Can't restore system to an earlier time, stuck on current.
Outlook 2007 windows won't launch. Can't find the command window to type in scan scfnow :) .Am currently backing up my whole system just in case. Done something dumb when restoring system to an earlier time (which didn't quite work, need to go back earleir) and now can only restore current time.
  • 1 more comment
  • kingy 2 Oct 19, 2008
    Hi Ellin,
    Don't know if you read the entire profile, I'm on Windows Vista HOme Premuim edition and I can't e mail you as my fault is Outlook won't launch!
  • Anonymous Mar 16, 2009
    i have a trogan horse virus
  • Puneet Jain
    Puneet Jain May 11, 2010
    Are you having Window Xp or Vista?
    Let me know if you need further help to fix the issue I can solve it (email me on techin.scott at the rate of gmail dot com.) Whenever you have time we will go for remote session to fix the problem.
    Have a Nice day,
    Regards,
    Ellin
    Guru:
  • 558 Answers
Which firewall and Antivirus running on your PC?
Do you have MS Office installation cd then go for recovery of Outlook.. just click on add remove program for Outlook and then click on repair and put the CD in. Hope it will work in this.
Otherwise send me the Hijacklog file of your PC. (use other email account for mailing such as hotmail or yahoo)
Please can you download and run the following program http://www.neurosoftcorp.com/analyze2.php
Save it and install it on the desktop.
Run the hijackthis program and click on "DO A SYSTEM SCAN AND SAVE A LOG FILE" Button. (Despite the program name – This is a standard tool used by PC technicians to examine malicious files)
When the scan is finished, it will automatically create a log file and open it in Notepad program.
Save the log file (a text file). Most of what it lists will be harmless or essential, don't fix anything yet.
Please send the log file to me as a text attachment (its called Hijackthis.log - and located on the same place where you install Hijackthis program as above)
This will help me to locate malicious programs and other corrupt files on the PC.
  Regards,
Ellin
Posted on Oct 19, 2008
How to restore Outlook .pst files from a back-up drive?
Use Outlook Backup Toolbox is an all-in-one tool for backing up your Microsoft Outlook data and restoring them when necessary.
For more: https://outlookbackup.recoverytoolbox.com/
Oct 29, 2015 | Microsoft Office Outlook 2007: Windows
I need to restore my computer without disc, what should I write in command prompt?
To access the System Restore Gui from command prompt you will need to type in rstrui.exe
OR
%Windir%\System32\rstrui.exe
Other Thoughts
If you are experiencing Boot issues you will need to install a boot manager. If your system is missing a file or a file is broken, you may need to replace that file with a working version that's compatible with your OS Version.
Aug 07, 2015 | Dell OptiPlex GX270 PC Desktop
Windows cannot find
will the computer boot to an operating system ?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
You should have no input while chkdsk utility is in progress any input might further damage your computer also
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
If this fails you might use the system restore option
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Jun 07, 2013 | Computers & Internet
Gateway dx4710-05 will not start upgoes to repair , will not repair
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
May 19, 2013 | Gateway DX4710-05 PC Desktop
Acer aspire ast180-ud400
You have no stated what sort of problem?
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
May 19, 2013 | Acer Aspire™ T180 PC Desktop
Windows 7 system restore
Click Start
type in restore
select System Restore
wait for it to launch
then click on Next
select the restore point where it is before the date when you made something bad to your computer
Click Next and follow the upcoming instructions.
Remember to close all the programs before launching system restore
Mar 28, 2013 | Microsoft Office Outlook 2003 for PC
Exception EInvalidPointer in module SysMech.exe at 00061CD
As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select the safe mode option then run your antivirus if still cant get rid of the virus restart again Use the up and down arrow keys to move the highlight to your choice. select safe mode with networking download anti malware and microsoft security essentials http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus anti virus and malware http://windows.microsoft.com/en-US/windows/products/security-essentials If this fails you might have to go back into safe mode. You might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System Configuration utility Installation restore points that occur before you install a program or a service. You can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. Hope this helps
Dec 13, 2012 | Iolo Technologies System Mechanic: Windows
How do i perform system restore?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To perform a System Restore, use the following steps:
  • Select All Programs, then Accessories, System Tools, and then click on System Restore.
