Question about Lite On Computers & Internet
Computer loads driver for device but can not find device hardware
  • John Hong
    John Hong May 11, 2010
    ``computer loads driver for device but can not find device hardware`` in reference to Lite On ... are you saying your CD or DVD drive is missing
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    perhaps you will share with us the maker of the computer?
    Genius:
  • 2,785 Answers
Plz check are you installing the correct drivers for the device
Posted on Oct 19, 2008
How do i turn on my bluetooth on my emachines pc
Click the "Start" button, then choose "Control Panel," "Network and Internet" then finally "Setup a Bluetooth enabled device."
Power on the Bluetooth Hardware you want to connect to the computer. You must have some sort of hardware to connect to the computer, in order to enable the Bluetooth connection.
Click "Add" and the computer searches for any Bluetooth hardware in the area. Once it detects the hardware, select it and click "Next."
Type in the passkey for the Bluetooth hardware (found in the device's user manual) and click "Next."
Install any drivers now that came with the Bluetooth hardware. (Insert the driver installation CD that comes with the Bluetooth hardware, wait for the the installation wizard to load onto the screen, accept the license agreement, then click "Next" for the installation name and location and select "Install" to install the drivers.)
Choose "Locate and install driver software" if there are provided drivers. If not, click "Don't show this message again for this device" and click "OK."
hope this helps
Aug 12, 2012 | E-Machines eMachines W2686 PC Desktop
Tip
How to Load a Device Driver
<span>Instructional step<br /></span> <ol> <li> Enter the device command into the "config.sys" file for older Windows operating systems. These commands can define whether the device is loaded normally or if it is to be loaded into upper memory. The older operating systems gave lots of flexibility to the user as to how the drivers were loaded into memory and in what order they loaded.<br /> </li> <li> Right click on "My Computer" icon on the desktop. Select "Properties." Select the Hardware tab and click on "Device Manager" to open up the window that shows all the devices connected to the computer and allows access to the drivers for these devices.<br /> </li> <li> Locate the driver that you need to install either from <a href="http://www.ehow.com/internet/">the Internet</a> or on a CD or other media that came with the computer from the manufacturer. Look at the Device Manager screen and find the device that has a yellow exclamation point on it indicating that there is a problem with the driver for that device.<br /> </li> <li> Click the icon (right click) and select "Update Driver." Read the Hardware Setup Wizard window that opens and follow the directions carefully. When asked to have Windows find the driver select "No" and then browse to the location of the driver that you have. Let the Hardware Setup Wizard install the new driver and close the Device Manager.<br /> </li></ol>
on Oct 29, 2010 | Computers & Internet
Tip
What are drivers?
Drivers are small software programs that help control devices attached to your computer because drivers enable your operating system and other software to communicate with various hardware devices, controllers, and other peripherals. In other words, drivers work as instruction manuals that provide software with the information with regard to controlling and communicating with different hardware devices.
Why do we need drivers? Drivers help computers identify and run installed hardware. A device driver is a code that an operating system uses to control disk devices, display adapters, input devices such as a mouse or trackball, modems, fax machines, printers, and other hardware. Without drivers, computers will not be able to distinguish between a sound card and a modem. Most computer devices and peripherals need drivers to run, which means that computer accessories, such as printers, scanners and digital cameras also need drivers to function. This is what all computer hardware and accessories that are purchased come with drivers stored in either a floppy disk or a CD. A computer automatically loads the drivers when these disks are inserted in their respective drives.
Like any other software, drivers are upgraded and updated by the manufacturers to remove bugs, add extra functionality to the hardware or to improve the performance of the device. Unless you update your drivers regularly you may face problems ranging from the relatively minor, such as having hardware that seems to perform poorly, to the more major problems such as hardware failure, hardware conflicts and complete system crashes.
Choosing and installing the correct device drivers for a given hardware is often a key component of computer system configuration.
Where you can get Drivers? Drivers can also be downloaded from the websites of hardware manufacturers. You can download the most recent or updated drivers for your hardware. You can do this by navigating through each manufacturer’s website and searching for the page that allows you to download drivers for their products. However, there are some software (ex. Driver Robot) that automatically scans your computer, looks for the drivers you need, and automatically installs them to your computer. These kinds of software are very easy to use and they can ensure that you will have the most up-to-date drivers for your devices.
on Apr 08, 2010 | Computers & Internet
Cant load pics onto computer
have load the driver on the computer if not load the drivers or else go to the device manager and right click on the computer and scan for new hardware and see if there is any error symbols on any of the device
Jun 12, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
I have 12 Drives All 12 Drives are found but when I burn a DVD The Some drivers fail and it is not the same ones all the time
Usually, a driver update is used as a solution to an issue with how Windows works with a piece of hardware.
