Question about RCA G36788LV 36" TV
Static on picture
I am starting to get static on the screen. The picture is generally pretty good but the screen will be will start to scramble and looks like there is some type of static causing it. If I hit the top of the TV, it clears up. It?s very random; sometimes we have to hit it several times in an hour. The picture is still good but I have noticed there is a slight darkening in two of the corners. Do you know what is causing this is is it worthwhile to fix?
    President:
  • 3,130 Answers
The more you hit the set and wait to get this problem fixed ,the more its gonna cost ya. Your problem is a very common one for RCA. Whats happening is theres several grounds around the tuner sheilds and tuner covers that are intrmittanly going bad because of the differant types of materials they used for the sheilds and covers , so the metals are all reacting differantly to the solder ing in the set. This set if not fixed right away will cause the eeprom to go bad and or the vertical swwep Ic to fail. The repair shouldnt cost more then 125 to 175 bucks or your getting ripped off!! Happens all the time . Good Luck
Posted on Jun 16, 2006
How do I troubleshoot a Toshiba 42HP66 T-CON board? Thank You
that's a plasma. it doesn't have a t conn. can you send picture ? sounds like main board
Dec 04, 2017 | Toshiba Televison & Video
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
My tv only displays snowy screen with load static noise. When I unplug it and plug it in the tv turns on by itself and the snowy screen and load static are there.
check that the antenna wire is properly connected as the screen indicates that it is not working or connected properly
Jan 03, 2016 | Televison & Video
Dash gauges not working
Coming here was a pretty good start... FREE
What you need to do is AVAIL yourself of the circuit drawings & TECHNICAL SERVICE BULLETINS (TSBs)...
The ABSOLUTE BEST drawings are found in your model and year's FACTORY+WORKSHOP+REPAIR+MANUAL...
(excepting FIRE ZONES & extreme winds) ... I strongly recommend paper CIRCUIT DRAWINGS
Typically 2000 Sunfire will include several different GM clusters
and the actual FACTORY manuals are not cheap...
(But few really great things... rarely are... ).
BEGINNING progress can be accomplished with FREE
drawings & TSBs from BBB Industries website
(registration is required ... as these are real documents).
BBB Industries Premium Alternators Starters Power Steering Products
SUCCESS comes from careful & CORRECT HANDLING
of sophisticated semiconductor circuitry (meaning: you must
beg, borrow or buy an anti-static wrist-strap... & use it )
$6...
Amazon com Rosewill ESD Anti Static Wrist Strap Components RTK 002 Black...
The slightest static spark... (you might not even feel)
is enough to completely destroy any SEMICONDUCTOR...
READ MORE about ESD (Electro-Static Discharge).
Incredibly important...
Electrostatic discharge
Hope this helps... If it does NOT ... Comment me back
(we can do this... It is a pretty cool Sunfire)
Carnac the Magnificent
Oct 30, 2017 | 2000 Pontiac Sunfire
From a cold start,power on,screen is all blue with "no signal" in the upper right corner. while still in blue screen mode approx 2 minutes after start a squealing sound starts. about 1 minute later the...
Sounds like a power supply fault due to leaky capacitors(electrolitics).
From cold take the back off and run a hair dryer over the power supply for a few minutes then switch on,if it comes up fully working then you have to isolate the faulty part/parts and replace.
Oct 01, 2009 | Polaroid FLM-3732 Television
Static interference problem
The Graco digital iMonitor scrambles the signal as it travels between the monitor and the receiver, making signals nearly impossible to be heard by others.
I had good experience with this product, it didn't suffer from the static noise problem.
Jul 16, 2009 | Graco Imonitor Digital Baby Monitor
N o picture just static noise
The symptom sounds like a dead tuner and the screen blanking may be due to missing video synchronization signals which may cause either blanking or 'blue screen' on some sets.
This could also still be because of a failing power supply although they will generally just cause no turn-on at all.
I would first substitute another TV just to be sure your signal source (cable or satellite) isn't causign the loss of signal.
May 25, 2009 | RCA R52WM24 52" HDTV Projection Television
Unit quits after 10 minutes/ screen black and static- noaudio files on card
I call this a problem with a capcitor inside the unit has leaked or has bulged.. Witch is not provding the power it needs to function properly see www.badcaps.com just for a example what are bad capcitors.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 24, 2009 | Astar PD-3015 Portable DVD Player
Picture becomes fuzzy in different areas of the screen
sounds like a splitter problem try replacing splitters
Mar 24, 2009 | LG 50PX5D 50 in. Plasma HDTV
TV has a good picture but the sound coming out is nothing but static.
I have the same problem that just develop last week 0 ggod picture but audio is just static Did you find a solution yet?
Dec 26, 2006 | GE 46GW947 46" Rear Projection Television
Televison & Video Logo
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
