2. Record or program the rhythm tracks. Most Tascam products offer a large library of built-in drum loops to construct rhythm tracks, so you don't even need live drums just to get a song down. You can designate the tempo of your song from the transport located on the right side of the console; this is where you would use a variety of buttons to make edits, undo or redo and automate punch-ins
  3. Record your base rhythm instrument. Let's say a rhythm guitar. There is a dedicated guitar input located on the front of the console, and once you're plugged in you can use the aforementioned amp modeling features to dial up a sound.
  4. Record the remaining track or tracks. This could include bass, vocals, keyboards, horns or any other instrument. The process is always the same. Arm the track you wish to record on, hold in record and hit play, and the machine begins to record whatever you are playing. When you're done, hit stop. If you want to undo what you recorded, simply hit the undo button.
  5. Repeat these steps on any other instrument you want to record. Plug a microphone into one of the first eight XLR inputs, the first 4 of which have phantom power for studio condenser microphones, arm a track and record.
  • If you need to punch-in a section, you can automate it by dialing up the time in the song you wish to replace using the auto punch function. When you enable this and choose the time in the song you wish to record over, once you hit record and play it'll start the track a few seconds before where it begins the punch-in and it will only go into record when it reaches the designated time stamp.
Do not rush. Proper recording takes time and patience.
hopefully this can help
regards
Jun 11, 2011 | Tascam 2488 Portastudio Multitrack...
Hi. I am using the Tascam 2488Mkii in a very simple set up. I love the sound of the single effect reverb. I just want to record my vocal and accoustic with that effect (recording via microphone)....
If you own a small practice guitar amplifier with reverb, mic the amplifier and hook your guitar and microphone into it and run it into the board. You will get a better sound
Nov 28, 2010 | Tascam 2488 Portastudio Multitrack...
Neo drums ?
No the neo does not have the built-in drum patterns/drum machine like the origial grey 2488 did. It was abandoned for the 2488 MkII which was the intermediate model and hasn't reappeared. I create drum patterns either using an external machine recorded in real time to a track on the my 2488 or create a drum pattern on the PC which I save as a mono wav and import to a track on the 2488.
Jun 03, 2009 | Tascam 2488 Portastudio Multitrack...
Guitar effects often disappear after recording
Hi Danny,
You seem to be aware already that the multi-effect acts like a traditional 'insert effect' on a mixer and as such can only be applied to one track/channel at a time (multiple effects / single channel). The problem you're asking about seems to be that the effect is not 'printing' during the recording of your track. Obviously the effect can't 'go away' after recording so it would appear that your guitar effect isn't being recorded (only monitored) when the track is being laid down.
My initial guess here would be that while recording you've been assigning the multi-effect to a channel vs an input. That would explain the effect being audible while monitoring, but the input still being recorded dry even though the effect is heard through the monitors.
So to get this working the way you expect you'd want to insure that you are indeed assigning the multi-effect to input from which your guitar is coming, rather than the track on which it is getting recorded.
Having said that, actually recording dry (like you are doing) and then applying the multi-effect to a new track via a 'bounce' is the way a lot of people (myself included) choose to accomplish this anyway. That way you preserve a dry track and can go back and 'redo' the effect (or choose a different effect instead) later on. It does however introduce another step and use up another virtual track (but the 2488 has 250 of them available which si a big reason the 2488 is so competitive).
Hope this helps.
bd.
Nov 30, 2008 | Tascam 2488 Portastudio Multitrack...
Multi Effects?
Here's a run down of the 2488 effects. It should explain how to use them.......
Effects processors can be inserted into the appropriate channels simply by holding the required effect mode button and pressing the required channel selection button. When the effects are configured as eight channel insert effects, the processor can provide compression, de-essing or exciter functions (selectable independently in each of the eight installations).
If you only need four such insert effects, then you can substitute a single multi-effect processor for the other four. This multi-effect is most likely going to find its way into the guitar DI input, and offers a chain of effects starting with a noise-gate followed by either distortion or compression.
