Question about Chaintech MK8M800 Motherboard
Wd sata HD not detecting in BIOS chaintech K8M800
Both wd sata 1 hd(WD800 and WD1600) does not detect in the BIOS.It worked 1 day earlier,but I decided to move the drive to another drive for airflow,when I restarted the machine,it did not detect the HD.Earlier I used a program called system mechanic that stated that one of my sata hd was overheating(WD800).I've tried everything in BIOS and changed jumper settings nothing.
can't find chaintech website to look for BIOS update!!!!
Please help
4 Suggested Answers
  • 16 Answers
SOURCE: Connecting an IDE HDD to a SATA port using an IDE to SATA converter
Not complete product...need to buy additional adapter for IDE to SATA power source.
IDE drive will have to have the power source hooked up as well as the adaptor hooked up.
Installing the adaptor only will not work. Your computer should have the 4 pin plug for the power to the IDE drive, other wise you will have to buy another adaptor.
Posted on Mar 23, 2008
nai6378
  • 58 Answers
SOURCE: can't get SATA hard drive to work
make sure the jumper switches are correct on the hard drive i:e master or slave,perhaps computer select (cs)
Posted on May 10, 2008
  • 561 Answers
SOURCE: Chaintech P35-121-16B9 need the manual or video jumper setting
Hi
Thank you for your query
Generally you dont need to disable the onboard VGA to AGP, all you need to do is to ensure that you plug the monitor lead into the AGP VGA card.
However if you wish to disable the onbaord VGA then please do the following
1) Ensure that the monitor lead is plugged into the onboard VGA card/port
2) Siwitch on PC then press F12, esc or del key to enter detup (When switching on there will be a message that says press X to enter setup)
3) This will present you with a blue BIOS screen, if yuo go through the menu there will be a option that says 'onboard/integrated peripherals'
4) choose that option and there will be a further option 'onboard VGA' this will be set to enabled. Set this to disabled and then save and exit
5) Note at this point you will have to move the VGA cable from the monitor from the back of the VGA prot to the AGP VGA card
I hope this has been helpful
Posted on Feb 28, 2010
MY WD 16OO NOT SHOW UP ON MY COMPUTER
check power and data cords , try to replace SATA cable, if your bios still cannot detect it, then the PCB controller board is defected and must be fixed or replaced with a working exact same one
Feb 16, 2012 | Western Digital Caviar WD1600 (1600YD) 160...
My WD Elements SE 1TB is not working when I connect it to my mac. One day was fine and now it isn't even recognized by my macbook. I've been reading multiple issues with this product on line and would...
The only way you can check physically is to change the USB cable. The other softwares that can assist :
1. Head to WD website and download diagnostic tool that may troubleshoot the hard disk but once it is recognized.
2. Try connecting it to a different PC running Windows.
3. You can check if the HD is being detected or not in BIOS menu. If it is being detected proceed to step 1, if not then change cables. If still it is problematic then you have to contact official support from WD for this.
Mar 12, 2011 | Western Digital Elements powered by WD 320...
My wd hard drive is not detecting. i want to data backup.
Only solution for that is to try to make that WD HD to be ur SLAVE! So that u could get the DATA u wanted!
Nov 29, 2010 | Western Digital Caviar SE WD800JD SATA...
Hi from Portugal. I have got a mobo a8n-sli SE and im having trouble connecting my new wd 64mb 1gb green sata HD. I already have got 2 working hd´s, one IDE 128gb and one Sata 320gb and now i...
ur mother bios should support 1TB HDD, only then it ll get detected... u can update the bios of your motherboard with latest bios that is available for ur board in ASus support site...if you update the bios your hdd may get detected...
Sep 30, 2010 | ASUS A8N-SLI Motherboard
Can't detect HD WD 500GB SataII 16MB cache
If you purchased a full retail hard drive the drive came with Data Life Guard tools. Boot to the Data Life Guard cd and follow the prompts to set up your new drive. This should by pass any bios limitations.
If your drive didn't come with the Tool cd you can download it from Western Digital's site.
Mar 23, 2009 | ECS 945P-A (V3.0) Motherboard
Trying to install wd 160gb sata drive on xp home sp2
try a newer xp version (sp3)
or custum build u;re xp, use nLite for it ...
Also in bios u can use the "ide mode" on the sata drive, if u have that option! (it wont afect u;re performance !)
Dec 11, 2008 | VIA JetWay PM9MS Socket 478 PM800 Micro...
Can't get SATA hard drive to work
May 10, 2008 | Chaintech SK8T800 Motherboard
ECS K8M800 bios can't detect hd pata seagate
How you setting the jumper, pls refer to mobo manual book or HDD or your DVD/CD recorder. i gues your problem is in setting the jumper. thx
Jan 31, 2008 | EliteGroup K8M800-M2 Motherboard
Chaintech MK8M800 Motherboard Logo
95 people viewed this question
Top Chaintech Computers & Internet Experts
Mark Gough
Alun Cox
Are you a Chaintech Computer and Internet Expert? Answer questions, earn points and help others
