New HDD Install Prob
I install new hard drive bt cant able to access. what can i do?
    Scholar:
  • 85 Answers
Basic Troubleshooting Tips after Installing a New Hard DriveBased on Seagate IDE hard drives.
If you have installed your drive and it does not function properly, perform the following basic checks:
Additional Troubleshooting Tips
If you have performed the preceding basic checks but the problem persists, follow these guidelines for troubleshooting specific cases:
After you install your new drive, your computer will not boot, and no error message appears on the screen.
The screen remains blank when you power up the system.
The system does not recognize the drive.
The dealer partitioned and formatted the drive for you in the store, but the drive does not respond when you install it.
The system hangs in FDISK or fails to create or save the partition record.
The system error message, "Drive not Ready," appears.
The FDISK error message, "No Fixed Disk Present," appears.
The drive does not format to full capacity.
The DOS message "Disk Boot Failure," "Non-System Disk" or "No ROM Basic - SYSTEM HALTED" appears.
The system error message, "HDD controller failure" appears.
Check your computer manual or BIOS manufacturer to determine whether your BIOS supports drives that have more than 4,092 cylinders. If your system has this limitation, use the following procedure to configure your computer:
Turn off your computer, open the case, and remove your new drive.
CAUTION: To avoid electrostatic discharge damage to your computer or hard drive, make sure you are well grounded before touching the drive, cable, connector or jumpers.
Move the jumper on the alternate-capacity jumper, as shown in Figure 6. This causes the drive to appear to your BIOS as having a 2.1-Gbyte capacity (4,092 cylinders, 16 heads, 63 sectors per track). You may need third-party partitioning software, such as Disk Manager, to achieve full capacity of the drive.
Remount your drive in the computer and replace the computer cover.
Insert a bootable system diskette into drive A and turn on the computer. It should boot from drive A and automatically detect the new drive as a 2.1 -Gbyte drive.
Insert your DiscWizard diskette into drive A and type A:XDM. Then press ENTER. This runs the Disk Manager program.
Follow the Disk Manager instructions to install the dynamic drive overlay and to partition and format your new drive to its full capacity.
After Disk Manager is done, reboot your system. You should see the Disk Manager banner and be able to access the full capacity of your new drive.
If the steps listed above do not remedy this problem, try the following:
Make sure the monitor is plugged in and turned on.
Check all cards.
Make sure the video card is seated in its slot and secured with mounting screws.
Turn off the computer and remove the drive host adapter. If the screen turns on after you reboot, the host adapter may be incompatible or defective. If so, see your dealer.
Check all cables.
Make sure the power supply is adequate for system needs.
Reboot the computer and listen to make sure the drive motor starts up. If the drive is very quiet, it may be difficult to hear its discs reach operating speed. If the drive motor does not start up, recheck all drive cables.
Verify that for each drive, a drive-type is listed in the system setup program.
Try rebooting your computer by pressing the CTRL, ALT and DELETE keys simultaneously. If the drive is recognized after you reboot the system, the computer BIOS test may be completing before the drive is ready.
One solution is to slow the processor speed during startup. If your computer has a turbo switch, set it to slow speed before turning the computer on. If there is no turbo switch, you may be able to use keyboard commands; see your computer manual for details. After the computer is up and running, return the processor to the fast speed.
Another solution is to warm-boot your computer after every power-on.
Check for I/O address conflicts. To isolate the conflict, verify that the drive and host adapter are compatible with your computer. Turn off the computer and remove all the peripheral adapter cards except for the video card and host adapter. If the computer recognizes the drive when you reboot the computer, turn off the computer. Reinstall the other peripheral cards, one at a time, until the conflict reoccurs. After you have isolated the source of the address conflict, you can resolve the conflict by changing the 1/0 address of the peripheral that appears to cause the conflict.
If Disk Manager has installed the DDO on your hard drive and you have booted directly from a diskette, the information in the boot record for the drive may not have been loaded. Make sure there is no diskette in drive A and reboot. If you want to boot from the diskette, follow the "Booting with a Diskette" instructions under "Advanced Disk Manager Options" on page 20.
Reboot the computer and make sure the drive spins up.
Check all cables.
Make sure the DOS or Windows version the dealer used to partition and format the drive is the same version you have installed in your computer. If it isn't, see your dealer.
Verify the drive-type values in the system setup program. You must install the drive using the same drive-type values your dealer used to partition the drive.
Check for 1/0 address conflicts between peripheral cards.
Check for viruses.
Check all cables.
Your setup system diskette may be corrupted. Try using a backup diskette.
Make the partitions smaller.
Change the interrupt jumper setting on the host adapter.
Some BIOS have a Track 0 protection feature that protects Track 0 from viruses. This may cause FDISK to hang the system. You must disable this feature in the system setup program before you can use FDISK. See your computer reference guide for assistance. Be sure to re-enable this important feature when FDISK is done.
Check all cable connections. Make sure pin 1 of the drive is connected to pin 1 of the hard-disc controller or host adapter.
Check for 1/0 address conflicts.
Verify the drive-type values in the system setup program. One of the following problems may have occurred:
The values may be set with an incorrect translation characteristic.
