Question about Ariston Technologies Ariston AWD12 Front Load Washer/Dryer
Ariston "Margarita 2000" Model AL129X [front load washing machine] - Clean sludge from door seal.
We have Australian model washing machine and need advice or instructions on how to thoroughly clean the round rubber seal in front of machine behind glass door.
It has a very thick & smelly brown sludge in places behind rubber which cannot be accessed and properly cleaned.
This sludge gets onto clothes at end of wash.
Can I easily remove this rubber seal and clean it properly ?
I am a handyman, but cannot see a simple way without complete dismantle of machine.
Any help or tips very welcome.
"Sadie" [Gold Coast - Australia.]
Ariston "Margarita 2000 cpu map photo
Posted on Nov 20, 2009
  • 3 Answers
I don't think it is easy to remove it, but you can clean it with white spirit or something similar.
Posted on Oct 29, 2008
How to remove front of Ariston washing machine AVD 129 SK
take the top off,remove the soap bucket,take the screws off on the pc board/front cover. the top screws of the front pannel are usualy behind the display cover. the botom screws are behind the bottom plastic cover which you have to prey off with a screwdriver from the top side.
Mar 18, 2014 | Ariston Technologies Washing Machines
What is the best thing to use to clean the inside of the front door seal that has sludge in it.
Bosch Classixx WFC 2465 Front Load Washer how to
clean door seal.
This video will show you
how to change a door seal on this Bosch front loader washing machine .
we have all bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 22, 2011 | Bosch Classixx WFC 2465 Front Load Washer
My ariston margarita dosent want to take a wash load
Most likely the EPROM is gone, or more commonly known as the PCB (Programm Control board) and it needs replacement. Costs about £80 for the board plus installation.
Dec 14, 2009 | Ariston Technologies Ariston AWD12 Front...
Tub smells like mildew, how do i get all the sludge out from the rubber lining, no matter if I run the tub clean cycle, it does not remove any of the sludge!!!!
You need to manually wipe out the inner seal(lining) every time you finish with the washer. This is one of the main complaints with front loading washing machines. You also neep to leave the door open(ajar) after you finish washing so the machine can completely dry out inside otherwise you will get a buld up of mildew. Also run a dishwashing packet like cascade(yes the stuff for the dishwasher) when you run the clean cycle. It is the same as the expensive washing machine cleaning packets that the appliance servicemen from sears sells to customers.
Nov 29, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
How do you clean the mould build up off the flexible door seal of a front loading machine. Can I take out the door seal safely to do it. Westinghouse front loading washing machine model LF711C
Bleach:Water solution 1:2 should kill the mould effectively.
What they should have told you when you bought this machine and what it almost certainly says in the owners manual is that front-loading washing machines, all brands, are prone to this problem. You must wipe the rubber gasket/door seal off when done using. Every time.
Dumb, I know, but necessary.
Sep 08, 2009 | Washing Machines
My Bosch washing machine is leaving sludge like marks on my clothes. Ran the machine at 90 degrees with soap but no load. Didn't solve the problem. Any ideas?
Make sure the draw is 100% clean inside the draw compartment to if the draw is all clean next thing to cheak is the rubber door seal make sure it is clean all the way round next thing to cheak is the pump at the front of the machine pull down the cover and undo the the pump cover by tuning anti clock wise water will come out when you cheaked it is 100%clean put it back together if you get stuck read manual if all toughs things are clean or bean cleaned. do a 90 again with washer cleaning detergent with you can buy at the super market hope this helped.
Aug 26, 2009 | Bosch Classixx WFO 2466 Front Load Washer
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Ariston Margherita 2000 AWD12 Advantage washer dryer filter clean
To clean filter, remove the lower plastic panel at front of washer.
Unscrew the pump filter cover anti-clockwise to remove and clean.
Please rate my fixya solution.
Thanks.
Feb 13, 2009 | Ariston Technologies Ariston AWD12 Front...
Ariston Technologies Ariston AWD12 Front Load Washer/Dryer Logo
3,265 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
