Question about Jenn-Air JED8230 Electric Cooktop
Jenn-aire downdraft electric heating problem
I have changed elements and had an electrician out to check why the unit only heats to 273 degrees. The electrician assures wiring is correct; and changing elements has the same results. It acts lik some type of thermostat problem. Sears came out and said all is well.
Any ideas? I am ab out to replace the unit with gas to get spme heat.
Thanks.
peele@vaforklift.com
Eddie Rentas
  • 59 Answers
SOURCE: downdraft vent on jenn air cooktop
Hello
Just get a dryer vent tube the flexible ones and some aluminum tape and that will do it, I had the same problem and thats how the gas company told me to do it and it works excelent.
Eddie Rentas
Tupper Lake NY
Posted on Jul 26, 2008
aborcass
  • 2651 Answers
SOURCE: JENN AIR GLASS TOP REPLACEMENT
the glass top replacemnt is a pretty straightfoward task, a matter of unscrewing one and repalcing it wiht anew one. after ordering new top its a matter of lookin g at eh new top to see which screws would need to be removed from old. hardest part about job will be youll need to do disconnect the downdraft from the venting ,and pull unit up from the counter inwhich it is installe.< not difficult but cumbersome and awkward to manuver. check abd verify full model and serail number and cal manufacture for correct part umber. may cast anywhere fom 200-400 dollars depending on model
Posted on Nov 04, 2008
RescueTech
  • 145 Answers
SOURCE: JENN AIR WALL OVEN ELECTRIC
Are you sure the breaker didn't trip on one side? If one leg of the 220 is out, the lights and controls will appear to work, but the elements will not heat up. Make sure you have 220 to the appliance. It's also possible that you pulled a wire off somehow when changing the broil element.
Posted on Dec 12, 2008
jtbjtb
  • 135 Answers
SOURCE: jenn air glasstop
As long as the pan bottom is truly flat, you sure can. Hope this helps!
Posted on Feb 17, 2009
  • 13 Answers
SOURCE: constant heat not produced on Jenn Air Schott Ceran stove top
It's a piece of ****, replace it the first chance you get.
Posted on Apr 29, 2010
Right front burner fails to heat (at all) Jenn air
I suspect a faulty element or electrical connection to the element.
Mar 21, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
All 4 elements suddenly won't heat--worked fine this am. Circuit breaker was tripped. Reset, now lights on knobs come on, but still no heating.
Likely a short in the junction box. Turn off the breaker and open the junction box for inspection. Problem is likely at the cooktop end of the feed from the breaker.
Check voltage at the junction. Should one side of the corcuit be dead, turn off power and call an electrician as the wiring probably has had a short due to staple or nail penetration and would be a fir hazard. Call an electrician if this is the case.
Jan 12, 2010 | Jenn-Air JED8430 Electric Cooktop
Constant heat not produced on Jenn Air Schott Ceran stove top
Dec 26, 2009 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air Cooktop replacement needed
You can get a new cooktop surface from Maytag/Jennair for $229. It is a pain however to replace it. Where is the crack in your cooktop and does that crack pass directly through a heating element? If not, then you may be able to repair it. I broke the corner off mine, and then dropped the piece (now 5 pieces). I was able to bond them back together and you really can't tell it was ever broken. But, it takes some work.
Apr 11, 2009 | Jenn-Air JED8430 Electric Cooktop
Dec 12, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Nov 04, 2008 | Jenn-Air JED8430 Electric Cooktop
Downdraft vent on jenn air cooktop
How do you get the inside area of the vent clean from the grease and oils where the filter is?? I have a rectangular box style downdraft that the vent goes into the floor, I pulled the filter, but the box is to slender to get an arm into to scrub the grease....... does the bottom come off, or is it a sealed unit? How do you get all the brease from the bottom if you cannot reach it?
Jul 09, 2008 | Jenn-Air JED8230 Electric Cooktop
Downdraft Slide-In Range
I have the radiant cooktop (i.e., glass top) version of this range. I've had this same problem since I first purchased this unit. I wondered why no one answered this question, as I check back to see from time to time. I finally contacted Jenn-Air's online support. My conversation was as follows (I'm not entirely sure that the tech support knew what she was talking about, but here you go anyway):
message.gif?p_db_name=whirlpool Cidalia C: Hi, my name is Cidalia C. How may I help you?
message.gif?p_db_name=whirlpool You: Hello!
message.gif?p_db_name=whirlpool You: I have a question regarding my "Downdraft Radiant Cooktop"
message.gif?p_db_name=whirlpool Cidalia C: Thank you for contacting Jenn-Air today with your inquiry. What is your question please?
message.gif?p_db_name=whirlpool You: None of my burners can simmer-- no matter what the setting, they will boil water!
message.gif?p_db_name=whirlpool You: Is there an adjustment that can be made to attenuate the heat?
message.gif?p_db_name=whirlpool Cidalia C: What is the model number of your cook top please
message.gif?p_db_name=whirlpool You: JED8430ADB
message.gif?p_db_name=whirlpool Cidalia C: Thank you. In looking at your burner configuration, the smallest wattage on your unit is 1200. And, unfortunately, there is no way to get a small wattage for your burners. We apologize for the inconvenience.
message.gif?p_db_name=whirlpool You: Yes, but the dials are supposed to prevent the full 1200 watts from reaching the burner unless it's on maximum heat, correct?
message.gif?p_db_name=whirlpool Cidalia C: Yes, but the burners do not get low enough to be considered simmer burners.
message.gif?p_db_name=whirlpool Cidalia C: Did you have any other questions or concerns today?
message.gif?p_db_name=whirlpool You: I suppose not.
message.gif?p_db_name=whirlpool Cidalia C: Thank you for contacting Jenn-Air. Have a good day!
Jul 08, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8230 Electric Cooktop Logo
89 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
