Question about HP Compaq Presario V2000 Notebook
Won't boot Hello Joe, I have a Presario v2000 with xp home. I resently reinstalled xp due to a system failure. When turned on, it beeps 2 times and then displays on a black screen, Press to resume, to setup. Nothing happens when either is pressed.
  • 3 more comments
  • d_ephraim01 Oct 19, 2008
    I don't know what the original system failure was. My son was using the v2000 computer. He told me it was no longer working. If my memory serves me, I could not get it to boot past the initial blue screen. I've tried F10 on the v2000 with no success. By the way, thank you so much. I'm responding on the Presario R3000 that you helped me with.
    The v2000, when turned on now, beeps twice and the screen turns black with Press to resume, to setup displayed.
  • d_ephraim01 Oct 24, 2008
    Thank you Joe,
    I'm not having the same level of success with the v2000. I've switched the memory but no change. It won't boot from the cd drive either. I appreciate your help.
  • blm000182 Dec 17, 2008
    i have been having the same problem but i wasent downloading anything i shut it down and the next time i turned it on i got two beeps and the screen f1 to resume f10 to set up but neither one worked i dont know what to do.
  • tiyana4_quee Jan 01, 2009
    I was uploading photos from a memory stick via USB port when my V2000 froze. I manually shut the system down and attempted to reboot the system. When it rebooted, a black screen with 2 lines of text appears: Press F1 to enter setup or F2 to change boot order. I tried pressing the appropriate keys without success. Thinking it was the keyboard, I replaced it with a brand new keyboard - still no success.
    Following the instructions to disassemble the unit, I attempted to remove and reseat the CMOS battery and the housing broke off and needs to be resoldered. Any helpful hints anyone can offer to fix both of my situations. I really like the laptop and have over $800 invested. I would like to see if it is repairable. Thanks in advance for your help.
  • JDTec
    JDTec May 11, 2010
    According to HP, a device did not install correctly. They sugguest going to device manager. But since you can not get past the F1 and F2 condition, I would recommend that you go through the re-installation again.
    This may be what was causing your system failure before you re-installed.
    What was the system failure before you re-installed XP?
I am unable to install operating system( WINDOWS XP)
Posted on Oct 30, 2008
Hello Joe,
I'm back where I've started. Need to ask a few questions. You recommended to rebuild the unit. How long does most laptops last? Where do I find the right parts and know how?
Posted on Oct 28, 2008
  • HP Master
  • 4,338 Answers
Glad to help.. Let me research this a little further.
Posted on Oct 20, 2008
  • JDTec
    JDTec Oct 22, 2008
    This is what I have found:
    2 Short Beeps
    Your computer has memory problems. First check video. If video is working, you'll see an error message. If not, you have a parity error in your first 64K of memory. First check your SIMM's. Reseat them and reboot. If this doesn't do it, the memory chips may be bad. You can try switching the first and second banks memory chips. First banks are the memory banks that your CPU finds its first 64K of base memory in. You'll need to consult your manual to see which bank is first. If all your memory tests good, you probably need to buy another motherboard
    You need to test the memory, Here is a link to the Ultimate Boot Disc. It has many programs used to test Memory, Hard drives etc.:
    You will need to create the cd, instructions are on the website.
    You may have to copy and paste the link into your browser.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
  • JDTec
    JDTec Oct 24, 2008
    You said in your comments, that there was a Blue Screen, This happens when memory fails, when a hardware component fails.
    Usually when you have a Blue Screen, you can get around it by going into Safe Mode or re-installing XP.
    Since the XP install failed, you are looking at a hardware failure, again 2 beeps points to memory. Did you try to create the Ultimate Book Disk. That will be the only way to diagnose this problem, by running the test on the memory and the hard drive.
What is wrong when my compaq v2000 beeps 2 times loud when I turn it on but no boot
Beep codes are unique to each brand of computer:
Compaq v2000
1 short with 1 long beep = bad bios. Must reload bios from disc.
2 short beeps = general bios failure
for more - do a google search for "v2000 Beep Codes" and go to the link for "bioscentral" - all are listed.
Jul 02, 2014 | HP Compaq Presario V2000 Notebook
My pc says"boot failure,insert boot diskette in A"
If XP was not installed on the HD from your computer then the computer won't boot from it. Reinstall it.
The system may not see your HD. As you boot, go to the boot menu and see if the HD is listed. - If it's not, see if the HD is well connected to the motherboard. - If it is then re install XP.
Sep 16, 2011 | Microsoft Windows XP Home Edition
Same problem
hi, there could be a hardware conflict, can you please reset your bios settings to defaults?
1. reboot your laptop
2. press "F2" - you should see a BIOS menu
3. Look for a keyword "reset to defaults"
4. Save and exit.
Aug 09, 2009 | HP Compaq Presario V2000 Notebook
Can't boot up to CD
You need to go into bios by pressing F2 or delete at boot up. Once you are in setup you need to change the boot sequence to the cd drive as number 1 and the hard drive as number 2 then press F10 to save and exit. then reboot the computer and it will boot off the cd.
Hope this helps.
May 04, 2009 | HP Compaq Presario V2000 Notebook
Hp Presario v2000 is died
you can buy a os dvd from a shop like **** smith
Dec 22, 2008 | HP Compaq Presario V2000 Notebook
Is it a restart with a blue screen? Is it XP?
If it is XP do the following:
Boot the laptop with a Win XP cd.
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your applications, it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
Thanks, Joe
Oct 16, 2008 | HP Compaq Presario V2000 Notebook
Presario V2000 will not boot
When your computer starts press f10 to enter the bios ,there you will find the option to reset its setting to default.....
Was this solution helpful .Show your appreciation by rating it.
May 30, 2008 | HP Compaq Presario V2000 Notebook
Reinstalling Windows on Presario V2000
Well, you can install XP as long as you have a CD and your laptop has a COA with a key. Hit delete, F2 or F10 to start the system in setup, change the order of boot devices to make the CD your primary boot device. Restart, boot into the CD and follow the prompts. After you complete your installation you can go to SUPPORT and DOWNLOADS and find whatever drivers you are missing. Take your time and you'll do fine.
Sep 08, 2007 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 fails to boot up
3 beeps is the Beep code for "Base 64KB RAM Failure". Lets hope that you are lucky and the problem is your memory. If you have two memory sticks in the computer, then try to take one of them out. Try different combinations such as swapping between the memory slots that are available. If you still getting the same error code, then your motherboard is shot.
Aug 16, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
166 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
