Question about Motorola Mobility E550 Cellular Phone
How do I get inside the E550 to clean the keyboard?
I have unscrewed the 4 screws, but can't lever off the back to get at keyboard. What do I need to do?
Take off any tabs or stikers sometines there is skrews under them and also somtime forse helps
Posted on Oct 19, 2008
A LOOSE BATHROOM SINK HOT WATER HANDLE
Is it the whole tap or just the knob/lever?
Whole tap, there is a nut underneath that needs tightening. Don't over tighten it.
Just the knob or lever that you turn to turn on and off? You will find a small screw at the rear. It is a set screw, so it doesn't have a head, it just sits in a hole. Usually a hex key to tighten it. The hole is often filled with gunk so clean it first with an old toothbrush. The set screw is often sticky so undo it I turn before you tighten, lift the knob off, screw the screw in until you see it coming out of the inside to clean the threads. Unscrew the screw back out, replace the knob and tighten it.
Oct 10, 2015 | Plumbing
Keyboard replacement
Unplug the laptop's power cord from the wall outlet and remove the internal battery pack. To remove the internal battery pack, simply locate the release button on the bottom of the laptop. This button needs to be held in while the battery pack is slid free from the computer. This button locks the battery in place, so if it is not held in the battery pack will not be able to be removed. Unscrew all of the screws from the bottom of the laptop. All laptops have different amounts of screws holding the external case together; however, there is usually one screw at each corner, and then one or two screws in the center of the laptop. Once all the screws are removed, slide the laptop's hard drive from the computer. The computer's hard drive will generally be located on the left or right side of the laptop; there will be a small symbol engraved into the laptop to denote its location. Remove the screen from the body of the laptop. To do this, remove the two screws from the back of the computer that hold the screen's hinges in place. Once the screws are removed, pull up gently on the screen until the two pegs that held the screen up have cleared the holes in the laptop's body from which they rested. There will be two wires that lead away from the laptop screen so make sure not to pull up so far that they become disconnected. Step 4 Separate the two plastic halves of the laptop's external case to expose the computer's internal components. Lift up on the keyboard pad and flip it on its face. You will notice a film-like strip that leads away from the keyboard and into the heart of the laptop. Before you can remove the keyboard, you must unscrew the metal piece that covers the computer's motherboard. This piece takes up the majority of the inside of the computer, so it will be very obvious to you when you are looking inside the laptop. Disconnect the keyboard connection after the metal covering from Step 4 has been removed. To remove the keyboard, follow the film-like strip back to where it connects to the computer's motherboard. The end of the connection will be held down by a small plastic tab. Pull up on this tab to release the keyboard connector and simply lift the old keyboard out of the laptop. Connect the new keyboard to the laptop. To do this, simply stick the end of the new keyboard's film-like connector inside the plastic tab that you released to remove the old keyboard. Push the tab back down so that it holds the end of the new keyboard's connector in place. Reassemble the computer by putting the components back in the exact spot you removed them from.
http://www.laptop-repair.info/laptop_keyboard_repair.html
Jan 20, 2013 | Computers & Internet
How do I remove the keyboard from a HP pavilion laptop dv4264eb?
Please look at the support like for youn model. There is a link to download the service manual for your machine. It should show you the screws on the back that you need to unscrew to remove your keyboard.
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=3674080&
May 01, 2010 | HP Pavilion dv4000 Notebook
Keys Sticking
no! you don't want to do that if you unscrew the back plate all the plastic suction cups with fall off and you will never be able to type on it, until you place the suction cups back what you want to do is get some WD-40 (the tool for fixing almost everything) or a can of pressurized air with a areosole top and aim it at the key or under it, press it and it will blow every piece of junk under the keys cleaning it.
Feb 09, 2010 | Logitech Wireless Access Duo Optical...
Need help opening up back of Aspire 5570Z
Yepp, you need to separate the keyboard. You do that by remove the screw behinde the hinges. So dont pull out the screws under the laptop. When you removed the screws from the hinges, pull the keyboard up and backwards, be care, its all plastic and very very easy to breake.
Good luck
Dec 11, 2008 | Acer Aspire 5500 5570-2609 Laptop
Laptop Buttons clean
Turn you laptop upside down, you’ll find a few screws with a symbol that looks like a keyboard.
Unscrew these screws(and ONLY these).
Turn it again, open, and find about 4 "slides" in between the F-buttons. Slide them toward the front and lift the keyboard up from the F- buttons. Be careful not to break the thin film. The film can be lifted from the seal, again with care.
Unscrew all the screws keeping the keyboard together.
Then clean, and know why you shouldn’t drink and drive at the same time - sorry that’s in a all together different area :-)
Regards
Teis -> don’t forget to vote, - thank you.
Dec 08, 2008 | Toshiba Satellite A205-S4617 Notebook
Gateway 4530 keyboard replacement
You don't have to take off the bottom.
You need to take off the panel right in front of the screen
1. Pop off the strip in front of the keyboard.
2. Unscrew the 3 screws.
3. pop off the panel that has the startup button on it.
4. Take the keyboard and put in the replacement.
5. To put it back together.
Oct 22, 2008 | Gateway 4530GZ Notebook
My Krups model 288 toaster won't always latch down.
You can fix this yourself by following these instructions. Unplug your toaster before proceeding!... Clean the toaster first. Turn the toaster upside-down and shake out the crumbs. Remove and clean the bottom crumb tray. 1. Unscrew the four Phillips head screws located in the corners of the bottom base. Remove the screws completely if possible. Do this over a cloth or newspaper - that way a stuck screw won't get lost if it falls out later. 2. With the toaster right-side up, pull off the wide toast lever knob. Do not remove the round adjustment knob (it will not come off from the outside) but make a mental note of what number (1-7) is showing at the knob's adjustment mark. 3. Carefully pry up the end of the case cover with the knob on it (don't pull on the "stop" button). When the knob's plastic shaft is clear of the circuit board, gently pull off the cover. 4. On the inner part of the circuit board you will see a black plastic "cam" surrounded by two sets of electrical contacts. Rotate the cam to open the contact points if necessary. Insert a thin nail file between the points and rotate the cam to trap the file between them, then scrub back and forth several times to clean the contact points. Do this for each contact on both sides of the cam. When finished, rotate the cam clockwise so it is all the way back down to it's original position. 5. To make re-assembly easier, remove the round adjustment knob from the cover by depressing the half-round shaft flanges inside the cover with your fingernails. 6. Re-assemble the toaster by reversing steps 1 & 2. Replace the knobs, making sure that the round one is in the same position you noted earlier before you push it all the way down.
Mar 27, 2007 | Krups 288 SensoToast Compact 2-Slice...
Motorola Mobility E550 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
