Question about DeLonghi DDE40E Dehumidifier
E3 is flashing on display panel
The dehumidifier turns on, fan runs but it doesn't dehumidfy and E3 is flashing on the display panel. I can't find a listing of error codes anywhere in the product manual or on the DeLonghi website.
  • 3 more comments
  • Anonymous Nov 30, 2007
    I have a Delonghi DDE 50e with the same problem after working very well for quite some time (Fan runs, nodehumidifying, flashing E3) Have an older Delonghi (non electronic digital display type) which works fine in the same room.
  • Anonymous Dec 12, 2007
    I have the exact same problem with the fan working but E3 flashing. I have never been happy with the DDE40E. I had an old sears unit that worked fine for 20 years without missing a beat.
    I am going to tear mine down and clean the sensors and see what happens.
  • Anonymous Apr 24, 2008
    Same problem, E3 just keeps flashing. The unit worked great for 3 years now just the fan works.
  • shfranz Jun 23, 2008
    I have the same problem with E3 flashing and the fan running;
    and I followed the recommendations, and reseat the cables from the controller to each of the two sensors. Also checked continuity of the cables to each of the sensors, and these are TOK. The resistance to the one that is connected to the coil looks like zero. Any ideas about how to test the sensors?
    SF
  • Anonymous Mar 20, 2014
    DISPLAY KEEPS SHOWING E3 DEHUMIDIFIER WILL NOT TURN ON
    New Friend:
  • 3 Answers
Calling two service centers, they both indicated that the main circuit board needed replacing. This would need shipping the unit!!, part and then labor. I figured over $120 - not reasonable. I then took the unit apart and followed the wires from the compressor to the back of the unit. This is where the moisture sensor was located - upper left. You'll see this when you take the filter off. Anyway, I cleaned the face of this part with a old toothbrush, used some compressed air to remove any dust. I then followed the wires with the black sleeve that went to what I think is a temperature sensor - also on the left. The wires go to a sensor that is pushed into a copper tube that is part of the cooling tubing. Gently pull this out, wipe it down and re-install. I then plugged the unit in, set the humidity level and it now works. I just put the unit back together and the compressor is turning on and collecting moisture! I will run it a few days and keep checking on it to make sure it doesn't go into the 'E3' Mode. By the way, the repair shops I called really didn't have a clue what the E3 code was. Dennis
Posted on Aug 26, 2006
Worked great...followed Dennis' advice and the machine works again!!! Thanks so much!
Posted on Jul 17, 2008
  • b_alton47 Aug 09, 2013
    Dennis' advice worked for me too...D you are the FN man!!
Dehumidfier runs, collects little water, the coils freeze up and water leaks out
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Jun 23, 2011 | Kenmore 53509 Dehumidifier
My dehumidfier won't shut off. I check everything out and it's good but it just won't shut off it keep running.
It may be, that you have it running in continuous mode, rather than timed mode. Also, most dehumidifiers fans will run almost continually, to keep the air moving, so the humidity sensor can pickup and increase in humidity, if there is one.
If the above doesn't seem to be the problem with your unit, turn The Master ON/OFF Switch to OFF and unplug the unit for 12-15 minutes. This will give the electronics time to reset themselves, if necessary.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 23, 2011 | Fedders A7DH45B2A Dehumidifier
The dehumidfier runs but no water is in the container
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Feb 02, 2011 | Whirlpool Dehumidifiers
Runs but does note dehumidfy
There can be many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 18, 2010 | LG LHD45EL Dehumidifier
MY DEHUMIDFIER DOES NOT PRODUCT WATER. SOMETIMES THE COMPRESS KICKS IN BUT LATER I ONLY HEAR THE FAN RUNNING. IS THE COMPRESSOR BAD? SHOULD I GET A NEW DEHUMIDIFIER?
Since this one is faulty, maybe you should go ahead and get another dehumidifier because trying to fix this one will cost you a lot of money.
Dehumidifier repairs are quite expensive. |So you get a new one straight away.
Take care.
Aug 15, 2010 | Whirlpool Dehumidifiers
My dehumidfier runs for about a min and then stops running
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit still stops running after a min, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Take care.
Aug 12, 2010 | Goldstar DH304 Dehumidifier
COMPRESSOR DOES NOT TURN ON I HERE THE FAN AND LOW TEMPLIGHT COMES ON. DELONGHI DEHUMIDFIER MODLE NUMBER DH90U
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
Feb 22, 2010 | DeLonghi DH90U Dehumidifier
Dehumidfier freezing up
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Oct 21, 2009 | Frigidaire FDL60P1 Dehumidifier
I have a Kenmore 54701 dehumidfier, less than 2 year old. the power is on, a fan seems to be running, I no longer hear a compressor turn and, and no water is collected?
The sealed system of the Kenmore 54701 dehumidifier is warranted (Parts & Labor) by Sears for five (5) years. Since the fan in your unit runs but the compressor doesn't, I suggest that you return it to Sears and request (demand) a new replacement unit under their warranty. I say "demand" because Sears will undoubtedly tell you that the problem is due to some "other" component which is not covered, and will charge you mega-bucks to repair it. Been there - - done that.
FYI, read the (very low) customer reviews of these units on Sears website and you'll see you're not alone in your experience with Sears' inferior quality units.
Above all, do NOT pay to have it repaired. That money is better spent on the purchase of a far more reliable brand of dehumidifier - - (which will most likely cost less that what you paid for the Sears unit).
Mar 09, 2009 | Kenmore 54701 Dehumidifier
DeLonghi DDE40E Dehumidifier Logo
1,506 people viewed this question
Top DeLonghi Dehumidifiers Experts
Jim Goldsmith
Jim Goldsmith
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
