Question about Sony PHC-Z10 CD Shelf System
Sony PHC-Z10: CD not working and showing ERROR on the display.
The CD player is not working and the display shows ERROR. The carousel is not turning but the carousel still open and close. Any ideas how to fix this?
Thanks.
  • klear973 Jan 24, 2009
    error comes up to when i try to play cds
Disk exchange system seems to function,changing CD's, but does not recognize a CD when s disk is selected and displays the error message "no disk selected"
The only thing you can do is clean the lens of the CD player. It's possible that dust has got inside blocking it. If that doesn't work, it will need to be taken to a repair shop as the lens might be damaged or an electronic fault.
Sep 12, 2015 | Sony PHC-Z10 CD Shelf System
Carousel will not turn
Could be a broken/loose carousel belt. take the cover off and look near the back of the unit and make sure that both belts are on there respective pulleys.
Jan 02, 2013 | Sony MegaStorage CDP-CX355 300-Disc CD...
Show picture of carousel rotary for hp 2840
Carousel rotation motor error, only professionals can do this activity,, Pl submit the unit in service center,, online support not suggestible..
Nov 16, 2011 | HP LaserJet 2840 Printer
Have Sony cdp-c535 cd player. The door won't stay in. Keeps cycling in and out.
I had the same problem with our 5-CD Sony carousel player CDP-C535 (manufactured Nov 1993). I removed the top metal cover, and loaded five audio CDs into the carousel. After I closed the table, I pressed the carousel tight so that it stayed close, and hit the play button. The CD player tried to push the carousel out with quite a force. I needed to warp me fingers around the front panel to keep the carousel closed. After a few cycles of forcing the carousel to remain close, and caused two separate strong "clucks" from the gear area, the CD carousel became operational again. The diagnosis of gear problem seems right.
Nov 28, 2009 | Sony Audio Players & Recorders
My Harman Kardon FL 8550 will not play, the display shows error and the carousel seems stuck. I already cleaned the lens.
Couple possibilities.
Disc jammed inside, take cover off and inspect.
Worn belts, belts are old and worn and it can't move the carousel or open, stripped gears will also have the same effect.
Or electronic problem, not worth repairing.
Nov 27, 2009 | Harman Kardon FL8550 CD Player
Table Error--carousel will not turn
pull off changer cover, theres 9 screws .looking from the front of the changer, look to left side,thats where there are belts for drive mech. the back one is for the carosel, it might of broke or came off. had the same problem belt came off. works good as new. hope it solves your problem
Nov 27, 2009 | Sony CDP-CX400 400-Disc CD Changer
Broken carouself? Can't properly open, close, rotate, etc.
Broken gears. The current replacement 5 disc is a CD/DVD player and sells for $129.00 at Sony or any other Sony retailer. The cost to have a service center even estimate the repair would be more than 50% of the replacement cost. Hope this helps
Nov 19, 2009 | Sony CDP-C265 CD Player
One more time vinyl
What is it not doing? "Wont play" doesn't really give enough information. Is it in credit? Does the LED display show the selection you make? Does the carousel turn?
Dave.
Jun 24, 2008 | Wurlitzer Jukebox 1015 One More Time...
Cd player
M-Error is a mechanical error and could have a multitude of causes. just went through it with a TAD-5160 unit where it was a small slip gear moving a tin lever to ingage the transport sled to insert or eject the disk from and to the carusel. You may have to take the unit apart and asess the problem. Harleysp.
Mar 19, 2007 | Fisher 9925 Shelf System
Sony PHC-Z10 CD Shelf System Logo
87 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
