Question about ASUS P5P800-MX Motherboard
Cpu Fan error
Hi, just recieved a new computer today, when i switch it on i get a message saying cpu fan error, then after a short time the computer shuts down. Any help be appreciated as i cant install windows xp on it. Thanks Intel Pentium D 5.3GHZ (DUAL CORE 2.66) 1G 3200 RAM
    President:
  • 3,130 Answers
Do you have a manual for the mother board?? Sounds like someone forgot to plug in the fan or you didnt say if the fan was working on the microprocessor or not?? If its not working then the plug for the fan should be right by the socket fore the processor. If it is working then theres a setting in the bios that has to be reset. I would take the board to or ask the person you bought it from about it. Did you buy the board with a case or all pieces separate? Good Luck
Posted on Jun 15, 2006
Computer fan is spinning slowly
buy another fun and replace the old one
May 01, 2013 | Antec TriCool 80mm Blue LED Fan Case...
I have dell 'DHS' model ,but my cpu is not working. when i give power supply to cpu that time fan are moving for 5sec after that it's not working.i have checked power supply,power cable, PSU shorts),PSU...
old post. PC is 16 years old today, (junk and not worth $10 used)
1: run it on line power only main battery out. now.
runs now,yhes, then the battery was shorted, get new one.
or run on AC only for ever.
2: RTC coin cell is dead, buy a new one and put it in.
no RTC COIN lasted 16 years, not a single one, impossible!!!
so get rid of this old coin cell., buy a new one, spend $2
3: Now the CPU fan works, and stays on, in some BIOS you can check a box say fan is always , on do so and now it only changes speed. if the fan is dead still then it may be bad. this old easy.
4: CPU overheat, I have never seen any CPU to heatsink
thermal compound last for 16 years, (mine does but not yours)
I use very top quality thermal grease (compound, no aging) ask.
5: The Power pack can be bad. (if PC dead with main battery out the pack can in fact be just bad.
6: is the screen 100% black at all times? no text ever?
most PC this old the CCLF back lamps are dead.
that is why most PC this old are worth nothing until year 2010 made. a fact. get a newer PC with LED back lamps.
ask for advice on this, have lots.
My posts can be all wrong ,after all I can not watch your screen
and do simple tests.
but the fan dead is very very serious matter.
I even strip off all modules in the Laptop, to prove there are no shorted modules in the PC. shorts cause power to shut of.
BY DESIGN.
Dec 31, 2017 | Dell Inspiron 1420 Notebook
My computer is beeping every so often it beeps about 3 times and it does it fast please tell me why
It only mens that there's an error on your computer.
Beep codes are use to check or identify which computer part/s causing the problem.
Beeps
Error Message
Description
1long, 2 short Video adapter error Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly. Repeating (endless loop) Memory error Check for improperly seated or missing memory. 1long, 3short No video card or bad video RAM Reseat or replace the video card. High frequency beeeps while running Overheated CPU Check the CPU fan for proper operation. Check the case for proper air flow. Repeating High/Low CPU Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat. Check the CPU fan or BIOS settings for proper fan speed.
May 11, 2011 | Toshiba Computers & Internet
My computer was in the shop for something unrelated to this problem and now that I have it back it (the cpu fan) sounds like I'm running a vacume it's that loud.
Hi Tim,
I can not say for sure that this is whats happening, but from your description, it seems logical.
After work is done on a computer, sometimes one of the ribbon (data) or power cables isn't completely secured. It can move around within the case, especially if it is transported (like back from a shop).
On occasion one of the cables comes in contact with a CPU fan (or any of the fans in a computer).If it does, the noise they make is horrendous.
Fortunately, the fix is easy. Get a flashlight and a screwdriver.
  • Open the box.
  • Switch the computer on
  • Locate the noise source if possible paying attention to the areas around the fans.
  • When you find it switch off.
  • If it was a cable just relocate it out of the way.
If this turns out not to be the problem, please comment back with more detail.
Best regards
Mike
Feb 05, 2011 | Foxconn CPU Cooler Fan CPU Fan
When i boot up the laptop i get a message 'Main Fan Error' the fan runs on start up then stops just before i get the error message. Fan will not restart... Joseph
This message means that the fan on your CPU (processor) is failing or has failed. This is not good because if the fan on the CPU fails your CPU will overheat and cause your machine to lock up and become non-functional till it cools down and then the same cycle will repeat till the fan is replaced.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 11, 2010 | Gateway (8008625) Cooling Fan, Heatsink...
Dell Dimension 3000 CPU Fan does not run
I agree with both of you. As long as you are not experiencing any heat event (shutting down and rebooting) just ignore the error message. If the fan is on and running at a fair speed, you shouldn't have and problems.
Now should you start to have heat problems, don't boot the computer until you have a larger CPU fan in place...and too you may be able to add an additional fan to the system for reassurance. the added noise is worth the security of not having a CPU meltdown.
Those large 120 are very quiet and move air, if you can find a place to hang it.
Good luck, hope this helps. please leave rating -thank you kindly
Apr 20, 2009 | Dell Dimension 3000 PC Desktop
CPU FAN ERROR PROBLEM
Check to make sure the CPU fan is plugged into the motherboard CPU fan power pins. Should be a 3pin port on the motherboard near the cpu with a white piece of plastic on the one side of it to show you are to plug in the cable correctly.
See if the fan spins at all on start up, or even when the computer is off, spin it with your finger and see if it gets hung up anywhere while it spins.
Mar 18, 2009 | Intel Motherboard
Cpu fan noisy/chip fan fail error messages
pils,
Yes. This sounds like a fan issue. The noise often comes from bearings failing within the fan. Also, a failing bearing can make things harder on the motor as it brings the fan up to speed. This is likely the reason that you see increased warnings during the fan speed check while booting because it comes to speed more slowly as bearing wear increases.
I give this a 90% chance that your CPU fan is causing the issue. Since a decent CPU fan will cost you ~$20 online, it's not much out of your pocket if you happen to uncover another culprit.
I'll keep an eye on this post. Let me know how things go.
Apr 03, 2008 | ASUS A8N-E Motherboard
Cpu fan noisy /chip fan fail
You must buy a new CPU Fan. You can get them HERE or a zillion other places on the Internet. You need a Socket 939 type fan that will handle your cpu speed. If you need help installing it, it may be in the manual. You can read the manual by clicking on the picture of your MB at the top of this post and then scrolling down.
Hope that fixed ya...
Geno
Apr 01, 2008 | ASUS A8N-E Motherboard
CPU shutting down.
Hi MonaMona,
Replacing a CPU fan is easy, but be carefull, the CPU will have old thermal grease on it, so unlatch the CPU at the same time you take the fan off. Because the CPU will come up with the fan, so unlatch the CPU pins, to release the CPU pins, when taking the fan off. And when putting the new fan on the CPU, & the fan nust be smaller then 80mm, the sell just CPU fans. Make sure you put on thermal grease on the CPU, so it won't over heat & will protect your CPU, also don't cake on the grease. Put on a small amout & spread it on the CPU thin. Let me know if that does it for you.
Good Luck with it.
Mar 09, 2008 | Acer Veriton 5200D PC Desktop
ASUS P5P800-MX Motherboard Logo
112 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