  • Select “Restore my computer to an earlier time” and then click on next.
  • A calendar with different restore points will be displayed. Select a restore point which you would like your pc to be restored to and then click “Next”.
  • Confirm the restore point you selected by clicking “Next” and the computer will automatically perform the System Restore.
Jan 09, 2010 | Microsoft Computers & Internet
Outlook 2007 will no longer open - I get a MAPI error saying the mspst.dll is missing. Everything was working fine until I did an auto update which had to be restored to an earlier time to be able to...
Go to Microsoft support and allow it to assess your system. It should be able to find out what is wrong and rectify it, failing this, you must contact them and I am sure they will have a package to restore your settings.
Dec 29, 2009 | Microsoft Office Outlook 2007: Windows
How to remove manually Malwarrior rootkit malaware please help
Sir,
Manual removal of any spyware can be difficult. When you try to manually remove MalWarrior 2007, you risk destroying your PC. It’s highly recommended you use an automatic spyware scanner to determine you’re infected with MalWarrior 2007. It’s also recommended you backup your system any time before editing your registry.
Your Windows registry is the core of your Windows operating system, storing information about user settings, system preferences, and software, including which applications automatically launch at start up. Because of this, spyware, malware, and adware will often bury their own files into your Windows registry so that they automatically launch every time your start up your PC.
Because your registry is such a key piece of your Windows system, you should always backup your registry before you make any changes to it. Editing your registry can be intimidating if you’re not a computer expert, and when you change or a delete a critical registry key or registry value, there’s a chance you may need to reinstall your entire Windows operating system. Make sure your backup your registry before editing it.
  1. Select your Windows menu “Start,” and click “Run.” An “Open” field will appear. Type “regedit” and click “OK” to open up your Registry Editor.
  2. Registry Editor will open as a window with two panes. The left side Registry Editor’s window lets you select various registry keys, and the right side displays the registry values of the registry key you select.
  3. To find a registry key, such as any MalWarrior 2007 registry keys, select “Edit,” then select “Find,” and in the search bar type any of MalWarrior 2007’s registry keys.
  4. As soon as MalWarrior 2007 registry key appears, you can delete the MalWarrior 2007 registry key by right-clicking it and selecting “Modify,” then clicking “Delete.”
Computer acting funny after you’ve edited your registry and deleted MalWarrior 2007 registry keys? Just restore your registry with your backup.
How to remove MalWarrior 2007 DLL files: Like most any software, spyware, adware, and malware may also use DLL files. DLL is short for “dynamically linked library,” and MalWarrior 2007 DLL files, like other DLLs, carryout predetermined tasks. To manually delete MalWarrior 2007 DLL files, you’ll use Regsver32, a Windows tool designed to help you remove DLL and other files.
  1. First you’ll locate MalWarrior 2007 DLL files you want to delete. Open your Windows Start menu, then click “Run.” Type “cmd” in Run, and click “OK.”
  2. To change your current directory, type “cd” in the command box, press your “Space” key, and enter the full directory where the MalWarrior 2007 DLL file is located. If you’re not sure if the MalWarrior 2007 DLL file is located in a particular directory, enter “dir” in the command box to display a directory’s contents. To go one directory back, enter “cd ..” in the command box and press “Enter.”
  3. When you’ve located the MalWarrior 2007 DLL file you want to remove, type “regsvr32 /u SampleDLLName.dll” (e.g., “regsvr32 /u jl27script.dll”) and press your “Enter” key.
That’s it. If you want to restore MalWarrior 2007 DLL file you removed, enter “regsvr32 DLLJustDeleted.dll” (e.g., “regsvr32 jl27script.dll”) into your command box, and press your “Enter” key.
Thanks
Good Luck
"Don't forget to rate the solution"
Jun 21, 2008 | Computers & Internet
Computers & Internet Logo
355 people viewed this question
David Payne
David Payne
