5 second beep/alarm
Im building a gigabyte GA-8GeM667K i have 3 gig cpu and a 2.6gig cpu a 256mg ddr400 legend ram second hand and a LEMEL1 gig ddr400 (hynix chips) brand new may be fulty because i keep getting a 5 second long beep iv turned it on without ram in it and it gave me fast rapid beeps meaning no ram so im thinking the ram is dead or not compatible if you have any idea's it would be a great help my email address is
thank you
  • bradley ireland Oct 20, 2008
    ok i try'd resetting cmos it didnt work so i had the ram tested at a pc shop here and it seems to be working just fine well it did on the pc they tested it on so im now thinking its something to do with the video graffics
    does anyone have any other idea's
Hi krusty_623.
If this is new RAM, you might want to try removing the battery from the motherboard, resetting the CMOS (clears out all the old hardware settings) and putting the battery back in so that the motherboard redetects the RAM as if the setup was brand new. I've had the same problem only once on a RAM upgrade and it baffled me. Once I reset the CMOS the motherboard accepted the new RAM without any problems. I don't know if this will work for you, but it's a simple thing to try.
Posted on Oct 19, 2008
Ga 7VM333M-rz ram slot #2 not active
Find out how much your onboard video is using.
Jun 15, 2012 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
HI I have a Gigabyte motherboard 945GCMX-S2, I have a 1GB ddr2 (667 Hz) hynix ram already installed upgrade it i installed another 1GB dynet ram (666 Hz)..but my cpu beeps now...i remember runni
You should be able to as it can take 4 gig total according to the manual.
2 DDRII DIMM memory slots (supports up to 4 GB memory) (Note 2)
Supports dual channel DDRII 667/533 unbuffered DIMMs (Note 3)
Supports 1.8V DDRII DIMMs
Note 2. Only for GA-945GCMX-S2.
Note 3. Only for GA-945GCM-S2.
Feb 06, 2012 | Gigabyte Computers & Internet
You can find the manual here at Gigabyte. The appendix lists this information about beep codes:
Hope this helps you figure out what to do next. Thanks for using Fixya!
Feb 20, 2010 | Gigabyte GA-MA785GM-US2H Motherboard
Packard Bell IMedia 5055: GA-8SIML will not post or boot. Removed all PCI cards,RAM,Hard drive, optical drives etc. Only CPU and mobo but no post/BIOS screen. CPU fan runs and front panel LEDs work. Do get...
Put just the ram back into the motherboard, the pc will not boot without processor, ram and graphics pluged into the board, check this, if it will still not boot and you still get 3 beeps its a memory(ram) problem, and you will need to replace the memory stick.
Feb 04, 2010 | Gigabyte GA-8SIML Motherboard
What RAM to use. I would like to use 1600mhz RAM but am not sure what would be the best to use. I am installing 12gb of ram. I will install 6gb now and another 6gb later.
Memory  6 x 1.5V DDR3 DIMM sockets supporting up to 24 GB of system memory (Note 1)
 Dual/3 channel memory architecture
 Support for DDR3 2100/1333/1066/800 MHz memory modules
(Go to GIGABYTE's website for the latest memory support list.)
Memory support list Date Subject 2005/05/12 Recommended memory module list for GA-8I915P Duo Pro ...More 2005/03/01 Recommended memory module list for GA-K8VT800 (Rev 2.0) ...More 2005/02/21 Recommended memory module list for GA-K8NF-9 ...More 2004/12/13 Recommended memory module list for 8I845GE-RZ/C ...More 2004/10/15 Recommended memory module list for GA-8TRX330-L ...More 2004/09/02 Recommended memory module list for GA-8TRS350MT ...More 2004/03/22 DDR400 support list for FSB800 CPU support - GA-8IE2004P \ 8IE2004P-L ...More 2003/12/23 PC3200(DDR400) Recommended module list for GA-8TRS300M ...More 2003/11/28 DDR400 support list for FSB800 CPU support - GA-8PE800 \ 8PE800-L ...More 2003/10/16 Recommended DDR400 (PC3200), DDR434 and DDR466 memory modules for GA-SINXP1394 ...More 2003/10/02 Recommended DDR200/266/333/400/466 Memory support list for GA-K8NNXP ...More 2003/07/23 Recommended DDR333(PC2700) memory modules for GA-8S650GXM-P (-C) ...More 2003/03/18 Recommended DDR400 (PC3200)memory modules for GA-8SQ800 Ultra and 8SQ800 ...More 2003/03/18 Recommended DDR400 (PC3200)memory modules for GA-8SG800 ...More 2002/10/30 Recommended DDR400 (PC3200)memory modules for GA-8SG667 ...More 2002/10/30 Recommended DDR400 (PC3200)memory modules for GA-7VAXP Ultra, GA-7VAXP, GA-7VAX, and GA-7VA ...More
Dec 27, 2009 | Gigabyte GA-EX58-UD5 Motherboard
One long beep tone---NO Display on monitor(monitor checked ok)
Definitely not your monitor. It is either a CPU or a Memory problem, is this a new build or did an existing computer suddenly start doing this?
Is that your motherboard, the Gigabyte 7VM400M ?
Jun 26, 2009 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Gigabyte k8m800-8237 won't boot with 2nd gig ram installed.
Could have been dusty. Find a copy of Memtest and run it to check things out. Errors could mean a bad stick or bad slot.
May 03, 2009 | Gigabyte GA-K8VM800M Motherboard
Monitor is not on
Im gonna take it that "yup i'm hear the any beep" means you do hear a beep.
So first If it has an onboard vga card. remove the second vga and hook the monitor up to the onboard and try to boot.
Second try the Power Supply, make sure whatever power supply you use has enough to handle all the equipment in the unit.
If those two don't solve the problem, then you have a bad motherboard.
Mar 17, 2009 | Gigabyte GA-8I848P-G Motherboard
Can ram ddr400 be replaced with DDr800 or ....
it would be supporting but it would generate more heat which has been disaster to ur processor simple way use less than 800ddr ram
Dec 06, 2008 | Gigabyte GA-K8NF-9 (890552602964)...
Computers & Internet Logo
763 people viewed this question
David Payne
David Payne
