Monitor display prob
The picture does not appear in my monitor no display appear.
what is the solution?
    Scholar:
  • 85 Answers
Here are some basic trouble shooting tips for new monitors: The picture does not appear
Check to make sure the signal cable is firmly connected in the socket.
Check to see if the computer system's power is ON.
Check that the Brightness Control is at the appropriate position, not at the minimum.
The Screen is not synchronized
Check that the output level matches the input level of your computer.
Make sure the signal timing of the computer system is within the specification of the monitor.
The position of the screen is not in the center
Adjust the H-Size, H-Phase or V-Size, V-Center controls.
Check if the signal timing of the computer system is within the specification of the monitor.
The screen is too bright or too dark
Check if the Brightness or contrast control is at the appropriate position, not at the maximum or minimum.
Check if the specified voltage is applied
Especially, check the horizontal frequency.
The screen is shaking
Move all objects that emit a magnetic field, such as a motor or transformer, away from the monitor.
Check if the specified voltage is applied.
Posted on Oct 19, 2008
Packardbell imedia
Hi paul,
1. check signal cable from pc into monitor and try to use other signal cable also do try into other monitor if prob cant solve.
2. your imedia include with graphic card? If has a graphic card try use other good graphic card to test the display run or not. If cannot.
3. Try make some cleaning into your ram, Test your ram one by one because sometime no display appear because of broken ram.
Try check this 2 site to other solutions..
Thanks..
1. How To Test Computer Monitor That Won Display Or Is Not Working
2. Fix Your Computer Monitor When the light is yellow or amber not green (try this one)
Good Luck.
Jan 19, 2014 | AMD Computers & Internet
HP w1907 monitor has fuzzy text
Procedures of acquiring high definition pixel quality
1.power on the computer wait until the desktop of icons display after booting has been completed
2. using the arrow of the mouse or pointer to an area on the desktop without icons, right click to display a prompt list
3. locate the appearance and setting prompt on the list.
4. a click to provide the options to increase the picture quality termed pixels
5. LCD monitors could produce several thousand pixels, select a choice nearly approapiate for reasons explained
a. the highest selection of picture quality provided on the list for a monitor powered by a separate computer with extremely dense graphics like known for modern gaming could cause monitor to blank out as precaution.
b. when selecting a picture quality from the list provided on the appearance settings area after a right click on the desktop, be sure about the compartibility of the monitor and computer unit, explained
c. most modern retail provide system units with higest definition pixel capabilites for several funcitons as gaming graphic and design, connect such a unit to an old monitor would display low quality definition pictures. However, that could be fixed by adjusting the appearance setting only with caution not to select the most highest available from the list of pixels.
Dec 06, 2010 | HP w1907 LCD Monitor
My monitor display size probs
u can adjust the screen appearance by presssing the buttons on the front...do a hit and try as i am not sure which buttons do what function in ur monitor and how they are positioned...normaly it will have function/up/down/set etc..eash option will increase, decrease, move up, move down, left, right, zoom out etc
Dec 24, 2009 | LG Flatron F700B 17" CRT Monitor
My screen appears horizontally expanded
If your monitor is crt type, on its menu control, goto menu setting look for something that will adjust horizontal width. Or set the adjustment on Display setting in windows.
Apr 10, 2009 | Computers & Internet
When switched ON, my Compaq Presario Desktop PC, a very bright and sharp blue line appears on the screen of monitor for few seconds and then goes of. Further no display. CPU led are ok. bip sounds normal....
sounds like a new monitor is in order or try another one and adjust the display settings in case the monitor cant handle what you have it set at, but i suspect its a new monitor
Dec 19, 2008 | Computers & Internet
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
If it's working fine in DOS, it can only be your display drivers for your operating system. What happes when you start in SAFE MODE? When you PC starts, keep pressing the F8 key, go to Safe Mode. If it works, bring the Resolution down to 800 X 600 and load the new display card drivers. Restart, should be fine.
Apr 22, 2008 | Philips Standard 104S 14" cRT Monitor
Monitor
check the cords and make sure theyr all connected properly.
both the computer end and the monitor end
Feb 04, 2008 | Gateway FPD2275W LCD Monitor
Dual monitors in XP Pro - HP Pavilion zd7000 laptop & I-Inc CY199 monitor
in that case u need a video hub, like : display booster. we call it a vga display booster. this may increase the quality of a picture. because when we attach any display unit, the image appears in two portion. it's gain is to low. to make it more sharp, monitor itself add some colour to that picture. the vga signal is fixed from inside of the monitor with resistance, so u can't make any variations in picture. that's why u guys need that VGA booster.
Jan 14, 2008 | Computers & Internet
Computers & Internet Logo
111 people viewed this question
David Payne
David Payne
