Question about Cyberhome CH-DVD 300 DVD Player
Sound, but no picture
I was messing around with the setup options one day and selected the wrong TV type and now I have a blank screen and I can't figure out how to reset it. I followed the instructions in the manual to reset to factory settings (turn off, turn on, open tray and press stop button on player for 5 seconds) and it doesn't work... has anyone else done this? How can I fix it?
  • MSRA Oct 23, 2008
    we have the same problem. We can't get a picture anymore. I don't have a 'progressive scan' button on my DVD remote. Now what should I do??
    Problem Solver:
  • 13 Answers
There is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds.
Posted on Oct 27, 2008
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 150 Answers
If you have a progressive scan button on the remote, it might change it back. Try all the video related buttons on the remote with the DVD player on.
Posted on Oct 20, 2008
Silly me...I was messing around with the menu options for my RCA TV and I clicked on the audio only option. Now I am unable to change anything on my TV. All I get is a blank screen as if the TV is turned...
Do a reset to this TV; and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Dec 17, 2014 | Televison & Video
Hello I'm Alexis and I am having a problem with the xbmc hub custom wizard edition. My son sat on the key board while I was watching a movie and the screen zoomed out. I've tried everything well what I...
Hello Alexis, in the bottom left hand corner is a cog icon that will take you to the settings menu. From here select system and you should see display mode at the top. Change this option to full screen.
If this does not fix the problem select the option to use a windowed full screen option just below.
Hope this works for you.
Regards Geoff
Nov 13, 2014 | Televison & Video
Manual setup mode
It sounds that some firmware error has occured. You have to enter the 'service mode' setting window to see, whether there has some errors. Service mode window is entirely different to that of user adjustment window. You must have sound knowledge in electronics to enter and adjust the data values there in service mode. Entering service mode option might be very easy, but to understand the options, and data value details are very important, because, if wrong data values has been set to this window, the set might turn irreparable. In my opinion, it will be best for you to contact any experienced service technician in this matter.
If you visit this site named 'Electro-help', you can get details about how to enter the service mode option to Sanyo TVs. To get this site, check this link. But, never try to do any adjustments, if you are not sound to do this work.
Jul 03, 2012 | Televison & Video
Main setup menu froze on screen unable to remove,also TV just stays on have to unplug from outlet. Press Rest button, and home button on remote nothing happens. Do have background channel TV from cox cable...
If the model number posted here is correct (vs-70707) this is a VZ8 Chassis made around 2000 and should NOT have a reset button on the front.
Please confirm actual model number.
Note: almost all Mitsubishi sets have a hidden menu (two or more) and one allows with the Mitsubishi remote to enter for example the OPTION menu and there you will be able to do a HARD RESET on the set which sets ALL settings back to default.
Oct 20, 2011 | Mitsubishi VS-70707 70" Rear Projection...
I can't get my console to display with the hdmi cable, but it works with my ps3 and the console outputs fine on a different tv. I took it back to the store this morning and they tested it and it worked...
It sounds like a resolution problem. Make sure your XBOX is reset to default settings. Use your other TV for this.
As the console starts, press and hold Y while holding the right trigger. This will reset the video settings to default, and restart your XBOX. Connect it to you HDTV and adjust the settings according to your TV type, and the MAX resolution. (I.E. if you only have a 720p TV, then you cannot select 1080p; you will get a blank screen.)
The steps are as follows:On your console, go to My Xbox, and then select System Settings.Select Console Settings.
Select Display.
Select HDTV Settings.
Select the resolution that is supported for your HDTV.
Select Yes to confirm the change.
Note If your HDTV does not support the selected option, the screen goes blank. If the screen does not reappear within 10 seconds, the console switches back to the original setting.
Aug 19, 2011 | Microsoft Xbox 360 4GB Console with Kinect...
Screen going blank but sound is fine
check around the flyback transformer for component failure. change the flyback transformer if you don't see anything wrong .
Don't forget to vote me
Sep 15, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Gives wrong time and day
This is from the Manual. If you want the whole manual, at the end of the instructions, there ia a link to the manual.
Setting Day and Time
Day & Time sets the day and time of your display.
1) Enter the Global Setup menu, and then the Day & Time
submenu option (see "Entering the Menu" on
page 17). Image is for the base.(Here is how)
Entering the Menu
1) In standby mode, press the MENU soft key.
2) Use volume up/down to move the pointer to a desired
main menu (DirectLink Mode, Room Monitor, Handset
Setup, Base Setup, Answ. Setup, Global Setup, and
Deregister HS).
3) Press the OK soft key to select the desired main menu.
To return to the previous screen, press the BACK soft
4) Use volume up/down to select a desired submenu and
then press the OK soft key to enter.
5) In the submenu option, use volume up/down to select
an item. Press the OK soft key to confirm your
selection. For detailed instructions, see the following
sections for the desired submenu option. To return to
the previous screen, press the BACK soft key.
6) To exit the menu, press end on the handset or cid/exit on the base.
2) Press volume up/down to select the day of the week,
and then the → soft key.
3) Press volume up/down to set hour, and then press the → soft key.
4) Press volume up/down to set minute, and then press the → soft key.
5) Press volume up/down to choose A M or P M, and then press the SAVE soft key. You
will hear a confirmation tone.
Jan 08, 2009 | Uniden TRU8885-2 Cordless Phone
While having one too many beers my friend managed to use the remote to get to the 'secret' Service Technician Menu for my LG RC797T DVD recorder to make it Region free. This he did mange to do, however his...
In 480p resolution, you highlight the 16.9 aspect ratio from the TV Aspect menu option in Setup and then type 1397139 on the remote. This brings up the service screen with all options and machine information.
Optimal (best) settings are as follows.
1 : f 2 2 : 35 (this is DivX)
3 : 93 (macrovision?) 4 : f f (Vcd/Svcd)
5 : f f (region free) 6 : c0 (c0 = LG logo)(ce = Insignia)
7 : 04 8 : 15
All I can say is Keep these and and dont mess around or you can kill it....
Apr 17, 2008 | LG Televison & Video
The language is in Arabic writing.
I just went through this agony for 3 days and found this on another blog for reseting the TV. It totally worked and got me to the language set up. Go to the front panel of the panel. Manually turn the TV OFF. Via the Front Panel push the INPUT (Function) Button in & Hold. Now use the power button on the front of the TV & turn ON the TV. I then used the remote to arrow up to English.
Oct 24, 2007 | Hitachi C29-TF750S 29" TV
Cyberhome CH-DVD 300 DVD Player Logo
110 people viewed this question
Top Cyberhome Televison & Video Experts
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
