Question about Samsung LNT3242H Television
Samsung LN-T3242HX LCD TV
Hi welcomejee,
Samsung LN-T3242HX lcd tv. When I first got the tv the screen would play a tone and the screen would flash blue for about one second and then go blank. I took it apart to find that one of the ccfl's had broken inside the screen. I replaced the ccfl today and now it does nothing except the red light flashes in the front. So it did light up for a second with the broken ccfl, but now not at all with the new one installed? The person that had the tv before me cut the ground wire off of the plug that goes to the wall, and when I use a new plug the power seems to be stronger on the board and not as strong with the old cord. I am trying to determine if it is a power supply issue? or if maybe it is the inverter? Can you tell me what to check to find out? If it is the power supply, do I need to buy a new board, or can I replace components? I appreciate any help or directions that you can give me! wow that is alot of
Thank you in advance for any help!
  • 1 more comment
  • compgeek09 Oct 19, 2008
    Thanks Welcomejee! I was thinking the same thing about the connector, but was not sure that I wanted to open it up again:) When I soldered the ccfl, I should have checked the connection better! The connections seemed tight? Do you know of any way to test solder joint while not hooked up, before I put it all back together? The one side of the ccfl has a wire attached and the other side connects to a small circuit board. I did check all the boards and connections, and I know they are right because I took pictures on dissasembly :) Thanks again for your help, and let me know if you think of anything else. I will keep you updated to the fix.
  • compgeek09 Oct 20, 2008
    Well I opened it up again, and resoldered the ccfl where it goes into the board. Still no luck. Does the ccfl actually have to be touching the lead on the board? or would the solder carry the current if was not right up against the lead? I am almost positive that it is making connection on the board, but I am no guru at soldering techniques. Would any of the ccfls light up if that one is not making the connection? Do you know of any way to test the ccfls while they are out of the unit? Thanks for all your help!
  • compgeek09 Oct 21, 2008
    Did you get my e-mail?
  • 10,594 Answers
Hi Compgeek09
Please check CCFL is hooked in connector properly, all connectors of back light inverter board are plugged correctly, check also other connectors of removed boards while CCFL replaced.
It doesn't seem issue of back light inverter board nor its related to ground wire of power plug to wall because tv was working before replacement of CCFL.
Posted on Oct 19, 2008
  • Shahid Electronics
    Shahid Electronics Oct 20, 2008
    Can you post disassemble pictures of CCFL or you can email me as you already know my email address ;)
    I want to see the situation to understand whats happening there.
    Shahid Electronics Oct 21, 2008
    yeah, I got your email and will reply you soon. Thanks.
    few pics are out of focus, specially solder points.
Greenish tint
Might try the color tones buttons on T.V. up or down.
Oct 13, 2013 | Samsung LN-S1951W 19 in. LCD Television
Blank screen Samsung LN-R409D, audio when turning on and off and blue light at power button in on position???
Hi there
Im afraid this sounds like a fault with the TV. Try turning it off at the wall for 3 minutes, and then with nothing plugged into the TV, turn it back on. If the problem persists contact the manufacturer.
Hope this helps
Jan 03, 2011 | Samsung LN-R409D 40 in. LCD Television
Samsung ln-t4053h 40in lcd will not power on
my samsung when switched to the hdmi inputs comes up with a box saying not supported mode?? how ever shall i play my ps3 now?? can anyone help??
Feb 08, 2010 | Samsung LN-T4053H 40 in. LCD Television
Blue screen
Did you see the back light at the back. If yes, the problem may come from T-Con board. Try other source like playing DVD AND If THE SAME PROBLEM HAPPEN, you may think of the main board defective.
Aug 15, 2009 | Samsung Televison & Video
Red dots across the screen
Please check the power supply board, if there is any Pup-Up electrolytic capacitors, please replace them.
May 25, 2017 | Samsung LN-T4665F 46 in. LCD Television
Sound problems
Sounds like there is a bad solder connection inside the set and needs to be looked at by a tech. The Flashing LED usually will be a code for the tech to send him in the right direction as to the problem. Try counting how many times it flashes and call them or manurfacture. hope this helps
Apr 01, 2009 | Samsung LN-S4051D 40 in. LCD Television
Cannot view tv program while recording on VCR
Hi and welcome to FixYa,
Initially, pls set the Samsung LCD TV to the Source selection as if watching a playback evgen if you are going to do a recording.
If that does not work, pls postback manner of connection (cabling) from Cox digital cable system to Philips DVD/VCR to Samsung LCD TV LN-T3253HX/XAA .
Good luck and Thank you for using FixYa. Happy Holidays.
Nov 15, 2008 | Philips DVP3345V/17 DVD Player/VCR
Samsung LN-T3242HX
Hello Compgeek09,
It appears that one of the CCFL lights might have broken behind the screen and that is why the TV would turn on for 1 second and goes off after.
The noise you are hearing could peaces of shattered or broken light and you would have to remove the screen and to be able to fix it, if you are up for the challenge.
Let me know if you required further assistance.
Jun 11, 2017 | Samsung LNT3242H Television
NO sound on HDMI3 port and when playing Blu-Ray DVD's the screen is pink
Go to the samsung website, and find out how to upgrade the firmware for your TV. You will probably need a portable usb memory stick to do so (if your TV is equipped with one). HDMI is an evolving technology, and firmware upgrades can resolve many of these quirky issues.
Here's a possibility from
Which Samsung LCD TVs Have The HDMI 1.3 Interface? spacer.gif Of the LN-T series Samsung LCD TVs, those models whose last two digits are 61, 65, 66, 69, 71, or 81 (for example, LN-T4071F or LN-T466F) have the HDMI 1.3 interface.
Samsung LCD TVs with HDMI 1.3 interfaces also have HDMI-CEC (HDMI - Consumer Electronics Control). For information about CEC, click HERE.
For information about individual Samsung LCD TVs with HDMI 1.3 interfaces and HDMI-CEC, click HERE. When the Samsung LCD TV web page appears, select the TV model you want information about by clicking the drop down list under Product Finder on the left side of the page.
Though other series of Samsung LCD TVs (LN-R, LN-S, etc.) have HDMI connections, none have models with the HDMI 1.3 interface.
Feb 18, 2008 | Televison & Video
Blue/black vertical line in the middle of screen
Sounds like a bad connection on a ribbon cable or plug comming or going to the LCD display. This is something you should not try to fix as these circuits are very very fradgile and you can easily break or tear a ribbon cable . Call the manufacturer to get a tech to assit you. Good Luck
Aug 06, 2006 | Samsung LN-R328W 32 in. HD-Ready LCD...
Televison & Video Logo
390 people viewed this question
Jerry Greenberg
Jerry Greenberg
