Question about Baby Gear
Instructions on how to instal a second hand safe-n-sound car seat
Borrowed from a friend of a friend not sure how to fix it into the back seat forward facing. We have the strap fixed to the bolt at the back but where does the lap seat belt go to ensure the bottom section is fixed to the seat securely and how do shoulder the straps go. Unfortunately they were removed by someone to wash the cover and weren't put back. Unable to tell from instructions as they have been torn from the car seat. It is a safe and sound model that changes from back facing to front facing.
How do i put the straps back on through the cover
Posted on Aug 03, 2009
2 Suggested Answers
SOURCE: shoulder straps will not extend
In between were her legs are there is a cocso sign push down on the button and pull the strap tight. A black strap should be handing out from under the button.
Posted on Jan 04, 2009
Power seat won't recline
Sounds like the motor and gearing has worn out, they take a lot of punishment. Replacements are available (sometimes it works out much much cheaper to buy a whole second-hand seat). But that depends how much you like the car...
Dec 04, 2014 | 1994 Oldsmobile 88
I have a dell vostro 1720, while booting up, you can see the home screen for about 2 seconds, then goes white screen and you can't see anything. tryed starting in safe mode, and got the same thing
This could be a virus.
The quickest way to fix this problem is to use your Dell recovery CD.
Boot up with this recovery CD follow the instructions and it will restore your Dell laptop. You will lose your data and you will need to install your programs again.
Mar 25, 2013 | Dell Vostro 1720 (bqcwd1z) PC Notebook
I have a second hand rear facing maxi cosi car seat and need to find out how to install this properly? Please send me instructions or installation guide etc.....
Hi Vanessa - We cannot recommend you use a 2nd hand carseat for exactly this reason. A carseat fitted with a 3 point seatbelt requires a physical fitting from a trained member of staff prior to purchase to ensure suitability, and to demonstrate to you how to correctly install it in your car to ensure your child is safe. Please attend an authorised retailer and ask for a carseat fitting from a trained member of staff to establish the most suitable carseat for you and your vehicle and to ensure you know how to fit it correctly.
Apr 18, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Can i place the car seat facing front?
Hi - If it is an infant carrier Group 0+ carseat it must never be installed facing forwards. It is designed as a rear facing carseat to keep your child safe in the event of an accident. Always install a carseat according to the instructions.
Feb 21, 2011 | Maxi-Cosi 22371HFL Infant Car Seat
Hi we have a second hand Britax rock a tot car seat, can you please advise the age group of the infant to be able to use this car seat?
it does not go by age, it is based on height and weight.
Rock A Tot is not a recognized name on their website of current or retired models.
http://www.britaxusa.com/
It is a model from the UK-
Weight/Size Suitability
------------------------- The Rock-a-Tot is a group 0 car seat, suitable from birth up to 13kgs (around 9-12 months). It uses a three point harness. For a newborn this seat is lovely, the head hugger makes the seat very snug and secure around their head. However I did find that as my baby got older the head hugger seemed too confining and we removed it when he was about 4 months old.
The shoulder straps can be adjusted to 3 or 4 height settings allowing a good fitting as you baby grows.
Although this seat is designed to go up to 13kgs I think that most people chose to move their baby out of this seat when he/ she reaches 9kgs and put baby into to a forward facing seat. Adrian was a large baby to start with (9lb 9oz) and also long. By the time he had reached 9kg's (around 7-8 months) his legs had to be bent slightly with his feet touching the back seat which we didn't think would be very safe in an accident (as surely more pressure would be placed on his legs if the car seat moved towards the fixed seat)and he was getting rather squashed in to the seat.
Feb 06, 2011 | Britax Baby Gear
Rear passenger seat belt stuck forward. any way
Probably not you can try to get it to pull back in by pulling on it but of course i am sure you have tried this. The belt will need to be replaced. If you would like contact me and i will get you a good deal on the belt and installation instructions if you are wanting to do the repair yourself.
Thanks,
Chris
Nov 21, 2009 | 2000 Toyota Camry
How do I install a forward facing car seat?
Instructions should be on the child seat. where I live , you can take your car to the fire hall and they will check it to ensure that it is properly installed and safe.
Nov 05, 2009 | 1999 Mercury Cougar
Cant fit nania first car seat
We just fitted our 'new' secondhand narnia yesterday with instructions and it was a bit of a fiddle, but once in was very secure. Place the lap/diagonal belt through the slot in the back so that it comes out the front, it then goes over the arm rest, back through the other slot, across the back of the seat, then through the slots in the other side over the arm rest again and click it in.
May 15, 2009 | Nania Dreamer LX
Hi, I am looking for the manual to go with an Eddie Bauer 22-756
Go to the eddie bauer website, search for your model, by date it was made and model type, and u can download the manual
May 02, 2009 | Eddie Bauer 22757MRC Convertible Car Seat
Child car seat - unable to put it back together after washing
You need to pass the belt behind the sit.
Mar 21, 2009 | Baby Gear
Baby Gear Logo
2,256 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
