Question about Toshiba Satellite A135-S2386 Notebook
Hello my session was shutdown. dont know why.
You can reach me here
good luck with the drivers
When i try to shutdown my acer aspire 1640z, it logs off but when it reaches the shutdown process, it goes on endlessly without completing shutdown. am on windows 7. please assist.
Try to download the beta driver from here:
http://forums.m-audio.com/showthread.php?t=11130 -- you have to register to download, but it's quick & free
let me know if that works for you.
Hope this helps.
Cheers!!!
Jan 13, 2011 | Acer Aspire 1640Z Notebook
HOW TO CONNECT IT TO WINDOW 7
Hello
Connect the printer with your computer using USB cable, and install drivers to windows 7 from the CD comes with printer, if you dont have CD download drivers from HERE and install
http://panasonic.net/pcc/support/mfp/dp-8020/index.html
feel free for more assistance
Good Luck
Dec 14, 2010 | Panasonic WORKiO DP-8016 Printer
I cant detect my philips ipod sa011102s/97 wen i connect it to my pc.plz give me a solution.i dont have a driver for that.
You can get the drivers from here:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?tmplt=ePlatform%20-%20Philips&scy=US&slg=AEN&sct=FLASH_AUDIO_PLAYERS_SU&cat=MP3_MEDIA_PLAYERS_CA&session=20100822135318_196.192.81.33&grp=SOUND_AND_VISION_GR&ctn=SA178/17&mid=Link_Software&hlt=Link_Software
good luck!
Aug 22, 2010 | Philips GoGear SA178 MP3 Player
Reciever powers up but after about 2 or 3 minutes it shuts off does any one know why?
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Its usually not a fault that you will see unless somethings burnt up. This is solid state electronics and you dont see this stuff go bad. But in the meantime try disconnecting the speakers and see if it still goes into shutdown and at the same time have a dc multimeter attached to the speaker outputs. If the unit comes on and you dont see any DC at all or very very little B+ on both speaker terminal sets then you may have a defective speaker. If you do see dc then thats why the protections comming on so you dont blow out your speakers. If you dont have any equipment or dont have any electronics experience I would then take the unit to a repair person for an estimate. Good Luck
May 25, 2010 | Denon AVR-1706 Receiver
When turn the system on it usaully says hello and when you turn the system off it says good bye but now it skips hello and go strate to good bye and turns off please help me
hello,
do check if the mains power is at steady voltage by the use of a voltmeter.
May 25, 2010 | Fisher DCS-C20 Shelf System
Need software driver so that I can connect my sansa e280 to my computer using vista
All support for the Sansa e200 series can be reached with next link:
http://kb.sandisk.com/app/answers/detail/a_id/4487/session/L3NpZC9rSlNkUHlTag%3D%3D/sno/0#e200
When needing more help, just add a comment in this thread.
Jan 19, 2010 | SanDisk Sansa E280 MP3 Player
Shutdown and startup problem
when you get into windows you need to perform a surface scan of the hard drive and check it for bad sectors, i sounds like it is having difficulties reading the boot drivers, run chkdsk /f to check the disk for any problems and it should fix them for you, if the drive comes up clean with no problems then the system 32 folder is corrupt and you are looking at a full system recovery, make sure you back up all of your data while you can still use the machine
good luck
Nov 15, 2008 | Computers & Internet
Explore won't open in Vista (not IE, I mean windows file explorer)
Most likely a damaged or altered registry entry. Clicks start and type
'regedit' and hit <enter>. Expand the keys at left to reach:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Click on this key, then locate the shell string in the right pane. Double
click it, replace the contents with just:
explorer.exe
Click ok, then close the registry editor and reboot.
This will resolve the issue.
Good Luck.
Live, Love, Laugh.
Apr 30, 2008 | Microsoft Windows Vista Home Premium with...
Toshiba Satellite A135-S2386 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