Updating a driver can also enable new or updated features for the hardware.
To access Device Manager, use any of the following methods:
  • Click Start, click Run, and then type devmgmt.msc.
  • Right-click My Computer, click Manage, and then click Device Manager.
  • Right-click My Computer, click Properties, click the Hardware tab, and then click Device Manager.
  • Type the following command at a command prompt: start devmgmt.msc
You can use Device Manager to change the way your hardware is configured, and to change the way your hardware interacts with your computer's programs. With Device Manager, you can update device drivers for hardware installed on your computer, modify hardware settings, and troubleshoot problems.
Device Manager enables you to:
  • Determine if the hardware on your computer is working properly.
  • Change hardware configuration settings.
  • Identify the device drivers that are loaded for each device and obtain information about each device driver.
  • Change advanced settings and properties for devices.
  • Install updated device drivers.
  • Disable, enable, and uninstall devices.
  • Reinstall the previous version of a driver.
  • Identify device conflicts and manually configure resource settings.
  • Print a summary of the devices that are installed on your computer.
If the device is experiencing a problem, the type of problem is displayed. You might also see a problem code and number and a suggested solution. If you call a support line, this number can be useful for determining and diagnosing the problem.
How to install a new driver from Device Manager loadTOCNode(2, 'summary');
  1. Double-click the type of device you want to update or change.
  2. Right-click the specific device driver you want to update or change.
  3. Click Update Driver to open the Hardware Update Wizard. Follow the wizard instructions.
Rolling back to a previous version of a driver loadTOCNode(2, 'summary'); Use this feature if you encounter problems after you install a driver, such as error messages when you access the device, faulty behavior of the device, or even the inability to start Windows.
Windows XP provides this roll back to a previous, working, device driver:
  1. Right-click the device for which the previous version of the driver is desired and then click Properties.
  2. Click the Drivers tab.
  3. Click Roll Back Driver.
If you cannot resolve the problem with these instructions, contact the manufacturer.
Dec 04, 2009 | ASUS QuieTrack CB-5216AG CD-RW/DVD-ROM...
Error 39 canot load the driver
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Uninstall and reinstall the driver
Uninstall the driver from Device Manager, and then scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
Nov 27, 2009 | Lite On (LTN486S) Internal 48x CD-ROM...
Code 39
hi,
error code 39 stand for (Windows cannot load the device driver for this hardware. The driver may be corrupted or missing.)
Reason
There are several causes of Code 39 errors:
  • A required device driver is missing.
  • A required binary file is corrupted.
  • There is a problem with the file I/O process.
  • A driver that is referencing an entry point in another binary file is unable to load.
Recommended resolution
Reinstall the drivers for this device.
Sep 26, 2009 | Computers & Internet
Can u brief me about drivers
Computer drivers are software programs. It helps a computer identify and run the hardware installed in it. For Example, without drivers the computer will not be able to distinguish between a sound card and a modem. Most devices on the computer need drivers to run. Computer accessories, such as printers, scanners and digital cameras also need drivers to function. All computer hardware and accessories that is purchased comes with drivers either in a floppy or a CD. The computer automatically loads the drivers when inserted in the drives. Drivers can also be downloaded from manufacturer's websites. You can download the most recent or updated drivers for a hardware.
Jul 11, 2009 | Computers & Internet
I have a dvd writer model LG GSA-E60L an when i install windows xp tells me that it is not digtally signed and also it comes up with error41 cant find hardware wont let me install and also i cant find my...
Code 41
Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
A driver was loaded but Windows cannot find the device. This error occurs when Windows does not detect a non-Plug and Play device.
If the device was removed, uninstall the driver, install the device, and then click Scan for hardware changes to reinstall the driver. If the hardware was not removed, obtain a new or updated driver for the device.
If the device is a non-Plug and Play device, a newer version of the driver might be needed. To install non-Plug and Play devices, use the Add Hardware wizard. Click Performance and Maintenance on Control Panel, click System, and on the Hardware tab, click Add Hardware Wizard.
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
Jul 08, 2008 | Computers & Internet
Computers & Internet Logo
15 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Gbenga
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
