Question about HP Pavilion a305w (DM181AR) PC Desktop
HP Desktop power up problem
My HP Desktop (Pavillion) won't power up. It got to the point where it would power up for a second or two. The blue light around the switch would show and then shut down. A few days prior it had started making loud noises. I replaced the hard drive but it does the same thing. I noticed a small fan just below the power supply seems to operate the same way. If I reset power (following the new poweer supply instructions), the fan will poweer up for a second or two, I see the blue light for a second or two and then it shuts down. Per the instructions if I turn the power supply switch off (the new power supply has a on/off switch) and disconnect then reconnect the connector to the mother board, then turn the power supply switch on it runs for a second or two. Any ideas?
  • 1 more comment
  • wgmartintx Oct 19, 2008
    Thanks a lot. I am computer illiterate but I will certainly try what I understood of the suggestions. How do I check the RAM? I replaced the old 250 watt Power Supply a 350 watt (computer store technician suggestion). Could the small fan (separate from the power supply) mounted on the front of what looks like cooling fans cause this problem. I guess what I am trying to ask is if the power supply needs an operationl feedback from that fan? Again, thank you very much for your input!!
  • plenews Dec 25, 2008
    My HP Pavilion does not power up. I went to BestBuy, they concurred that it was a bad power supply. I hooked up the new Power supply I got from CensusPC on line $50.00 with shipping. Hooked it up today, still no power. I did a continuity ck on the power switch and it seems to work fine. I shorted the 2 power button switch leads at the Mother Board with it plugged in and still no action. Does anyone know where to get a schematic of the power supply or the computer?
  • Anonymous Mar 15, 2014
    I have a HP a1700n desktop pc that will shut itself off after 5 min sometimes longer. I have cleaned the inside, tried switching ram sticks and sockets, replaced power supply, installed new 1 gig hard drive, switched power cords,removed external hardware one at a time checked for loose connections and burn spots in mother board. the only thing I havn't done is pulled the CPU,and battery. Heat sing fan runsfine I even tried putting a fan pointed to inside cabinet to make sur it wasn't overheating.
    What do you think?
    Wayne
    Problem Solver:
  • 8 Answers
Bad ram probably, units do that all the time at my job. Most of the time, it is the power supply that does not have enough power to invest into all hardware that makes your pc. even if you had a 400watts power supply, the next time you are buying a power supply you should do some kind of upgrade. 600 watts or more. If you have a high end graphics card then you are indeed in need of a new power supply. also check your cpu, its fan, check if it still seated properly, if there still paste on top of it to hel cooling it down, and protect it from statics. if you added new hardware, remove them and keep checking if it is working. To do manual diags, you need to take the unit apart. I would start by removing rams first, and check ram one by one, then hdd, then disconnect other components until i find the actual part. I am sure it is your powersupply, worst case scenario is you mobo is gone.(but it powers up and shutdown after all so let us hope you don't have a dead motherboard." and remove the dust please, dusty units do not run properly. Neim Le Legionaire.
Posted on Oct 19, 2008
  • Neim Sims
    Neim Sims Oct 19, 2008
    check ram by using one of them at a time. if you only have one stick then time for some cheap shopping. i would say go to the closest geeksquad and have them check it out for you but I believe in trial and succes, in knowledge to experience so go to bestbuy or some pawn shop, or cheap store and get the kind of ram your unit takes. if is from the xp era, and it is a pavillion, it might be ddr but check and make sure. google the unit name and check the specs.
    well for the power supply issue, i did not quite get the question but I know there is a 4pin jack that need to connect to the motherboard and that way, it powers on the cpu and cpu fan.
HP Pavillion dv6700 - won't power up
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.If you move/wiggle the hp pavilion dv6700 power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, the power adapter is probably faulty and needs replacement.Hope this helps.
Feb 16, 2013 | HP Pavilion Computers & Internet
HP Pavillion zd8000 won't power up
Try attaching a normal VGA desktop monitor to it. There should be a plug either on the sides or the back of the laptop. A blue one. That way you'll be sure.
Apr 17, 2010 | HP Computers & Internet
Solution for ''hp computer a6020a wont turn on after two months packed away'' it worked fine then went away for two months and now will not turn on has power but no blue light and nothing happens all fans...
HP has been really great with my pavillion desktop and its out of warranty and they still help me with the issues and help me solve them it may take a while to get it taken care of you may have to emial back in forth to get your promblem taken care of. Here is the email support that you can try just provide the modle number and the serial number that should be located on one side of the computer or on the bottom of the tower, and Good Luck!
PAVILION_SUPPORT_EN@MAIL.SUPPORT.HP.COM
Jan 06, 2010 | HP Pavilion a6000n (882780985018) PC...
My HP media center edition m7330n desktop will not power up (won`t stay on), The power button light flashes every 2 seconds from blue to orange & no power at usb ports. Any advise on what went bad or...
Before doing anything try to get the following tested,Processor,Power supply,Memory,also remove any cards installed including modem.Look for physical damage(ie) Brown substance coming from capacitors on board all capacitors should be flat on top if they show rounding or a hump over the top the MotherBoard needs rplacing!
Aug 08, 2009 | HP Pavilion Media Center TV m7330n...
My hp pavillion will not power all the way up
What do you mean it powered on to the blue light?
Does anything show up on the screen?
Does the system usually beep when it starts? If so, does it beep now?
Jun 16, 2009 | Computers & Internet
HP Pavillion dv9700 won't power up
Try removing the battery and using only power cord to turn the laptop on. If that fails, try turning it on without power cord, just on battery.
If none of those work, then most probable cause of your problem is motherboard. Hopefuly you are either under manufacturer warranty or you have extended warranty with your vendor where you've purchased the laptop.
If your laptop turns on on power cord, but without battery, then battery is the problem. Also, if laptop turns on when it's only on battery but it doesn't when you plug ac cord in it, then the adapter is the problem.
Jun 01, 2009 | HP Pavilion dv9700t Notebook PC
My desk top hp pavillion will not turn on
Hold the power button in on the computer for 5 seconds. Wait another 5 seconds. Now hit the power button as you normally would to turn the PC on. It should boot normally.
Dec 30, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Hp 6000 notebook screen goes black..... blue control lights go on and off
if i'm reading this correctly, it sounds like it could be a motherboard/video issue. If that's the case then unfortunately you are probably going to need a new computer if it's out of warranty...
for now however, try shutting down the computer and removing all power (power cord, battery) for a few minutes, then plug it back in and try to boot.
Aug 13, 2008 | HP Pavillion ZV6000 Notebook
HP Pavilion a305w (DM181AR) PC Desktop Logo
983 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