You may have entered a parameter value that exceeds the physical capacity of the drive.
You entered a translation characteristic that does not take full advantage of the drive's capacity.
The drive's physical specifications exceed the translation limits imposed by the BIOS.
CAUTION: If you change the drive-type values in the system setup program, you must partition and format the drive again. This erases data on the drive.
If you have partitioned the drive into individual logical drives, you may need to make the partitions smaller to access the full drive capacity.
If your computer supports LBA mode, you may need to enable LBA mode in the system setup program to access the full capacity of the drive. Refer to your computer's reference guide to find out how to enable LBA.
Your computer may not support drives that have more than 4,092 cylinders. Follow the instructions on page 25 for After you install your new drive, your computer will not boot, and no error message appears on the screen.
Reinstall the DOS system files using the DOS SYS utility.
Check all cables.
Use FDISK to verify that the primary partition is active.
Check for viruses.
Confirm the jumper settings on the drive.
Verify the drive-type settings in the system setup program.
If a problem persists, please search for a solution or post a question in our tech support forum in our Help Desk.
Posted on Oct 19, 2008
Want to replace 80Gb HDD with a bigger one. How? Do I have to copy everything from the original one to the new one before actually replacing it? how?
Before you change the 80 GB Hard Drive you can take the backup of your hard drive to the External Hard Drive or if you have any sata case so you put your new hard Drive in the sata case and make 2-3 partitions in the new drive and copy your data in the new hard drive except in first partition which will be primary C Drive for your laptop and will replace data when you install windows in it. after the windows is installed and your data is verified in your new hard drive you can clear your old hard Drive or use it as an External Hard Drive (as you like )
2nd thing which is more safer and reliable is that you make backup CD/DVDs for your data before proceed to formatting or even changing hard drives, it will be very useful and helpful for any unforeseen data loss
if you require more assistance regarding this feel free to reply to this post
Regards, BA
Jan 14, 2011 | Acer Aspire 9300 Notebook
Installing new hard drive and monitor says
Turn the computer off.
Disconnect all the disk-drives, both "data" and "power" cables.
Disconnect the CD/DVD drives, both "data" and "power" cables.
Disconnect the 3.5" diskette drive, both "data" and "power" cables.
Turn the computer on.
Better? Worse?
Nov 01, 2009 | MSI K8N NEO2-F NFORCE3 250 ULTRA S-939 ATX...
I cant find the hard drive when i want to install xp on my pc. and i cant play music as there is no sound cut. how can i solve this
Can the BIOS detect the hard drive?
If not then the hard drive maybe faulty and that is why the XP install cannot find the hard drive.
If this is the case then you need a new hard drive.
Oct 06, 2009 | Compaq Presario C700T Notebook
I own a HP Pavilion dv4-1433sb laptop with a 250 gig hard drive - I want to install a 500 gig drive, but do not know exactly which drive is plug compatible for install. How do I find out what to buy?
I'm not clearly understanding what your saying.
You want to install a 500gb HDD in your laptop correct?
Your looking for "sata HDD", these are laptop HDD. Usually on the box or on the HDD there is a sticker saying what type they are.
The second choice is how much gb you need, as you said 500.
Thrid choice is your "rpm", right now the two types are 5400 and 7200. This is how fast the drive works, 5400 is cheaper and 7200 is much more expensive and faster. So if your on a budget get the 5400 rpm. Like before it will say it on the box/sticker of the HDD.
Yes, your laptop can support the 7200, so its your choice on how much you are willing to spend.
Go on HP or youtube and you will find "how to" install a new HDD if you are not sure what you are doing.
Sep 13, 2009 | Computers & Internet
I need installation instructions for a new hard drive
Here is the quick guide to installing the new sata HDD.
http://www.easeus.com/resource/install-sata-hard-drive.htm
Jun 09, 2009 | Computers & Internet
System can detect Fujitsu MHY2160BH : 160GB HDD, but cant install
it seems that your computer might have a SATA hard drive which could not be detectable by windows xp, try to install vista it will detect it easily.
otherwise use dm (disk manager) for detection and partition.
Dec 17, 2008 | Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM...
My hard drive is not working!!!!
You can access your HDD from the old computer but cannot boot your HDD from that old computer. I think you down load a file with virus, maybe your computer was infected with virus coming from that crack. Means you have to re-install your computer.
Oct 20, 2008 | ASUS P5QC Motherboard - Intel P45, Socket...
Hard disk partition table error
Insert windows xp bootable disk and boot your system in CD/DVD and then reformat your HDD and install new windows operating system.
Jan 08, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Hard drive install
Is your system still power ? if the system is working properly before u connect the new HDD. Be sure that your system or motherboard support the new HHD. if yes then, newly installed HDD sharing one cable specifically on IDE cable , the second drive should be in slave and the first one is master.( verify installation summary of the Hard drive label ) if you sure about these, then maybe memory is lessened try to fixed it by removing and installing. if not solved then update me about your system.
Dec 13, 2007 | Intel Motherboard
Computers & Internet Logo
310 people viewed this question
David Payne
David Payne
