Question about Sylvania SRPD442 42 in. EDTV-Ready Plasma Television
TV goes on for minute, and then goes to standby
I have a Sylvania SRPD442 when I turn it on for a minute it goes to standby mode, what you think the problem could be?
  • 1 more comment
  • _Ram_ Jan 09, 2008
    I have the same problem. When it first happened I turned the cieling fan on in reverse as to allow the air to sweep behind it. It didn't do it anymore for about two weeks. Than that didn't work anymore. A sevice man said it was the power supply. The cost of the repair was in the neighborhood of $1K. I declined the repairs and came here for help. What kind of voltages are you talking about? Is there a concern when the unit is unplugged? Is it possible that a relay overheating could be the problem? Please respond. Thank you.
  • jtservices Jun 08, 2008
    The problem you describe is on the pcb labeled "pkg-1720"
    the yellow transformer marked ec1180 in the lower center of the board
    about a $10 fix
    Just try to find one......not going to happen in this lifetime, I've been trying for a couple of weeks
  • Anonymous Mar 25, 2014
    keeps going off
  • 1,476 Answers
This could be anything but is more than likely a problem in the power supply or control board. There really are not any user serviceable parts in these units and they have dangerous voltages. Repair is best left to a professional.
Posted on Jun 28, 2006
I have a sylvania flat screen 46 inch TV and will not turn on. It stays in standby mode. Any quick fix?
Do a hard reset to this set, and check. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If it do not help you, check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 07, 2015 | Sylvania Televison & Video
Won't turn on led flashes green 8 time
Sounds stupid but I've had this issue with 2 different brand TV's and I unplug them for 5-10 minutes and then they are fine. I just had this happen just a week ago with a TV again.
Jul 14, 2014 | Sylvania 6842PE TV
My sylvania tv is stuck on standby
This is due to a bad power supply system which consist of an electronical board with capacitors on them that burn out.
Jun 18, 2012 | Sylvania Televison & Video
When you start light turns green but go's back to red . sylvania 6842thg
DOES THE TV STAY ON ??DOES IT TURN OFF?...MOST CASES IS A FAILURE IN ONE OF THE POWER PROCESSING BOARDS..WHICH MEANS THAT HAS TO BE REPLACED..
Mar 18, 2011 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Insignia 37" goes into standby mode
I am experimenting with Insignia's and there is a feature whereby if a signal is not detected the TV will switch to standby mode (in about 10 - 15 minutes). It's documented as a tiny "note" in the manual under "Understanding the basics - Turning TV on or off"
I don't know if the TV resumes when the signal is restored or if you need to power on manually.
You are probably experiencing a glitch with the signal or the TV thinking the signal is not there. Are you watching a clear picture when this happens? I would first check to see if the signal is too weak (like using a signal booster). If that is not the case, it's probably the TV acting up.
I hope this helps.
Is this
May 26, 2009 | Insignia 37" LCD Flat-Panel HDTV
SRPD442 TV WILL NOT DISPLAY PICTURE AND WILL NOT SHUT OFF
This can be many types of faults. The set will need shop service. There may be cold solder connections on one or some of the boards, or there may be come components that are intermittant. In anycase most of the time, there will be the need for board replacments.
The cost for this type of repair can be fairly expensive. I would consider investing in to a new set because after having this serviced, there will still be many older components in the set that can potentialy fail.
Jerry G.
May 22, 2007 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
in this model, the ribbon cable conection fail many times, and tis sound to be the problem, just open it and secure all sokect conection better get a tech to do it ...good luck
Aug 09, 2006 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Sylvania SRPD442 no picture
Your problem is probably in the power supply as theres a voltage called the sustain voltage that is always keeping the screen charged so the address lines will activate the screen and make it light up Via the Microprocessor and the video processor. This is not a repair for a handy person as this set, you can cause more problems Please seek out a trained tech for this set. Good luck
Jul 24, 2006 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Sylvania SRPD442 42 in. EDTV-Ready Plasma Television Logo
586 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
