Question about Olympus WS-100 Digital Voice Recorder
It keeps telling me i only have 40 min of record time, where are the 27 hrs?
I have erased all the files and it still tells me 40 min remain when i want to record. i have not been able to record some key speeches. what should i do?
  • royozanne Jan 08, 2009
    I have the same problem, but it tells me that I only have 39 seconds of time remaining. I reformatted the recorder, but still the same problem persists.
    I submitted this 10 days ago and paid 9.95 for premium assistance, but I have heard nothing.
Hold down the 'Menu/Folder' button until it flashes "menu". Then press fast-forward until you get to "FORMAT". Press play, then it will say 'no'. Press FF to get to 'yes' and press play again. You'll have to do that twice, because it will ask you if you are sure.
It worked for me...
Posted on Mar 05, 2010
    President:
  • 919 Answers
Sounds as if you need to format the memory of the device. If you go to the menu and to the format option this will clear all data from the device and bring it back to factory defaulted settings and ready to record again.
Posted on Dec 15, 2008
Why a low remain record time on zoom h1 handy recorder when .wav setting in use?
when you record in .wav format, the files ARE better quality, however, they are ALOT larger than a standard .mp3...if you can't tell the 'loss in quality', i would suggest to keep recording as .mp3...but if a .wav is preferred, then i would suggest upgrading the SD card. ..hope this helps.
May 23, 2014 | Music
We have our timers set to record only new episodes but it trys to record old ones all the time. They say clearly "original air date ___". (there are no actual blanks fill in whatever date there). Also we...
when you select "new episodes" it will record ALL episoded that have not been recorded already. ALL episoded will record every time the show comes on. as far as then 134 hr recording, it sounds like a manual timer error i would erase it and monitor progress to see if it does it again.
Sep 23, 2009 | DISH Network ViP 612
Timers & recorded events erased
Ocassionally these receivers have been known to do this. It is not an issue that normally repeats itself however it is very frustrating. The upside is it ussuaaly will result in 150 hrs of record time. If you did not receive the150 hrs delete all timers and recording and reboot the system. You should have the 150 hrs once it comes back online. Thanks for using Fix Ya.
Aug 02, 2009 | DISH Network DVR-625 DTV Receiver /...
Olympus VN-480 digtial recorder - can't get my files to play back
if the power is interupted or improperly unplugged from the computer, the files may be corrupted... try to play the files and while playing move them to another folder... this may get your files back... else you will need to clear the recorder by pressing stop and erase at the same time for about 3 seconds.
Jan 19, 2009 | Olympus VN-480 Digital Voice Recorder
Recording Length Not As Indicated
Hi. Yeah, RCA soutions are worthless. What happens is that the hard disk loses recording time while in use. Like a hard disk losing clusters on a computer and making them unusable. To get that recording time back, you will need to reset the unit. To do this, go to the main menu, press and hold the play and open buttons on the front pannel for about 7 seconds. This will reformat your hard disk. Keep in mind that reformating will erase all data. I have looked up and down for some type of firmware/software update and RCA support told me to disconnect the unit..press the power button 10 times and connect again!!???!?!? How silly. Hope this helps :)
Jul 24, 2008 | RCA DRC8052N DVD Recorder
Saying it only has 59m18s mins left...but its empty!!
format recorder and it will clear all files including corrupted ones... try to safely remove hardware before actually unplugging the device from computer
Apr 13, 2008 | Olympus WS-300M Digital Voice Recorder
Lost time/inaccessible files on flip
This may sound risky, but I did this and my Camera is working perfectly again... If you don't have any videos on it you need to salvage too badly this should do the trick.
1) Plug it in (obviously)
2) Go to My Computer and right click your video camera
3) Click Format
4) I clicked restore device defaults because it sounded safe (but may not be necessary)
5) Click start and begin the reformatting
After this i went from my incorrect 27:11 min. remaining on the camera to the full 60. Still records perfectly and the software is still on it and works correctly. Hope it helps some of you out there =)
Mar 09, 2008 | Pure Digital Flip Video Ultra Camcorder
Recording Time
I have one of these recorders, I actually have 4 or 5, since discontinued I believe, and one is stuck at 43 min remaining.
I think that problems start when you remove the battery while
the recorder is / was in the process of recording (or in play mode) I now press stop while recording before opening the battery case to switch a battery
Mar 04, 2008 | Olympus WS-100 Digital Voice Recorder
Erasing Files
when you copy the files to your computer the files are still in the ws-100, you have to erase them in the ws-100 buttons after that.
Feb 29, 2008 | Olympus WS-100 Digital Voice Recorder
Recorder says "PLEASE DOWNLOAD FILES," but there are no files to download
The DS-2 has a format option in the menu under submenu. After you choose start you will see a progress bar and it should return to full record time. Use on a MAC seems to cause the reduced record time more often than on a PC.
Dec 11, 2007 | Olympus DS-2 Digital Voice Recorder
Olympus WS-100 Digital Voice Recorder Logo
237 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
