Question about Sony Grand WEGA KDF55E2000 55" Projection HDTV
Sony Wega KDF-55E2000 won't turn on
Have had t.v for 16 months, the other night t.v shut itself off. Fan was running for a couple minutes afterwards when I try to turn the t.v back on the green power light blinks for about a minute and then the red power button starts blinking in cycles of 5 blinks, the t.v won't turn on at all it just keeps blinking red. Any help would be greatly appreciated.
  • Anonymous Mar 14, 2014
    the power button keeps blinking and wont go on
  • 320 Answers
A 5 blink code is a lamp power supply problem, but I would try a new lamp. I'd say about 90% of the time that fixes the problem.Get an ORIGINAL Sony lamp as the aftermarket replacements are ****. If you replace the lamp and still have the problem, you will need to have the lamp power supply/lamp ballast replaced
Posted on Oct 19, 2008
Power light flashes green likes it turning on then flashes red 3 times. I just replaced lamp Sony Grand Wega KDF-55E2000
3 blinks should on this model mean "LAMP DOOR IS NOT CLOSED" BUT IT really means something else.
Can I assist you?
I can tell you how to prove this or not and if proved it is a simple and not expensive repair..
SD TECH
Nov 10, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have Sony Grand Wega KDF-55E2000. While my 3 year grandchild was visiting she was playing with remote and now I have System Status and Path A Status screen displayed that I can't remove. Please help!!!!
The easiest way is by resetting the tv itself back to the factory setting.Just unplug,replug the tv back like about an hour later.This should remove itself.
Nov 22, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
How do you replace the projection lammp?
I will forward a link to a page where you can find the instructions on replacing the lamp of the TV.
http://www.docs.sony.com/release/KDF42-46-50-55E2000.pdf
Jul 23, 2010 | Sony Grand WEGA KDF55E2000 55" Projection...
Pink or magenta stripe across the top of my sony kdf-55e2000
Sony has extended the warranty on the optical block which you are experiencing a problem with until June 30 2010. Read about it here. http://www.agoraquest.com/display_alert.php?alert_id=17
Jul 14, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony WEGA Large Projection TV
I sounds like the projection bulb has failed. I think there is a red lamp on the front that lights up when the bulb fails however.
This sounds very similiar to what mine did when the bulb failed about 2 months ago. Once the buld fails the TV will shut itself down and keep doing that until the bulb is replaced.
Dec 17, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Tv turns off
Its the lamp that needs replacing. It will run for a couple of seconds and then it would dim or turn off.
May 27, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
SONY WEGA KF60WE610
I would suggest going to the folowng link you can get the full service manual with full trouble shooting and parts section emailed to you for 10.99. your model is listed on page 2 of the sony section. They also provide free help to help you with diagnosis. I have used them countless times they have excellent sevice manuals. Here is the Link.
http://servicemanuals.vstore.ca/
Feb 25, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony Grand WEGA KDF-60XS955 60 in. Rear Projection popped and turned off
the reason your lamp blew so quickly is the the lamp fan has become cloged with dust. this is a known problem by sony and I have done 15 or so of the up grades needed. first look at the lamp door is it discolored and warped. if so have a tech order the up grade kit which includes a new door, siraco fan, thermal fuse, and lamp. the return fan may also be needed. also some service menu changes need to be made with the fan voltages of fan 1 and fan2.
Feb 22, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Grand WEGA KDF55E2000 55" Projection HDTV Logo
1,058 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
