Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Where????? Where can i find the right battery?
    Problem Solver:
  • 5 Answers
Office Depot, Radio Shack, Walmart online all have suitable battery replacements for less than the Canon brand. The battery number is NB-4L. Circuit City and Best Buy carry the Canon brand as well as other replacement brands. They are the more expensive.
Posted on Oct 24, 2008
Try amazon.com
Posted on Oct 23, 2008
  • 489 Answers
Don't buy a battery for $30 at a store, get one on eBay for $5, they are perfectly good batteries I've been using them for years!
Just search "4L battery" and you will find them easily.
Thomas
Darntoothysam com
Posted on Nov 11, 2008
Hi, this is a frustioning question. How do you open the battery door. I have an instrucation guide, for I can't figutre it out. Beverly
Hold the camera upside down lens to the right. Slide the battery door release button to the right and at the same time slide the battery door away from you.
Aug 29, 2010 | Canon PowerShot SX100 IS Digital Camera
Turns on then right back off like the battery is
I know you mean your kodak easyshare camera battery life is over,and the new kodak battery replacement you buy isn't effective to you camera, it may be a compatibility problem,You should have take your camera with you to test if it is fit.Now you can get some kadak battery information or get from Inernet search engine.
Jun 02, 2010 | Cameras
My kodak z712 is won't turn on. New batteries. The lens extends and then goes right back and off
You say new batteries - does that include the tiny ones, that keep the clock and other internal functions going? If not, check those, too. They are usually located in a different place than the larger batteries.
Also, make sure you put the new batteries in, in the right order.
-a.
May 28, 2010 | Kodak EasyShare Z712 Digital Camera
I have a low battery indication with a fully charged battery on a Sony DSC-F717. What do I do?
First, even a fully charged battery may not be working right - VERY common.
Does the camera do this on two batteries, one old and one much newer? (I say this because lithium batteries are good for about 500 charges - if you are over this, the batteries will always read weak...)
A service shop can test the camera and see if the battery is reading correctly. A service shop may allow you to try the SHOP's good battery in your camera and see if it reads right. If OK, you need a new battery.
The service shop can reload the operating data into your camera - I have fixed them this way myself.
If not, the circuit board that handles charging and batteries may run you $275 plus labour. (The board is not repairable)
Mar 22, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
My camera turn right off when i tirn it on
suspect battery is low.
suspect battery has not charged properly in charger.
suspect battery may be defective.
suspect camera is defective.
i would ask a specialist at a camera store to check this.
Nov 15, 2009 | Sanyo VPC-S1080 Digital Camera
My camera will not turn on
Check to see that you are using the right kind of batteries (NiCad, Lithium, etc) Not just size, but check what knd the camera needs . Some batteries come labeled for 'Photo' or Digital Devices', but are not the right type for your device, so will not work, and will result in odd bhaviors like what you are seeing > not enough of the right juice.
DigiChick
Apr 23, 2008 | Canon PowerShot S3 IS Digital Camera
Fuji Fine Pix Z5 battery won't charge
I looked up this question with the same problem and while the battery was placed in with the right side in, the three metal tabs weren't on the right side with the three metal chargers- so I had to spin it around the other way...i hope i'm explaining this right...now it's charging! I am so glad. This camera is excellent.
Mar 31, 2008 | Fuji FinePix Z5fd Digital Camera
Wont turn on
Only use Ni-MH or AA-size alkaline batteries. Do not use Ni-Cd (nickel-cadmium) because the heat emitted can damage the camera.
I would suggest using e2 batteries from Energizer.
In the manual, on page 80 there is a description and procedure for discharging Ni-MH batteries (but NOT regular batteries, so don't do this with regular alkaline batteries) AND do not do this when the external power is connected.
Moving on... The discharging of the batteries procedure should happen when:
  • the batteries last for a short time after being charged normally
  • the batteries have not been used for a long period
  • the batteries are new.
Follow these instructions:
  1. Press the menu/OK button to display the menu on the LCD monitor
  2. Press the "left" or "right" on the pad to select "SET" OPTION and then press "up" or "down" to select "SET-UP".
  3. Press the "MENU/OK" button to dipslay the "SET-UP" screen.
  4. Press "right" or "left" to move to option 5 and then press "up" or "down" to select "DISCHARGE".
  5. Press "right"
  6. Press "left" or "right" to select "OK".
  7. Press the "MENU/OK" button.
The screen changes and discharging begins. When the battery level indicator blinks red and discharging ends, the camera turns off.
Remember to not have the camera external battery plugged in so the battery can discharge on it's own.
Then, at this point, recharge the battery using the external battery charger. This helps to "renew" the battery. This is because Ni-MH batteries will remember the last place where they recharged, and too many times, the memory "bookmark" gets marked to low and has to be reset, done by the recharge.
It may be necessary to repeat these steps multiple times. This effect is not because the batteries are deffective. This is a normal side-effect of Ni-MH. This is the reason the camera comes with a discharge feature.
I the batteries are old and don't function even after performing the discharge procedure as part of the normal operation of the camera (like of the year or two), then the batteries may have reached the end of their service life.
Hope this helps, if so, please rate FixYa! ThankYa!
Nov 04, 2007 | Fuji FinePix A360 Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
51 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
