Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Picture shadowing and waving pictures
There are shadowing and waving effects on the pictures of my JVC 48W30 CRT projection tv. i checked the convergence button on the menu and saw green + and blue+ only and they're apart form each other, tried to move it manually and only the right side where aligned and the rest can't be move horizontally, vertically yes it can be move but not horizontally.
can anybody help me solb my problem?
  • JVC Master
  • 3,459 Answers
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and picture shadowing and waving pictures - 2c07611.pngeplaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 21, 2009
    Problem Solver:
  • 22 Answers
Replace stk chips
Posted on Mar 03, 2009
Picture fussy, double picture, and both side and top of screen are distorted and waved in
Sounds like convergence problem. Fixing the problem requires removing, desoldering and soldering the convergence ICs.
The repair for this may go for a couple Hundred or more..
Best of luck
Nour Sabre
WWW.AAATVSERVICE.COM
Jul 28, 2011 | JVC AV48P776 48" CRT TV
The red in the picture is shadowing the rest of the picture giving it a 3d effect
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D, wavy, or has a shadow or shadows
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
Jan 23, 2011 | Sony KP-53HS30 53" Rear Projection...
How do i fix my samsung 1080i hdtv. It has a double picture and is red and blue, and also looks like a bow tie effect
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved pictures convergence problems.The shop,will cost u like $300-$350 for parts and labors.
Nov 21, 2010 | JVC AV-48WP74 48" Rear Projection...
Shadow effect on picture. Picture is fine but there is a red shadow tint to everything (basically everything is written twice, but not in the same spot)
Tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look like.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 19, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have waveing in my tv
Hello
Picture waving can be due to many reasons. The first reason is ariel connection. Check it first for tight and not loose contacted. Second one is due to the main filter capacitor connected across the main rectified power supply DC. If the capacitor goes value reduced or opened, waves may occur. If this is the reason, picture will show blooming effect also. Check the mair rectifier bridge also. gopakumar1@hotmail.com
Oct 18, 2010 | Orion STV2763 27" TV
I have a 65 in Mitsubishi rear projection TV that started showing a blueish Ghost effect in the picture as if out of alignment with the guns or something. Is there anything I can do to check this out or...
This tv have a problems known as a convergence.This problems the tv convergence board,must have the 2 STK convergence ICS some or all it resistors be replaced to solved the convergence problems.These problems are 3D pictures,colors out alignments,colors have shadows,pictures of colors mesh it all together.The shop will cost u $300-350 for parts and labors.
Jul 01, 2010 | Mitsubishi WS-65819 TV
Sony Trinitron picture turning green hues
Nowadays CRT's do not have good quality shadow masks anymore. After heating up a little they can give a so called "blooming" effect giving a blue an yellow leaf effect large over the screen. Reason nonparallelity in deformation of the shadow mask.
Apr 11, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
JVC AV-48WP34
The convergence ICs need to be replaced. I can post a link where to get replacement ICs along with free step by step instructions so you can do the repair yourself. Its an easy ,common repair , however a shop will be around 300 to 400
Mar 28, 2008 | JVC AV-48WP30 48" Rear Projection...
Jvc television
picture on tv started waving in & out
normally this problem is due to main filter capacitor failure in tv which is located in power supply.it becomes dry after few years
you can also check for normal voltage at input to your home.
hope this will help
good luck.
Oct 12, 2007 | Televison & Video
Jvc tv picture quality
sounds like your crt tubes...meaning Red, Green and Blue are out of alignment...or possibly 1 of the crt's is burned out.
Jan 29, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
342 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
