Question about Sharp Viewcam VL-Z1 Mini DV Digital Camcorder
Constant Eject Tape iluminated on screen.
I can not use my camcorder due to I have a constant "Eject Tape" is illuminated on the screen. I can not record or playback tapes I already have recorded. What could possibly be the problem. Any help would be appreciated.
  • 1,476 Answers
Are there any error codes listed? Usually when a camcorder constantly ejects the tape it is because of a fault being present, the most likely one is moisture. Leave unit in a dry environment for a day with the cassette door open then try it. If you are sure the unit does not have moisture in it you probably have a bad moisture sensor. They go bad frequently. It is the small square device usually located on the deck base near the video drum and sometimes on the base of the drum. I do not know if you are capable of replacing this unit. If not you will need to find a reputable repair facility to get an estimate. Keep in mind from the description you gave of the problem it could be about anything. This is just the most common problem for this symptom. Several websites which offer free estimates are: http://www.videotech.com or http://www.camcorderrepair.com or http://www.videoonerepair.com Good luck.
Posted on Jul 24, 2006
My tape gets ejected after loading it in the compartment and makes a clicking noise and a constant flashing of an alarm bell on screen
There is a problem with the tape running in the machine. Check how tightly wound the tape might be
Please rate my help++++Thanks for using FIXYA
Feb 07, 2010 | Sony Handycam DCR-HC30 Mini DV Digital...
My GL2 camera constantly wants me to eject tape!!  I am unable to use my camera because it forces me to eject  the tape. I've switch tapes and use new tapes and still the same  results. Only time it...
The immediate remedy may be cleaning the video heads. The head is not receiving the data from the inserted tape because it may be clogged. Use head cleaning tape for about 10 seconds but NO MORE. Try again, if not you may need to clean and adjust by trained technicians. Good luck -James. For further assistance, go to www.camerarepairjapan.com
Mar 20, 2009 | Canon GL2 Mini DV Digital Camcorder
"Please Re-Insert Tape"!!!
stop bying sony camcorders, I had same problem and its was my second sony camcorder that failed to function properly after just one year (just after waranty expierd) the first I took to shop to repare **** after two weeks it was broken again, this while I diden't even realy used it; my very first camcorder: a canon, functioned more than 6 years and if I wanted I could still repare it **** it's analog. so go Canon, even sanyo is better these days than a f#^îng sony
Oct 22, 2008 | Sony Handycam DCR-TRV265E Digital...
Can not eject tape
I had same problem, while transferring media from TRV-16 to DVD, tape would not play, then would not eject. This after transferring several tapes to DVD. I tried several things over the last couple months that did not work before finally getting it open today. It did me no good to remove several of the outer panels that were each held by two "tiny" phillips head screws each. Went to the internet, found your post, also found a post that referred me back to SONY page which follows.......
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
"NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required."
After I did this, I could hear a whirring sound when I hit eject, although nothing came out. While the whirring was going on, I pulled up and out with constant pressure and the cassette holder opened. The tape had jammed apparently as the little protective plastic tape guard was jammed partially open when I pulled the cassette out. Good Luck and don't be afraid to put a little pressure on the door if you can hear the door trying to open.
Now I turn to recovering the tape, but having grown up with cassette decks, don't believe it will be a problem.
Oct 14, 2008 | Sony Handycam CCD-TR416 Camcorder
Sony DCR-TRV320
Try this (seems to be a standard thing from Sony):
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If an error message appears, service may be required. If the error ,message starts with an "E" it needs to be sent in.
Go to any large photo shop and get an estimate.
Aug 23, 2007 | Sony Handycam DCR-TRV320 Digital Camcorder
Flashing Power Light
The internal battery is worn out
Aug 05, 2007 | Panasonic NV-DS29B Mini DV Digital...
Tape ejects every 60 to 90 seconds regardless of the mode the camera is in
The flip up cover over the cassette housing has the "eject" button built into it. Sony has had problems with the flexible harness that connects this door to the camera body. The harness rubs against the metal frame of the camera and causes various malfunctions such as the constant eject symptom you are having. Sony service in Laredo, TX can repair this for you, it is no big deal. Good luck, this is a nice camera! Joe Weibel customelectronics.org
Feb 11, 2007 | Sony Handycam CCD-TRV87 Camcorder
Sharp Viewcam VL-Z1 Mini DV Digital Camcorder Logo
94 people viewed this question
Top Sharp Video Cameras Experts
Marvin
Marvin
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
