Question about Agere All 56K Modems: 56K V.92 Lucent/ Chipset W/Voice Software Modem (MODOE5605)
Agere All 56K Modem
I have installed the subject modem in my computer. When I try to connect the intenet through dialup I dont get dialing tone?
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    did you check to see that the phone line is in fact active before plugging it into that modem. also, those modems usually have two ports. make sure the phone line is plugged into the IN port.
I just on the computer and it was in the process of starting that there was a breakdown of Electric? After that when I started the computer there was a message: "DMA Controller Error" Fatel Error -System Halted. After that I cannot start the computer.
Kindly solve my problem.
Nazim
Posted on Oct 25, 2008
I have checked the telephone line, it is working alright and it is sure that I have plugged the line into IN port.
Posted on Oct 19, 2008
I have a hp compaq nx7400 laptop with an agere systems hda modem.i have a dial tone and when i try to connect to the internet the modem sounds like it is dialing but the dial tone never goes away.is the...
The Agere systems HDA modem is a 56kbps modem typically found on laptops. View it in device manager.
Start->Control Panel->System->Device Manager->Modems
Should be listed there. See if there is an exclamation mark next to it.
Not very expensive or difficult to replace
Aug 14, 2010 | HP Compaq Business Notebook nx7400
Agere modem 2.0 no dial tone message
if its working properly before, try to remove the wirings and clean it a little then try it again, possibilities is its wires didn't contact properly.
Apr 26, 2010 | Computers & Internet
Hi, to every one. I need to disable a dial tone from my laptop modem to make a data call to plac from omron. When i call from local because the sound is one tone, it dial but when i call from standard...
WELL I SOLVED THEE PROBLEM BY INSERTING A "x3"AT COMMAND IN THE MODEM ADVANCED SETTINGS, AND I MADE A CALL FROM STANDARD PHONE LINE.
THE IDEA WAS THAT I MAKE A BLIND CALL, TO PLC VIA GSM MODEM. THE ATX3 COMMAND MAKE BUSY IF THE LINE IS BUSY OR BLIND CALL IF LINE IS FREE.
WELL THAT'S MY SOLUTIONS,
Nov 19, 2009 | Agere All 56K Modems: 56K V.92 Lucent/...
Error keeps saying
install the modem drivers properly
Aug 31, 2009 | Agere (DSLU56KPCI) Modem
Agere Win Modem Driver Version 8.30.0.0 vs V.92
My solution was to go to Staples and they were able to help me.
Thanks.
Feb 05, 2009 | Agere FM56 / 56k -V. 92 (Lucent) PCI Soft...
Missing modem
what is XE3 circa 2002, 15 years young. wow.
XP is now 3 years dead, at microsoft.
why not at least upgrade to Win7. be wise to do that.
XP must have SP3, if not it will fail, and even with it it fail.
lots of USB devices for example will fail. here.
dial up, you dont run DSL.
ive not see dial up in 20 years. why dial up.?
if compelled to use dial up, you need a modem that XP understands
most of them it does not. nor will it ever,
there are 2 classes of modem. (DIAL up to POTS)
1: software modem (99% software, and a box) they SUX. all do.
2: hardware modem, best is USB. by
and A good dial up program,. windows dial up software stinks.
https://www.cdw.com/shop/products/Hayes-ACCURA-World-Approved-V.92-56K-External-USB-Mini-Modem/1651998.aspx
i see this is HP supported (was) modem
Agere systems soft PCI
it needs the HP.com driver to run that modem
does the number you dial buy hand (using a POTS phone)
dial up and answer and squeal? if not its hopeless that number
you need to pay for superscription service, and with a pass word.
LIKE HERE
http://www.earthlink.net/dialup/
THE PROBLEM IS HP NO LONGER SUPPORTS YOUR PC
SO THERE ARE NO DRIVERS. now.
why not get 10 year or newer PC, or get DSL to home
or cable modem with only 1 channel active, (slow like dialup)
for cheap. (im using 16channel now, as i type)
or buy a new modem and connect it and use the new modems
disk to install a nice dialer for you.
but finding one is not easy now.
the best modems, are Hayes, there hardware modems are like rock. i used them back in the ARPnet days and on amocat.
Apr 20, 2017 | HP XE3 SYSTEM BOARD WITH MODEM & LAN HP...
Modem stopped working
Well its sounds ike the modem may poked ut lets assume it is not perhaps yo have doube checked your conection is correct if it is TRY ANOTHER modem because they are known probems for your coonections especially dialup are you meaning this?
Jul 13, 2008 | Toshiba Satellite A135-S4527 Notebook
USB modem HiRo model H50113 will not complete phone connection
Yes you're right! What you have to do is:
  1. Right click My Network Places
  2. Select Properties
  3. Select the Advanced menu
  4. Uncheck "Operated-Assisted Dialing"
Jan 30, 2008 | Hiro V.92 56K AGERE Chipset PCI Fax Voice...
Agere All 56K Modems: 56K V.92 Lucent/ Chipset W/Voice Software Modem (MODOE5605) Logo
524 people viewed this question
Top Agere Computers & Internet Experts
David Payne
David Payne
Are you an Agere Computer and Internet Expert? Answer questions, earn points and help others
