Question about Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
Tv tuner-hardware could not be located by system
Conseqent to the crash of my system,I had to reformat my os (windowsxp).Windows could not locate my hardware(tv tuner) resulting my inability to reinstal my tv tuner in my system.
  • 1 more comment
  • vsankar Oct 20, 2008
    I did as suggested.But still the problem persists.
  • vsankar Oct 21, 2008
    thank u
  • jason May 11, 2010
    have you tried to , shut down the computer , pull the tuner card out , start up computer , shut down computer again , put the card back in , and start up the computer?
  • 905 Answers
Then the card is bad and you will need a new one ,
sorry it was the card.
but these cards have been going , I was just hoping yours didn'tagain ,sorry
electech
Posted on Oct 21, 2008
GGoof
Posted on Oct 20, 2008
Why is it that my PC (desktop) encountered suddenly shutdown? WINDOWS HAS RECOVERED UNEXPECTED SHUTDOWN Problem signature: Problem Event Name: BlueScreen OS Version: 6.1.7601.2.1.0.256.48 L
You say Windows, but not which version. Regardless, the "blue screen of d??th" is a mighty frustrating issue. There are ways that can help isolate the cause, but they are complex and require additional software. The two things that most often cause crashes are intermittent hardware faults and defective or incompatible drivers. Check to see if you have recently updated and of the component drivers. If so, use the "rollback" feature to go back to the previous driver and see if that helps. Unfortunately, often the only way to solve these problems is to reload the OS. If you can still access your system, now is a good time to back up all your data that you don't want to lose in case the system crashes hard and you need to reformat and reload.
Dec 31, 2014 | Computers & Internet
Mercury Ez View TV Tuner Card Driver for win 64 bit
You have to be sure the computer has the correct software to recognise the hardware and can work with it. From Windows 7 and up, for all hardware that is certified with Microsoft, you can download the drivers from Microsoft. Lots of hardware is recognised when connected and will initiate a download from Microsoft. But not all hardware will do so and not all hardware is compatible (same as not certified by Microsoft from Windows 7 and up) with the new operating systems.
Most things that worked fine with Windows XP and or Vista, can fail with Windows 7 and 8, because the factory that made the hardware in the first place does not ask for certification with Microsoft for their old Hardware. They only spend time and money to get their new hardware certified on the new operating systems. So to make sure your hardware is compatible with the OS. Check the manual and find out, what you have to do so it will work on your computer.
If your device was working on a USB2 port, it also should work on an USB3 port, on the same computer. But don't expect another speed, because the slowest part decides the speed.
Oct 17, 2014 | Microsoft Computers & Internet
Sony VGC LT16E VAIO live tv tuner hardware cannot be found
Go to "Device Manager" and look for anything that has a yellow question mark. If you see this, you need to run the set up program for that device to install the driver/.inf file and let the setup program set other parameters.
Since you reformatted, you removed all your previous settings unless you backed those up previously. If it came with the laptop from the store, it should have come with a CD or DVD rom with the install program.
If you lost that, or cannot find it, go to the Sony website, select "support" and locate that driver or set up program and download it. Make an archive copy of it in case it is needed in the future. The device manager should identify what model of tuner card you have.
Dec 10, 2011 | Sony VGC-LT16E VAIO 22" All-in-One Desktop...
I have got zenith TV tuner card purchased along with zenith TV before 10 years back,which was suitable for window's-98 O.S. Now I am using windows-7 o.s. on which above tv tuner software is not being...
I know all driver of hardware PCI zenith TV tuner can work with windows 7 O.S. try first open your CPU then transfer to other PCI slot of your PC motherboard. then power on PC.
May 30, 2011 | Computers & Internet
I cannot start my computer after replacing motherboard and CPU. How do i install Windows onto the motherboard and how do I install eJiffy?
You forgot to sysprep the OS before removing the old board.
Put the drive back on the old board and CPU and let it boot up.
now sysprep the drive THEN re-install the new board and CPU
To sysprep the drive, do the following:
>There is a SYSPREP tool on the XP CD.
>You may need to extract files from the Windows XP CD, files are located at CD:\SUPPORT\TOOLS\ in a cab file called DEPLOY.CAB. The files are Sysprep.exe and Setupcl.exe.
>With the old motherboard still intact:
>You run sysprep and "RESEAL" Windows XP.
>Then you put the new board in, and it re-activates Windows XP and populates the device manager list.
>You do need to re-activate with the same key-code, and if you exhaust that number of activations, it will prompt you to call Microsoft and you get a new release key at no cost from them over the phone.
The basic problem here is that when windows goes to initialize the old hard disk controller, it loses the hard disk because the controller isn't the same.
It may also be crashing as it tries to initialize other hardware, but it needs that IDE or SATA (or SCSI) controller online even to get into safe mode!!
Good luck - sysprep works about 90% of the time, but if you run into problems, it can be a real bugger to untangle!
Feb 27, 2011 | Computers & Internet
GIGA POCKET TV TUNER NOT WORKING
PROBLEM SOLVED. APPARENTLY THE GIGA POCKET PROGRAM IS AFFECTED BY THE SONIC STAGE MUSIC PROGRAM OF SONY. I RE-FORMATTED AND DID NOT INSTALL THE VAIO MEDIA AND SONIC STAGE SOFTWARE ...
THE TV TUNER NOW WORKS FINE ....
I JUST USE WINDOWS MEDIA PLAYER AND WINAMP FOR THE MUSIC ....
NO REMOTE CONTROLS ... BUT THE TV TUNER WORKED .... ONCE MORE ....
May 19, 2009 | Sony Computers & Internet
I want to crash my computer and reload os and software
you dont need to crash your windows all you need to do is to reformat your hard disk and reload the operating system .
Dec 08, 2008 | Computers & Internet
MFC-8440 PRINTER DRIVER
Go to:
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc8440_all
Follow steps below :
Step 1: Select Type
Drivers Utilities (ALL) common_012.gif Step 2: Select OS Windows98 WindowsMe Windows NT4.0 Windows2000 WindowsXP Home/Professional WindowsXP Professional x64 Edition Windows Vista Windows Vista x64 Edition Windows Server 2003 Windows Server 2003 x64 Edition Windows Server 2008 Windows Server 2008 x64 Edition Mac OS 8.x-9.x Mac OS X (10.1) Mac OS X (10.2) Mac OS X (10.3) Mac OS X (10.4) Mac OS X (10.5) Step 3: Select Language Good luck!
Jul 21, 2008 | Brother MFC-8440 All-In-One Laser Printer
Tv on hp media center
Have you gone through the media center installation process and got the tuner / tuners setup properly?
Jul 03, 2008 | HP Media Center PC 873n (P9875A#ABA) PC...
My acer 5612 WLMI keeps crashing randomly
reformat your system.. always partition your hdd into 2 parts,, the os on one partition and your files on another,, so that anytime your system is in trouble,, you can reformat it without worries...
there must have been a virus in your system or there was something wrong in the installation of your os..
if this doesn't work,, maybe it is a serious hardware problem...
Jan 26, 2008 | Acer Aspire 3680 Laptop
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
57 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
