Question about Samsung VP-D103i Mini DV Digital Camcorder
Zoom Problem When operating the ZOOM switch, rather than zooming in and out, the image just goes in and out of focus. There are actually two points at which the image is in focus, and once set to either of these, the autofocus seems to work.(IE when moving between near and far subjects, it remains in focus).
  • Mvic Dec 10, 2012
    This exactly explains the problem I'm having as well. I have 2 points at which the camera will come into focus, otherwise it's blurry.
  • 1,476 Answers
There are two components to a camera lense. One adjusts the final lense distance from the CCD imaging chip the other adjusts the distance between the lenses in the assembly (which zooms the image in and out). It sounds like something inside the lense came loose and when you zoom the lense the focal lense is moving with the rest. The lense will probably have to be replaced if it cannot be taken apart. Odds are something is broken inside anyway. This could be something you might be capable of, I have no way of knowing. If you do not think you are up to the task, have a reputable repair shop do it. Cost should not be excessive. I would think less than $100 US plus the cost of the part. Good luck.
Posted on Jul 24, 2006
SOURCE:
When I zoom in to take a picture I get it focused I hit the button and the picture shows up not zoomed?
How are you zooming in? If you are using a button to zoom, that is to check the focus: it's just enlarging the image for your convenience during focusing. In order to get a zoomed-in image when press the shutter button, you need to adjust the zoom ring manually on the lens barrel before taking the picture.
Sep 24, 2014 | Canon EOS 600D Rebel T3i Digital Camera
When i zoom my cam in and out, it became blurder.
On a webcam, you will generally find that they don't have the optical zoom that you would find on a compact digital, or SLR camer. in most cases, the zoom that you have is digital zoom, this just increases the size of parts the image being fed to the computer, and will often become blurred after a certain point. the best advice would be to move closer to the cam, or to buy a camera with higher resolution...generally 5MP should be more than enough.
the other thing you should try first, is to check that the camera isn't out of focus by looking for a ring around the lens, on some models there will be an adjustable focus, if this is the case,rotate the ring until a desirable image is shown.
Apr 30, 2011 | Computers & Internet
Just need a manual foor Nikon One.Touch Zoom 90s
Description: Sleek and stylish, the exciting new Nikon One-Touch Zoom 90QD offers real zoom power in a lightweight, easy-to-use design. The One-Touch Zoom 90QD has a sharp, clear, 2.5x zoom lens with a 38-90mm range and a macro mode for shots as close as 11 inches. The One-Touch Zoom 90QD features a built-in automatic flash with five versatile modes (auto flash, anytime flash, flash cancel, slow sync and red-eye reduction). The active infrared autofocus, infinity focus (for landscapes and faraway subjects), real-image zoom viewfinder and fully automatic exposure control all help to ensure clear and balanced photos.
7444ca6.jpg Depth 2.1 in. Film Type 35mm Width 4.6 in. Height 2.5 in. UPC 018208018789 Battery Type 1 x 3V Lithium Battery (CR-2) Weight 7.84 oz. Self Timer Yes Camera Type Point and Shoot Focus Type Autofocus Minimum Focus Distance 1 ft. ISO Range - Automatic Setting ISO 100 - 800 Red Eye Reduction With Red Eye Reduction Zoom Size 2.4 Auto Exposure Yes Min Aperture f10.5 Waterproof No Max Aperture f4.8 Zoom Lens With Zoom Lens Zoom Range 38 mm - 90 mm
User Manual can not be found up to now. Very soon will be available.
Jan 26, 2010 | Nikon One Touch Zoom 90S 35mm Point and...
Just purchased it from bid tv it has 4xdigital zoom would i have been better to get optical zoom instead this is my first camera
Digital zoom enlarges the ccd image and will become more pixelated the more you zoom and optical zoom uses an actual lens to magnify the image coming into the camera. optical zoom is better than digital zoom.
Sep 25, 2009 | Vivitar 7.0MP Camera Digital Camera with...
I look through viewfinder and view is out of focus
Yes, common problem, small plastic tab(s) connecting viewfinder to the zoom are broken.
Apr 17, 2009 | Olympus Stylus Zoom 140 35mm Point and...
Camara not focusing/ zoom not working
Its an error code and shows problem of Lens mechanism.
Lens focus / zoom motor is stuck that's why camera gives out of focus image.
You need to replace Lens Assembly and it would cost you more then camera worth.
Oct 26, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Over exposure when zooming
If you want to be able to use optical zoom try getting a more advanced camera because cameras like Nikon Coolpix 4300 does`nt have quality zoom its very poor and you can see it yourself the images gets blurry when maximize your zoom.
Jun 22, 2008 | Nikon Coolpix 4300 Digital Camera
Dimage Z3 blurred zoom images
I don't think there's any problem. Simply, a longer zoom means that - without a faster shutter speed - there is an increased probability for camera shake. Additionally, cameras usually struggle with focus in longer zoom. To be sure that there isn't a fault, do this:
1) Place the camera on a tripod or other sturdy surface
2) For additional stability (and to avoid camera shake due to shutter button movement), select the self-timer
3) Focus and take the shot.
If it's still blurry, then yeah, there's a problem
Dec 21, 2007 | Konica Minolta DiMAGE Z3 Digital Camera
IESP auto focus
iESP is the default auto focus setting for the C-8080 Wide Zoom camera. It uses a contrast detecting system to analyze the entire image by comparing the subject against the background to achieve focus. When the shutter button is pressed half way on the C-8080 Wide Zoom, the AF target mark automatically moves to an area of the image where it finds the optimal contrast.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
Focusing distance in macro mode
On a D-580 Zoom camera, the Macro Mode operating range is 8 inches to 20 inches. This means the camera must be between 8 inches and 20 inches away from the subject for a picture to be in focus.
Sep 01, 2005 | Olympia OL-5805 Cordless Phone
Samsung VP-D103i Mini DV Digital Camcorder Logo
104 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
