Question about NexxTech (20-8002) SW/FM/AM Radio
Base mp3 music player Mode:GK915
I cannot get my mp3 player to connect to the computer to sync, it connects but will not show up in my computer at all,, it just has the little hour glass on the screen while its connected to the computer AND when it isn't...I have installed, uninstalled then reinstalled the software, done hardware searches nothing helps... it was working fine before I connected it to the computer! HELP ME PLEASE
  • kittipage Dec 29, 2008
    I can delete .. but cannot add ANY MUSIC .. It is driving me nutty as well.
  • Anonymous Jan 02, 2009
    I know mine will not let me add music to my mp4 im ready to just throw it!
4 Suggested Answers
SOURCE: MP3 player-shows no files downloaded
k the whatever may be the problem i suppose its a virus affected device. format your device in a protected computer and upgrade it using the firmware manager that came in the form of installation cd.(you need internet to upgrade . this will solve the problem i beleive.
Posted on Jul 04, 2009
97F350diesel
  • 1326 Answers
SOURCE: Problem while connecting my mp3 player
Try reinstalling the driver disc for your device, sometimes windows doesn't recognize some devices and some drivers are not pre installed with your windows software. If you don' have them already try going to the manufators website and dwnld. They are usually free.
Posted on Aug 21, 2009
  • 519 Answers
SOURCE: how do you transfer podcast video clip files to my
with Video Download Studio from http://www.downloadvideos-convert.com/download-videos-music can help you with this.
Posted on Jun 28, 2010
I have always been able to sync music on my Sansa MP3 player until today. It wont accept any new music, but the music files are not hidden. When I try to sync the music, it gets about half-way through a...
Freezing up while playing songs Check and see if there is a boot file in any of the folders on the player use the Explorer to check Check both MTP and MSC modes and unhook your player
Recovery Mode: download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa. http://www.youtube.com/watch?v=_95hLqZxCHc&feature=related here is a link to a kid showing you how to goto recovery mode.
Update software from this link..
(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe)
and install the software before you recover
Delete songs and Format (Helps with try to delete BAD TRACKS and folders that will not delete(Some ripped CD folders).. Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works
Jul 01, 2010 | SanDisk Sansa e250 MP3 Player
Philips GoGear HDD6330 MP3 Player will not sync music files onto it? How do I fix that and has deleted all previous ones! Please help>
This could be the player's connection mode in combination with your synchronization software. If you are using Windows Media Player or Philips Songbird to sync, the player will need to be set for MTP connection mode. Most other software that works with regular flash drives will need the player set for MSC connection mode. Whatever you are using, simply try the other mode.
To change the connection mode, select "PC connection preference" in the Settings menu of the player.
If you found this information helpful, please indicate as such.
Apr 12, 2010 | Philips GoGear HDD6330 MP3 Player
How do I download music on my mp3 player? I bought the mp3 player(gpxml638b) and it did not have any soft ware. I have the wire to plug from mp3 to computer, but how do I start downloading music?
Sir,
1. Turn on the MP3 Player by holding the PLAY/PAUSE button.
2. Take the USB Cord and plug the corresponding ends into the MP3 Player and a Computer.
3. When connected the LCD Display will either say “USB” or “MTP”.
4. Press the “M” (mode) button to switch between “USB” and “MTP” mode.
“MTP” mode will only work, when your player is connected to Microsoft
® Windows® XP and Windows® Media Player 10.
The MP3 Player will only work in “USB” mode when it is connected to Windows® 98SE, ME, or 2000 Professional.
1. Start Windows Media Player 9 and connect the MP3 Player to your computer.
2. Click “Copy to CD or Device”.
3. In the drop-down list, on the “Items to Copy” pane, click the play list, category, or other item that you want to copy.
4. Clear the check boxes next to any files you do not want to copy.
5. In the drop-down list, on the “Items to Copy” pane, click the device that you want to copy files to.
6. Click the ‘Copy’ button.
7. Repeat steps 2-5 for any other items that you want to copy to your unit.
1. Start Windows Media Player 10 and connect the unit to your computer. On your player’s display it should say ‘MTP’. If not, then while the unit is connected press the ‘M’ (mode) button to change from ‘USB’ to ‘MTP’ mode.
2. If you have not set up synchronization between your computer
and this device, the Device Setup Wizard starts. In the Device Setup Wizard, select Manual.
3. Click Finish.
4. Select Library option. On the right pane select Sync List.
5. From the left pane you can select the Play list or Library and you will see the content songs in the center pane.
6. Select the songs from the center pane, drag and add them to the Sync List.
7. Click the ‘Start Sync’ button in the Sync List pane.
8. Repeat steps 4-7 for any other items that you want to copy to your unit.
Thanks
Good Luck
Aug 17, 2009 | GPX ML648B MP3 Player
My MP3 player won't connect to my laptop
Open up your windows media player on your computer and select the sync tab on the upper righthand side .Plug In your MP3 Player and now It should be recognized there on the right pane window when you use the sync feature on windows media player !! Drag your music files from your library to this area and they should sync to your player using the button in the lower right hand corner area . I believe it will say sync or sync device !! Rock and Roll Swampratt200 AAAAEEE!!!!!!!
Jul 05, 2009 | Samsung YP-K5 MP3 Player
Sansa 2.0 gb mp3 player having trouble getting it to
I had the same problem when I connected to the computer. So I used my friends Labtop definite 2.0 usb. Did you try to update your sansa click on link and download install run connect sansa when asked.
this has the manual also Make sure USB mode is MSC I use my computer to drag and drop my music from my music folder to the sansa media folder.... Open my computer click on folder what ever folder has your music in it and drag to media folder and drop (click on the (+)where it say's sansa ) easier not to sync
I hope this works
Apr 19, 2009 | SanDisk Sansa E280 MP3 Player
Not enough space for music db. Please free 6 MB.
If you have formatted there is no music on the player. You will have to re-sync any the music. Set the USB mode to MTP, then Use Windows Media Player 10 or higher to sync player.
http://www.sansaworld.com/
http://www.sansaworldmp3.com/
Apr 03, 2009 | SanDisk Sansa e260 MP3 Player
My mp3 can't boot
Try recharging it again on the PC, and ensure the power switch on the player is ON while charging
Dec 11, 2008 | Samsung YP-T9JAB Digital Media Player
A base mp3 player model gk915
I had the same problem with my mp3, i fixed mine by. when you load your mp3 player onto your computer try creating a folder name it something like classic, pop, rock, favorites and then try loading your songs into the folder. I can't promise it will work but that works for most mp3s. hope everything works out! good luck, sam
Nov 11, 2008 | Samsung YP-T9JAB Digital Media Player
New base mp3 digital music player gk915
Have charged for the recommended time. Battery shows as full. Can only turn mp3 on when its connected to usb. When not connected to usb it wont turn on.
Jun 28, 2008 | Audio Players & Recorders
Can't sync bigpond music to Base MP3 player
I have a Base Digital MP3 Video Player, Model GK902. Can you tell me which video format it supports. I have uploaded WINDOW MEDIA AUDIO/ VIDEO files in it, they are not appearing in the folder in which I have stored
sanjeev kapoor
sanjeev_8421@yahoo.com
Apr 12, 2008 | Audio Players & Recorders
NexxTech (20-8002) SW/FM/AM Radio Logo
Top NexxTech Audio Players & Recorders Experts
Josh Whitehead
Josh Whitehead
Pieter Vleeshouwers
Pieter Vleeshouwers
Willem.
Willem.
Are you a NexxTech Audio Player and Recorder Expert? Answer questions, earn points and help others
