Question about Motorola Mobility SLVR L7 Cellular Phone
How to remove write protection from motorola sd adapter
Ihve got a problem with my motorola sd adapter.whenever i uses a memory card it says it is write protected so i am not able to transfer file from or to it.please help me.i hve tried to put the small switch at unlock place but still it does not work.thanks
    Master:
  • 383 Answers
It will be a problem with the card reader or the adapter ....first change the adapter and check ...other wise its a card reader problem
Posted on Oct 19, 2008
Remove write protection on sd card
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 18, 2014 | Electronics - Others
When i try to format my micro sd card system shows remove write protect how can i format it
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
I hope this helps.
Aug 09, 2011 | SanDisk 2GB microSD Memory Card
Plz help me to remove write protection from my micro sd card.
Hi, slide up the Write protection switch which is white in color for the Memory Card Adapter to remove Write protection and Slide down to enable write protection of the Memory Card.
Please click on the link below to view the Write protection switch:
http://kb.sandisk.com/euf/assets/images/faqs/id1102_e3sdhc.gif
If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
Apr 16, 2011 | SanDisk 2GB microSD Memory Card
When i try to add music in to my card adapter pny SD 2 gb it says it has write protection and to take it off what do i do?..
To remove write protection
In your memory card adapter have a switch to on/off write protection.
pull this switch to down ,you can remove write protection of your memory card
thank you
Dec 23, 2010 | PNY 2GB microSD Memory Card
My microsd 2gb memory card show write protected.plz help me
You will need to use a regular SD Card Adapter for the micro sd card. The micro sd card itself does not have a write protected switch, but a regular SD card adapter will, and that does affect the microsd card. You just need to put it in an adapter, flip the switch to make sure it knows it is "locked" - so switch it to locked first, then switch it to unlocked. From there you should be able to write to the card. If you can not then it is possible the micro-sd card is having physical problems and may need to be replaced. Here is a little diagram showing how to unlock the card. Before you go though please make sure to rate my answer 4 thumbs up, it is extremely important to me for you to do so. I would be forever grateful!
Here's the link:
http://www.instructables.com/id/Remove-the-write-protection-on-a-Micro-SD./#step1
Thanks
Tim
Oct 12, 2010 | PNY 2GB microSD Memory Card
I had a samsung corby mobile phone whenever i copy a file using card reader it shows memory card protected please help me for this
Does your phone have an SD or similar card? If so maybe there is a little tab on the side of the card that needs to be slid down or up, depending on its current position, to release the copy protection.
I know that this can be the case with the larger Micro SD adapters, in which you slot your small SD card into a larger card (the adapter) in order to interface it with card readers and the like.
Kind Regards
a
Aug 10, 2010 | Computers & Internet
How to remove write protection from sd memory card
On the Mini SD adapter, there is a small lock tap button,you push down usually when you put your mini SD card in to it, then into the USB adapter. To turn off the write protection on your mini SD, simply do not lock your mini SD in its adapter.
Mar 20, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Memory card write protect?
i had same problem..couldn't solve it with tape over the lock switch and many other ways.. so i purchased a usb card reader (about $5 max) and now it works fine!...just make sure the lock is off!
Jun 02, 2009 | SanDisk 1GB microSD Memory Card
How to remove write protected memory card
Dear the card adaptor which you are using on the side of adaptor there is a side lock please check it may be it is lock that's why u r not able to transfer data.
May 20, 2009 | Motorola Mobility L6 Cellular Phone
Motorola i880 phone.
check that the write protection on the disc is not on its a little switch on the card
Dec 04, 2007 | Motorola Mobility i880 Cellular Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
65 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
