Question about Minolta Maxxum 700si 35mm SLR Camera
Cracked hand grip
I have a Minolta 700si, it works fine but, the rubber hand grip is cracked and falling apart. How can I fix this.
4 Suggested Answers
philipp
  • 217 Answers
SOURCE: Minolta 700si rewind Problems
I dont get it! All I know is that almost all of film cameras rewinds when it reaches the end of film. Find the switch that turns off the autorewind function.
Posted on Sep 01, 2007
  • 685 Answers
SOURCE: I have a Minolta 700si and want to put a MD Zoom
There were years ago, but you did not have auto-focus or metering as I remember. Also there adapter had an optic that was not too good so the lens lost a lot of quality when used. Get an SRT-101 for use with the Celtic lens.
Posted on Nov 24, 2009
SOURCE: my Minolta Maxxum 700si is blinking HELP on the
That same problem popped up on mine about three months ago after I put new film in it. I was only able to get a few shots out of it before HELP appeared in the window. Then everything locked up. I was able to reset the HELP by taking out the battery momentarily, but the problem reappeared. Also, after that, my pictures were mostly blank.
I opened up the back and found that one of the four thin metal shutter "flaps" had popped out and was jammed out of place. I probably snagged it with my fingernail when I loaded the film. I was able to tuck it back in place and now the HELP problem is gone.
Haven't taken any pics yet, but I'm hopeful. BTW, it also fixed my built-in flash, which had stopped working, also.
Posted on Apr 30, 2011
The electric cord on my hand held percussion HoMedic Masager is loose. How can I open it and fix it?
What is the model of your HoMedic Massager?
If it has a rubber grip on the handle, you can take it off by simply sliding it towards the power cord, with effort and a little patience.
Once the rubber grips are off, you will find 1 screw hidden under the grip, 1 screw near the power cord, and 5 screws on the head, take all the screws off.
Once you've unscrewed all of the screws, unscrew the 2 vibrating heads then take the unit apart.
Good luck.
Jul 22, 2014 | Homedics Health & Beauty
Why doesn't my minolta 700si urn on?
Check for battery leakage in the battery compartment. Check the battery contacts. Make sure they are orientated correctly
Jul 10, 2014 | Minolta Maxxum 700si 35mm SLR Camera
What sort of a card goes in to the card slot of the minolta dynax 700si and what does it do if not store images
The cards are known as "Creative Expansion Cards" and add features to the camera. You can find much more information here.
Jan 14, 2011 | Minolta DYNAX 700Si AUTOFOCUS SLR CAMERA...
Phone will not dial certian numbers
Kellie is right on with the keypad repair. We have 4 handsets, for about 2 years now, and are very happy with the system. However, the most used phone started giving us fits with the '3' and the 'off' buttons not working. I washed and dried my iPod nano [in the laundry by accident], and was able to take that apart and get it working again so I thought what the heck-lets have a go at this larger Motorola phone handset. I actually did this before I saw Kellie's post, and after getting most of the phone apart, I decided to do a search for hints-when it felt I was about to crack something. After getting the phone apart, and cleaning it with a Q tip and rubbing alcohol it works perfectly. I considered calling Motorola and "demandimg" replacement handsets, but I am happy to be able to fix it myself. Here is what I did:
1] remove the clip- at first you'll think this thing is frickin glued or welded on, but you actually just need to spread the "wings" on the side of the phone outward, and you'll successfully remove tabs "A" from slots "B"
2] remove battery cover and remove battery-should unclip easily
3] remove 2 screws in battery compartment
4] remove the small plate on the back of the top of the phone just abouve the clip you removed. Use a thin screwdriver and pry from the bottom of the panel, as its like a door that will want to "swing up" and out
5] remove the 2 screws you have now exposed-they are the same size and type as the 2 screws you removed from the battery compartment
6] now your nerve will be tested. You need to seperate the phone into 2 halves- a front and back. As you do this, you will think you are gonna crack either the front or back plate in half. If you can trust us, and understand that the rubber "grips" on each side of the phone are the only thing really holding the front and back together you can win this struggle. Its hard to explain, but the rubber grips on each slide have a number of slots, and the front and back halves slide into these grooves snugly and at a 90 degree angle. You could just grab one end of the rubber grip and yank away like its a zipper, but I didn't do this because I didn't want to stretch or tear the rubber and have the phone look like hell after I put it back together. There are also 3 plastic "clips" one on one side and 2 on the other, but these are nothing. Defeat the rubber grips and these 3 little clip things you won't even notice. So take your time, and eventually you should get the front and back halves of the phone apart from each other and the rubber grips.
7] remove the 2 screws holding teh circuit board to the faceplate. The circuit board should come out easily-be careful with the soldered red and black wires to the speaker. When you take circuit board out it will still be tethered to the faceplate by the speaker wires.
8] take Q-tip and rubing alcohol and wipe all copper contacts and backs of rubber buttons like a wild man [wild woman]
9] let dry [a few minutes], put back together in reverse of way you took it apart- little stubby antenna will possibly fall out at some point, just set it back in when you put two halves back together, then enjoy Utopia as your phone will now work like it did when you first took it out of its stupid box !!!! Any questions? post a comment and I will try to answer them good luck, its really pretty easy ! If sexy Kellie can do it so can you !
thanks
Jul 01, 2010 | Panasonic KX-TG1033S Cordless Phone
My Minolta Maxxum 700si is blinking HELP on the screen
Jun 10, 2010 | Minolta Maxxum 700si 35mm SLR Camera
Motor cycles on and off when trigger not depressed
Simple fix...... There is an O ring on the end of the pressure hose that seals it to the pistol grip that the various nozzle wands fit into. The O ring is either cracked, which may not be obvious with a cursory inspection, or a small piece of it may be missing. The O rings harden over time and crack and then start to fall apart. Just fixed mine in 30 seconds with a free O ring from the hardware store. Just make sure it is of the correct diameter and material thickness and everything will go fine. The O ring should appear minutely larger than the brass stem is sits on.
Jun 05, 2010 | Karcher PSI Electric Pressure Washer
I have a Minolta 700si and want to put a MD Zoom Minolta Celtic 100-200mm lens on it. Is there an adapter that I can get to use this lens and have it fit properly?
Nov 23, 2009 | Minolta Maxxum 700si 35mm SLR Camera
My handgrip is also cracked
There's a phrase which comes to mind: "You're flogging a dead horse".
Your camera is far too badly damaged to even be worth attempting to repair, especially when you consider that it's largely electronic and not like earlier mostly mechanical models. The last working example I saw on an auction website sold for under £60 and a wreck with a severely cracked body (left hand grip) sold in the USA for £7.42 (US$12.08 at current rates). If that's your camera then you can probably sell it for what you paid for it and even make a slight profit if you sell the body cap separately.
I hope you don't think that I've been unhelpful, but I'd be lying to you if I indicated even the slightest bit of hope for your wrecked camera. Cut your losses and buy another
Jul 13, 2009 | Minolta Maxxum 700si 35mm SLR Camera
Minolta 700si rewinding film before its finished
change the gers ,in minolta rhere will be a bule gare wich wok for forwinding the fillm and rewinding .the gare size will be 32.try this or find the gare that drive the all gares
Mar 20, 2009 | Minolta DYNAX 700Si AUTOFOCUS SLR CAMERA...
Apr 15, 2007 | Minolta Maxxum 7 / Dynax 7 35mm SLR Camera
Minolta Maxxum 700si 35mm SLR Camera Logo
64 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
TC CAMERA REPAIR.Com...
Are you a Minolta Photography Expert? Answer questions, earn points and help others
