Question about RCA HD52W56 52" Rear Projection HDTV
RCA REAR PROJECTION 52inch 1999 model
My picture gets to where it looks like there is something interfing with my tv but when i move the tv or twist the coaxal where it is screwed on or push the piece where the coaxal is screwed on it gets clear again i,m wondering if it,s the ground in the tv somewhere
    Genius:
  • 1,605 Answers
Get a new cable. the connector on the cable is bad.
the center pin of the cable connector is the signal carrier, and the outer jacket is the ground. so if wiggle the cable and the cable and the pic become clear, then it is definitely is the cable.
Posted on Oct 20, 2008
My rca 52inch rear projection tv would shut off then come back on know it won,t come at all is it possable it is a bulb help wayne
this model does not use a bulb, but has 3 picture tubes. Most common problem for this is bad solder connections under the high voltage transformer.
Nov 29, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hi my name is Robert I have an rca 52inch tv model# d52w20byx1. The tv gets power no picture or sound. Can you give any suggestions
jaxff85,
I certainly can. I have a tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting which will walk you through the troubleshooting process and help you pinpoint the problem.
Thanks for using FixYa and for the great rating.
hardrocko
Apr 28, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
When i go to turn on TV the green light blinks 3 times and that is all it does- its an rca 52inch projection
You have lost the high voltage section and the high voltage module will have to be replace or repair, and you are looking at around 450 on repairs.
Dec 20, 2010 | RCA HD52W56 52" Rear Projection HDTV
52inch rca rear projection power button turns green but tv will not turn on will replacing the capacitors repair this problem
Often it will, But the Flyback transformer is also famous for failing in that Model which can cause the same symptom. Caps should alwasy be tried first with that model.
Oct 26, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I OWN AN RCA 52INCH REAR PROJECTION SCREEN TV...WHEN I TURN IT ON...A GREEN LIGHT APPERARS AND BLINKS 3 TIMES AND STOP...WITH NO PICTURE OR NO SOUND....PLZ TELL ME WHATS THE PROBLEM?...IS IT WORTH...
24.95 the kit is called the CP150, CP114 and CP120 capacitors repair kit listedunder RCA reapair kits at www.tvrepairworld.com The kit contains the capacitors and detailed instructions on CD
Nov 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture (fan& bulb do not come on) but there is sound
I have a RCA 52inch D52w136D, the power button blinks three times, but nothing happens no picture or sound
Nov 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca sound and menu problems
Here at my shop we see this problem with these rca sets. The processor is seeing a command from the keyboard or the ir sensor. The most likely cause is a faulty keyboard cuircit board. And replacing is the best coarse of action. To make sure its the problem I remove the keyboard cuicit board and see if the problem goes away. I just use the remote to control the tv, u can also do this until the part arives To get the part you need to know the entire model number. It will be on the sticker in the back in small letters hd52w56yx1 or yx30 or something to that extint. i get most of my rca parts from union electroncs or just let me know and i can look up the part number for you
Nov 12, 2008 | RCA HD52W56 52" Rear Projection HDTV
Colour separation on rear projection tv
CHECK THE MENU TO SEE IF YOUR TV HAS CONVERSION,,MY RCA 52INCH HDTV PROJECTION,,ITS 4 WHEN YOU MOVE IT OR THE COLOR GETS ALL OUT OF WHACK,,ITLL FIX IT RGHT UP
Oct 05, 2008 | Televison & Video
RCA 52inch Big Screen.
On your remote push "Info" then push right or left to get OFF zoom mode, Cinema view looks pretty good.
Jul 20, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA 52inch TV
If the screen control for the green picture tube is set too high, then the colors will be greenish, there will be green where there should be black and there will be fine curved lines (retrace lines) in the picture. If you feel confident then you can open the set and look for the focus block which has the 3 focus and 3 screen controls. One row is labeled Screen and the green control will be the center one. Try turning that control down a little and see is the green background and curved lines go away. If they do not go away then there is something more serious wrong. If you do not have experience working on projection sets then allow a qualified tech to handle it for you.
Jul 13, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W56 52" Rear Projection HDTV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
