Question about Philips 27PT5441 27" TV
Closed Caption won't turn off
My philips 27" tv has the caption continually on. I want to turn it off. Is there a way to turn it off with the four buttons on the tv?
    President:
  • 3,130 Answers
Nope your gonnas need to get a remote that operates the menu. Theres an original thats available from 1800 remotes or http://www.remotes.com for 50 bucks. Thats like 25 less then the one from phillips! Goord Luck
Posted on Jun 15, 2006
Philips 24PT6341 closed captioning won't turn off and there is no option in menu
There must be a button marked "CC" on your TVs remote control. Press it once. It will make the closed caption windwow off.
Jun 21, 2012 | Philips 27PT6441 27" TV
I can not turn the captions off on my magnovox television
It sounds as if you have the closed caption option activated on your TV. The easiest way to disable this is to search your remote for the closed caption button. It is most likely the button marked CC or Closed Caption. Good Luck
Jan 11, 2011 | Philips Magnavox 27MS343S 27" TV
Can't turn off closed captions or find option to do so please helphelp
hi,
u can remove the closed caption optoin by the following setup.
1.Press the CC button on the remote to display the current Closed Caption setting.
2.Press the CC button repeatedly to choose from the four Closed Caption options (CC
Off, CC1, CC2, CC Mute). select CC off.
3.When finished, press the STATUS /EXIT button to remove the menu from the TV
Dec 26, 2010 | Philips 32PT6441/37 32" TV
How the **** do i take off captions off my philips tv
Hello
Press CC button on the remote to display the current Closed Caption Setting.
Press the CC button Repeatedly to choose from the four Closed Caption Options [CC OFF,CC 1, CC 2, CC MUTE].
When finished press the Status/Exit button to remove the Menu from the Tv screen
From the above said four Caption options just select as your need. OK.
Nov 12, 2010 | Philips 32PT6441/37 32" TV
The following should solve your problem if you have a comcast digital cable box and possibly for others.
Hey, it's worth a shot!
Turn the TV Power on and cable box power off.
Press the MENU button on the front of the cable box.
Scroll down to the caption item on the menu and toggle it to "disabled"
Press the menu button again to close.
Hope this helps!
Aug 11, 2008 | Sanyo DS31520 31" TV
Cannot get 27" magnavox closed caption
I called the Magnavox tech support - put the TV on channel 2,
hit the cc button repeatedly and problem solved.
thanks for contacting me.
Jun 25, 2008 | Philips Magnavox 27MS343S 27" TV
Big Black box covers screen
On the remote control is a button called closed caption or CC.. Someone turned on the closed caption. Simply turn off the closed caption. That black box is called the text box. Good Luck
Apr 12, 2008 | Philips Magnavox 27MS343S 27" TV
Close caption turns on and off by itself problem
Check the cable box to make sure the captions aren't truned on in the cable box.
If not -if it really is the Magnavox caption service- then -
This is assuming you have the original remote:
1 Press MENU to show the on-screen
menu.
2 Press VOL+ or VOL- until SET is highlighted.
3 Press CH+ or CH- repeatedly to
highlight CLOSED CAPTION.
4 Press VOL+ or VOL-
to display the
CLOSED CAPTION menu.
5 Press CH+ or CH- to select the
closed caption you want (OFF, CC-1,
CC-2, or CC-MUTE).
CC-MUTE sets
the TV to show closed captions when
you press MUTE. The TV volume will be
disabled until you press MUTE again to
restore the sound.
6 Press VOL+ or VOL-
to confirm your
selection.
7 Press TV/AV/EXIT to remove the
menu.
Feb 25, 2008 | Philips Magnavox 27MS343S 27" TV
cannot turn off closed caption on 27" insignia. the option screen which illustrates the closed caption category, is not highlighted and you cannot manually choose that option from the remote control.
Dec 08, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Closed caption
Go thru menu pages one at a time until you find CC / Text...
Selections might be CC1 , CC2 , CC3 , Text 1 , etc. You may
have to try each CC for your signal source......T.
More details = more help !
Nov 07, 2007 | Philips Magnavox 27MS343S 27" TV
Philips 27PT5441 27" TV Logo
144 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
