Question about Kenmore 24032\24036 Top Load Washer
Gearcase How do I remove the gearcase on a new model Kenmore 90 series? Do I need to remove the agaitor?
  • 5,911 Answers
The following link gives step-by-step instructions on how to repalce the gearcase on a Kenmore top loading washing machine with a direct-drive transmission:
http://www.fixya.com/support/r699497-replacing_gearcase
To answer your question, "yes", you DO need to remove the agitator. That is explained in step 11 of the instructions. I hope you find this information helpful. If you require additional assistance, please let me know.
PS Any particular reason why you are wanting to remove the gearcase?
Posted on Oct 19, 2008
I have a 90 series washer model 20912 that will only drain when empty or nearly empty. It will spin ok, but again, only when empty.
It sounds like your floating gear in your gearcase failed or a bad clutch. Most likely its the gearcase.
Jun 06, 2011 | Kenmore Washing Machines
Seal a round shaft of transmission leaking what oil does the transmission require
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive washer.
See the following Whirl[pool parts list for their commercial washers although the consumer models use the same transmission and parts.
The part you need is probably the 3349985 Seal, Gearcase
Cover, a relatively cheap part.
I've found that basic 80-90 weight non-detergent gear oil ( available at auto parts stores) seems to work well. It's certainly less expensive than the gearcase oil from Sears.
Feb 12, 2010 | Kenmore Washing Machines
Kenmore washer agitates on spin cycle
Obviously the washer should be either just spinning or agitating. The transmission ,or in this style washer it is called the gearcase, is bad and would need to be replaced. The gearcase controls the spin and the agitate in this washer. The part number is 3360629 and retails for $172.77. To replace; Unplug washer, remove the 2 trim pieces on either side of the console, remove the 2 screws under the trim, lift the console and rotate to the back, remove the 2 retainers going from the back into the cabinet, remove the cabinet, remove the drain pump, remove the motor, remove the agitator, remove the gearcase with 3 bolts holding it on. The gearcase will now slide out of the washer. Transfer the clutch and motor mounting plate to the new gearcase and reassemble in the reverse order.
Thank you
Jan 23, 2010 | Washing Machines
Kenmore 80 series, model 110-2781690, won't spin or agitate. loud clicking from lower portion of machine. fills & drains ok. transmission failure?
hi,
Unfortunately, it sounds like a transmission/gearcase problem, mainly because you stated the motor would run, but would not agitate or spin.
With the motor removed from the gearcase, try to turn the coupler on the gearcase side one way for many turns, and see if your agitator moves back and forth, then turn the coupler on the gearcase the other way many turns to see if the tub starts to move
thank you,
vijay
Sep 29, 2009 | Kenmore Washing Machines
Kenmore series 90 washer won't go into Spin
This is probably a bad drive coupler between the motor and the gearcase assembly.
Go here for:
Kenmore Washing Machine Parts
RepairClinic.com
appliance parts, help & more
Sep 20, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Cannot remove clutch from gearcase
there is a spring clip under the washer and C clip slid screwdriver under it to remove it no clutch does not come with gearcase..clutch pt #285785
Nov 17, 2008 | Kenmore 24032\24036 Top Load Washer
Washer on the fritz
ck motor coupling probably broke or cracked not engaging gearcase
Sep 09, 2008 | Kenmore Washing Machines
80 series kenmore washer
if you need part number is 110---3360629 gearcase fo all direct drive transmission
Jul 18, 2008 | Kenmore 15864/15862 Top Load Washer
Series 90
rack, on these direct drive Kenmores, any time you have the washer spinning and agitating at the same time, it is a gearcase problem. The gearcase is covered under warranty for 5 years. Probably around 133.00 labor. Catriver..post back.
Oct 02, 2006 | Kenmore 15864/15862 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
Ron Lankford
Archaeology
Archaeology
reliableservice
