Home | Ariston Technologies | AWD121WH | Dial clicks round
Ariston Technologies AWD121WH
Problem for Ariston Technologies AWD121WH
Dial clicks round
By groovy on Jun 15, 2006
I set the washing machine and it gets to the first part fills with water then the dial just keeps clicking round. I have heard a spinning noise but machine does not spin. Can I fix it?
Same Problem
Dec 27, 2007
-   Iam having the same problem. PUt the machine on programme starts normally but does not turn around and sarts clicking round and carries on until manually stoped.-   Nelley
Best Solution
posted on Jun 16, 2006
Helpful)
dovi
Rank: Guru
Rating: 88%, 2492 votes
Open the rear panel and look for a broken or worn belt. If this is the problem you can replace it easily.
Good luck !
Was this helpful?
Yes
No
Solution #2
posted on Feb 07, 2009
Not Rated)
masc30
Rank: Guide
Rating: 84%, 4 votes
I have an Ariston Margherita AL128 and the same problem happened. After skimming through the manual, it occurred to me that it could be the pump that's causing not to drain or spin anymore. Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manual once in a while, it does help! I lost mine but was able to download a copy from the net.
Was this helpful?
Yes
No
Popular Solutions for Ariston Technologies AWD121WH
Questions and Unsolved Problems for Ariston Technologies AWD121WH
Do you recommend Ariston Technologies AWD121WH?
Answer
Answer
My Ariston Margherita AWD 12 washer/dryer will light up as though a dryer programme has been... (More)
Answer
problem with ariston a1436: 1.) wash cycle is not complete. 2) with water coming out from the soap... (More)
Answer
I have an Ariston AWD121 washer/dryer combo. When I run a dry cycle, the clothes come out soaking... (More)
Answer
I have the above mentioned washing machine and i have a wash in, i have left it as normal to settle... (More)
Answer
The oven has 6 small black push buttons at the top right hand side and the green lit dial... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ariston Technologies AWD121WH:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14709
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