If you are happy to abandon channel insert effects entirely, then you can set up the effects block as a single send/return processor which provides somewhat higher-quality effects. Algorithms include reverb, pitch-shifting, delays, and so on, and are accessed by dialling in an amount of Loop Send from any appropriate mixer channels. There is no dedicated effects return channel as such, but the level of the chosen effect can be adjusted in the relevant control screen.
Full article at: http://www.soundonsound.com/sos/may04/articles/tascam2488.htm
Sep 03, 2008 | Tascam 2488 Portastudio Multitrack...
Mic effects
The short answer is that you'd use the multi effect (or one of the 4 mic effect) to one channel for effecting your mic input. Reverb should be added later using the single effect. You'd send the already recorded track to the send effect and then return it to another track and 'print' it using a bounce. 'Send' sends the signal to the effect and returnsit to the mix bus. So to add reverb to a track you'd send that track to the single effect after configuring the reverb effect the way you'd like it, and then make sure all of the other are turned down and record it to an open track during a bounce.
The single effect is what would be referred to as a 'send effect' and is designed to be used at mixdown or during a bounce. In the 2488 the single, aux and send effects are all 'send effects'. These take an existing sound and change it. Examples are reverb, chorus, delay, phaser and flanger. The internal effects on the 2488 can be used or external sound processors can be fed with the sends and returned to inputs on the 2488.
The 2488's multi-effect, as well as the mic x4 effects are 'insert effects' to be used on the input signal when recording. Examples of insert effects are compression, expansion, gating, limiting and distortion.
You can send all channels (or multiple channels) to the same effect send, but they all must be sent to the same effect (or chain of effects) at once. You cannot for instance send channels 1,2 and 5 to one send effect and 3 and 4 to another at once. You'd have to do something like that in two seperate operations.
Insert effects cannot be shared among channel strips. Each sound source needs its own insert effect. The 2488 has one multi-effect box which acts like an effect chain on one channel or 4 mic effects which can be assigned to 4 mic inputs at once. Each input assigned uses one of the mic effects up (a stereo pair will use 2) of the available 4.
The main thing to remember is that there are the 2 different effect types. Sends are for adding something to the signal like reverb, chorus, delay, phase shift, flange (on the 2488 these are the single effect and the aux send effects) while insert effects act on the signal modify or subtract from it (compression, gate, limiter, distortion).
Hopefully this helps. I know it can be quite confusing starting out.
bd.
Jun 26, 2008 | Tascam 2488 Portastudio Multitrack...
Using the effects on the 2488 mk 11 for vocals
Use a single effect vice a multi effect and assign it to the channel vice the input and that should get you going. I'm sure you could just set the effect to the input and not the channel but this works for me. If your tracking your instruments/tracks to different channels, and you should be, then assigining the effect to the channel wont hurt you.
Apr 05, 2008 | Tascam 2488 Portastudio Multitrack...
USB Export!?!?!?!?!?!?!?!AAAAHHHH
all i want is the dvd on the tascam 2488 cause the manual is a lot of work ,it leaves out the little things.
Jan 09, 2008 | Tascam 2488 Portastudio Multitrack...
Sonic maximizer
To use the maximizer as a send effect, connect the effect send (1 or 2) to the input on your maximizer, then connect the output from your maximizer back into any input A thru G on your 2488. You then assign the track you want to maximize to the correct send (1 or 2) using the send key and then assign the input to a track to record to.
To use a maximizer as an input effect (assuming guitar) simply plug yoiur guitar into the maximizer and then patch the maximizer to input H (Hi Z input of the front panel of the 2488). Assign input H to a track to record and this will record the maximized input signal.
Jan 03, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Recorder
if the multitrack doesnt have built in effects you need to but an extrenal vocal effects processor that you can wire up to it. try lexicon products, they offer really good realistic vocal effects rack units.
Dec 26, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
155 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
