Question about Amana Refrigerators
Refrigerator seems to turn off. My ice cubes start melting them in a few hours it will sometimes turn back on.
    President:
  • Amana Master
  • 2,651 Answers
Can bea few diff issues actually, might be a bad compressor, overheating, shutting off and then in a few hours restarting when cooled off enough. any noises associated with the shut down?? perhaps a motor trying to start(reallly sounds like its struggling to start fro 10 secs or so and then clicks off).. can be a faulty tmep control getting stuck, or even stuck in defrost mode longer then it needs to be,
Posted on Oct 19, 2008
Sometimes ice melts in ice maker. Water drips down and refreezes.
There is a heater built into the ice maker bottom to help release ice cubes from the machine. Under normal conditions the heater only come on when the ice maker starts to run and then jambs against the frozen cubes. When it stalls and jambs against the frozen ice cubes, the heater comes on to melt the cubes enough. I think you have a defective ice maker and the heater is coming on to much or at the wrong time, Since your temps go back to normal with the ice maker turned off, I am almost sure thats your problem.
Mar 16, 2015 | GE Profile PSC25MSWSS Stainless Steel...
My GE side by side refrigerator model PSC25SGSC has a problem. It makes ice fine. But sometime, all the ice cubes melted, along with the food on the top shelf. After I turned the ice maker on and off, it...
Ok this sounds like your mainboard is about to go out, its causing intermittment cooling issues, board runs about $150-200.As long as you dont have any frost buidup in the back of the freezer, if not definitely the board. If you need any further assistance let me know.
Sean
Mar 30, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
A recent power outage seems to have clogged my icemaker. partially formed ice cubes are jammed in the mold and the arm stop arm will not go down.
Hello. I can assist you. Turn off the freezer at the dial and use a blow dryer to heat the ice and melt it. Then use towels to remove the water and dry all of the surfaces. FInally, spray some PAM cooking spray on the surfaces to act as a lubricant. Turn the freezer dial back to where it was and you will be up and running again in a few hours.
Nov 28, 2009 | Sub-Zero 690 Side by Side Refrigerator
Icemaker water overflows into freezer
the condensate tube is run incorrectly on this model and goes uphill into the area above the refrigerator where there is a condensate pan. This will plug and back up and cause this problem. I have fixed ours several times but it always came back. The last time I bought a new clear plastic tube and reran the condensate out the back of the refrigerator and down through my floor. It's all downhill now and seems to have fixed the problem.
Nov 28, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
May 14, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Refrigerator not making alot of ice cubes
a bad valve will make them stick togather and sometimes hollow but the ge is well known for the back board being bad
Mar 18, 2009 | Refrigerators
Ice Maker Stopped Making Ice & Cubes are Melting (rest of freezer is cold)
can you pull the cover off the ice maker to see if the gears are bad?let me know more-mike
Oct 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker problem, side by side refrigerator
ice in ice bin sort of melts and sticks together and wont dispence out the door . it is a G E
Jul 29, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Refrigerators Logo
76 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
