Question about Canon ZR100 Mini DV Digital Camcorder
A beeping noise goes off, when i put in a tape, like it starts beeping then ejects it out, and the screen shows "remove casset", ive already tried the dry video head cleaners, but it ejects that tape back out too, what do i do?
  • Blaine88 Jul 19, 2008
    The same thing happens to me.  I try to pt the tape in and it will just make a buzzing sound like it's trying to load.  Then it will beep, reject the tape, and tell me to "REMOVE THE CASSETTE" appears on the screen.
    On my camera the tear drop does not appear.  My mother thinks it might be that the reading lenses are misaligned.  Could that be the case?
  • 215 Answers
If your recorder is suffering from condensation problems then an icon in the shape of a teardrop will appear on the LCD and there will be a beep or beeping. Just beeping and the eject is being done to protect the tape. What it's actually protecting the tape against isn't explained but it could be tape slack or broken or an outright fault within the the recorder. The beeping could be an RF problem, meaning the heads are still dirty. Perhaps a word with a local tech who may have come across the same problem because you're not the only one with it.
Posted on Jul 22, 2006
  • 1,476 Answers
Does the unit say anything about moisture? This sounds like a moisture fault. Leave the unit open for a day in a dry area and try it. If it is moisture and everything is OK this should solve your problem. If it doesn't solve your problem you could have a bad moisture detector. This is a small square metal looking device near the video drum with two wires hooked to it. It's job is to protect the camcorder and keep it from damaging tapes when moisture is present in the unit. The simplist way to verify if it is defective is to jump a wire across the two connections and try the unit. If it works this is your problem and you will need it replaced. A good repair shop should be able to do it for about $50 US. Two websites which give free estimates are http://www.videotech.com and http://www.camcorderrepair.com Good luck.
Posted on Jul 21, 2006
My dsr-45 no eject cassete
please follow this :-Remove the case, remove the mechanism cover, cut the mangled tape in pieces and take it out gently - you are going to have to rotate some part to untangle most of it. With all the tape that's out of the cassette removed from the mechanism put the unit back together and eject it.
i hope this will be helpfull to you .
goodluck.......
Feb 02, 2011 | Sony DSR-45 Mini DV VCR
Tascam DA 40 DAT Machine ." Loading error "
The DAT machine needs new belts and maybe some cleaning. These fail all the time due to old belts that lose the tension that is required.
Dec 10, 2008 | Tascam 122MKIII Single Dual Cassette Deck
Tape will not eject / Battery full
while the eject process is trying to happen remove the battery and replace it. keep initiating the eject process and removing the battery and it should finally eject. If you attempt to use the camera again put in a new tape so you don't lose a tape that contains footage you may want to save.
Dec 07, 2008 | Canon ZR100 Mini DV Digital Camcorder
Tape wont play or eject.
i just read about this c:31:22 problem while looking for a solution to another problem I am having. Someone suggested removing the battery, switching the camera to the "camera" setting, and then turn it off, put the batter back in and it should work. Good luck.
Jun 15, 2008 | Sony Handycam CCD-TRV308 Camcorder
Will not close while tape is in ejecter,alarm beeps and screen says (remove cassete), but will however close without tape??? canon mv830i digital camcorder...
Several things could be happening...the tape is backwards, upside down, inverted or just wrong type since it closes without it. Next check to see on the inside if something is jamming the tape. While it closes without a tape there could be something that jams when a tape is inserted.
May 09, 2008 | Cameras
Canon ZR60 Mini DV Digital, remove the cassete message
This is a tape transport problem and is expensive to fix. Unless you know a cheap tech, it's time for a new one. Be patient loading and unloading tapes. This is usually what causes this problem. The Yellow warning sticker is REALLY important. Another important item is to always use the same brand of tape because switching tapes causes a gummy build-up the makes tapes get caught in the machine.
Videoteacher
Dec 08, 2007 | Canon ZR60 Mini DV Digital Camcorder
DHR- 1000
Recently repaired one of these with what appeared to be a power supply problem; found several defective capacitors on the drive board. The symptoms were similar to what you are seeing.
Aug 20, 2007 | Sony DHR-1000 DVHS VCR
Error message E4 and stuck tape
Yes with care. Simply remove the cover and with care unwrap the tape. If you must break the tape - but make sure all residual tape is cleanly removed. Re assemble and put a tape head cleaner through- following the instructions.
Jun 22, 2007 | Mitsubishi HS-U445 VHS VCR
Eject is flashing with fast beeps. Won't eject tape or open compartment.
sad to say that the problem of your camera is the timing gear is already damage....it need to disassembly the camera to fix the timing gear....go to the qualified service center for fixing or replacing the timing gear..
Jun 15, 2007 | Sony Handycam CCD-TRV37 Camcorder
Canon ZR100 Mini DV Digital Camcorder Logo
401 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
