Question about Sony VPL-HS20 Multimedia Projector
Using HDMI input keeps changing to memory stick!!!!
When I use the HDMI input, it keeps going to MS. ANY SOLUTIONS?
  • Anonymous Dec 13, 2008
    I have the same problem ... periodically, and more frequently when the
    unit gets hot. I just tried changing the Filter to see if that
    will keep it cooler (it's been a while anyway).
    If this doesn't work, I'll probably end up taking it to Sony repair.
2 Suggested Answers
SOURCE: SWITCHES TO MEMORY STICK
If you unplug the unit for a few hours prior to use this will fix the problem .
Posted on Nov 30, 2008
I bought a 2gb memory stick for my psp, once i insterted it in an orage light keeps blinking and while i put it on usb mode it says there is no memory stick insterted when there is
If the MS light keeps blinking continuously, that means that the PSP cannot read the MS you inserted. That happens normally. You just need to take it out, then put it back in. That's the simple fix there.
To pull it out, open the MS slot first. Gently push the exposed part of the MS, inward to pop it out.
When putting it back in, make sure that it's perfectly aligned and that the light blinks fast only for a couple of seconds (2 to 4sec) and then immediately stops. That means, the MS is properly placed and can now be read.
May 15, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
When I try to insert a memory stick into my sony cyber-shot dsc-p20 it won't lock in place and I can't close the door. Help!
Try quickly pushing the card in and letting it go, fast. Keep trying this and see if the card finally locks, you could have a build up of fluff on the latching mechanism. doing this could free the fluff and problem solved.
Its also possible that the latching mechanism has dislodged which means a dismantle at a repair shop.
Apr 10, 2010 | Sony Cyber-Shot DSC-P20 Digital Camera
KDL-40V5100 TV HDMI Issue
I have the same problem did you ever find a solution
Jan 07, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
Wrror message C13:01. Keep saying insert memory
First you have to find out if the problem is caused by the camera or by the MS. Replace the MS. In case of wrong MS you may restore photos in some card reader using some freeware restoring SW. In case of wrong camera check pins for MS in the slot.
Oct 18, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
I HAVE SOME CORRUPTED DATA IN MY MEMORY STICK
check if magicgate in your memory stick is supported, if not...it´s an alternative MS...but you can try to format all your memory stick using your psp , PS3 or even with a pc MS card reader...re-install all ms softs...
Sep 14, 2009 | Sony PlayStation Portable (PSP) Slim...
Memory card freezes psp after trying to convert a movie
one thing u should learn is that u shouldnt cancel an ongoing process so as not to corrupt ur registry. formatting it should ease the problem
Jan 07, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
Memory Stick error c:13:01 My old 512 MB memory stick is working fine. However, recently I brought a 2 GB memory stick and when I put it inside, the camera (Sony DSC S40 cyber shot) shows: MEMORY STICK...
Is your new 2GB memory stick is original from Sony or after market? some of them will not detect in CAM because the contact on MS were not touched iside the slot of CAM
Reinsert your 512 MB MS if it work fine then change your 2MB MS
Good luck
Nov 30, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Apr 12, 2008 | Sony VPL-HS20 Multimedia Projector
Lcd montior with tv box but no hdmi sound
in some cases certain manufacturers say in the instructions that when using s video with seperate audio, you cannot use the HDMI for the sound and sometimes visa versa, it's just the way the output is set up. Remove the other sound cable you are using for pc or tv and just use HDMI to confirm that the sound is re-enabled on the HDMI
Oct 02, 2007 | Sony Playstation 3 (PS3) Console
Sony VPL-HS20 Multimedia Projector Logo
62 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
