Question about Sony RDR-GX315 DVD Recorder
Cannot record thru line 1
I have my dvd recorder running thru my denon 2806 avr receiver. My receiver receives a signal from my motorola dct6412 comcast dual tuner with dvr cable box. when in the dvd source i can receive the cable signal thru the dvd tuner channels 2 thru 120. I cannot receive a signal from thru line 1. If i select tv in the video select mode i get the video but no audio out thru the speakers. Also no audio on the recorded dvd + or - r or rw. My unit plays recorded dvd's fine. Until a month ago i could record thru line 1, but i now have picture or sound thru line 1 only.I no idea why i cannot record now.
    Genius:
  • 2,985 Answers
If you could but now you cannot then this is a circuit break down- although check your set up , but I feel it is the machine beginning to die
Posted on Jul 31, 2007
When connecting motorola dct6412 to samsung tv, blu-ray player & avr via HDMI (DVI), do you run the HDMI from dvd & cable box to the avr, then seperate HDMI to the tv?
If you have more than one HDMI port on your TV,
run one HDMI cable from the DCT6412 to the TV,
and one HDMI cable from the BluRay unit to the TV.
Then, use the "source" (or "input") control on the TV's remote-control to select either 'HDMI1' or 'HDMI2'.
Dec 16, 2009 | Motorola Televison & Video
Denon AVR-3806 keeps losing video signal. The audio signal is still good. What could be the problem?
If your using HDMI, pull it from the receiver and run directly to the TV, then run optical or digital coaxial to your receiver. It's referred to in the industry as a "Handshake" issue. It has to do with firmware and hardware of your receiver and continuous ridiculous updates from the recording industry to protect copyright. Hope this helps. If you still have issues, post a comment and I will help you troubleshoot further.
Sep 20, 2009 | Denon AVR-3806 Receiver
Can't record out from a digital input
It only passes the signal it see's. Digital for Digital and Analog for Analog. Try running a Standard analog RCA from your Cable box to the receiver then try and record. Hope this helps. If you still have an issue, post a comment and I can help you further.
Sep 18, 2009 | Denon AVR-3803 Receiver
Denon Receiver AVR 1602 not playing Dolby Digital w/ Samsung BD
Dolby signals are passed via either an RF cable or optical link. Both the receiver and player need to have these switched on and that they are passing the correct signals. You clearly found the correct setting for the TV sound link. Now you just have to find the one for the DVD player.
Jun 02, 2017 | Denon AVR-3805 Receiver
How use Tivo on Motorola DCT6412 III?
this works to record progam you watching
1. press menu key
2. highlight DVR button by using either < or > key then press OK button
3. answer prompts
Do this to set up a recording in advance or a series recording
1. Hit the guide button
2. scroll thru channels until you find program you want to record
3. scrool over to red dot press OK button
4.you can the highlight red dot for one time recording or go down one to record every episode. make sure you check the settings for this program.
Hope this Helps.
Mar 19, 2009 | Motorola Televison & Video
Connection/configuration issue: I have a Denon
Just confirming my understanding of your connections :
1). The DVD1800BD output HDMI is connected to AVR3808's DVD-in HDMI.
2). The DVD/VHS recorder output HDMI is connected to AVR3808's DVR-in HDMI.
3). The DVD/VHS recorder input (S-video and L/R Audio) is connected to AVR3808's DVR-out(SVideo and L/R Audio).
Right?
What other inputs have been connect to your AVR3808?
Does the recorder have Component Video inputs?
Please also connect DVD1800BD's output(Component video, S-Video and L/R Audio) to AVR3808s' DVD-in similar inputs and try recording onto your recorder.
Actually, its possible that you may be having a HDMI HDCP communication issue(High-Bandwidth Digital Content Protection) with the source product (DVD1800BD). First check with the source equipment manufacturer for any updates to their products.
If HDMI video is not passing through your AVR3808, you can connect it thru the alternate connection method I have mentioned above.
If the connections/recording still does not happen with the added anolog cables, then let me know , we can trouble shoot it further.
I hope the above helps.
Please do rate this solution and thanks for using FixYa!
Mar 06, 2009 | Denon AVR 3808Ci Receiver
Play phono - vinyl records
You need to purchase a phono preamp (about $20) and then the output of the preamp can be connected to any line level input on the receiver (tape, CD, DVD etc.)
Dan
Feb 25, 2009 | Denon AVR-1602 Receiver
Denon AVR1602
I know the avr 1602 well....What exactly do you mean "I have my TV cable service wired to the Denon".....Do you mean the actual co-ax cable ?....
The denon is only able to switch raw video and audio signals.
What do I mean by that ?....IF you are running your co-ax cable from your cable company directly into the back of the denon, it won't work. The Denon has an AM-FM tuner, but not a video tuner ( channels 1-121)....If this is what you are doing, then you want to run it to your samsung first ( as long as the samsung has a tuner so you can change channels ).
If the samsung operates like an old VCR, whereby you can plug the cable company co-ax cable into the back of it, and change channels with the samsung, then that is what you must do. You would then hook up the OUTPUTS of the samsing to the VCR or DVD inputs on the Denon receiver. ( use DVD inputs on the denon if the samsung has optical audio out, and use an optical cable as well for better sound ).
You would then use the Denon for the sound, and hook up your TV to the Monitor out jack on the back of the Denon.
The Denon is like a big switchbox. You plug your DVD, VCR, Satellite, video game, or what-have-you into the Denon. Then you use the denon to route the signal to your TV for the picture, and the denon takes care of the sound.
Hope this helps, and remember to always follow your owners manual.......Rob
Mar 13, 2008 | Denon AVR-1602 Receiver
Recording out of my Denon
No, if you have nothing on the tape out, there is a problem I'm afraid with the preamp section of this receiver. the tape out should always be on, no mater what mode is being used. Good Luck
Jun 19, 2007 | Denon AVR-3805 Receiver
Sony RDR-GX315 DVD Recorder Logo
113 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
