Question about Emerson EWF2703 27" TV
Remote broken cant get tv to play a dvd
No universal remote will work and I can t get component on the menu selection to play a DVD
  • 10 more comments
  • reeze Oct 20, 2008
    Do not have original remote, there is no universal remote that will work, can not manually change channel on TV to add a component, like tv/vcr input ot Aux..etc I looked up the Funai Corp and it confirms that this TV needs the original remote. I have tried to hook it up thru the satellite box but still wont play a component.
  • reeze Oct 21, 2008
    No a/v button on the TV. There are (3) jacks, yellow for video, white and red for audio. this is to add the DVD player but thats all, plug (3) to TV and other end (3) to DVD
    The TV used to work with a Philips universal remote but it stopped working also. I will try the RCA remote but I might as well just buy the original from newremote.com. Its a Emerson remote #NE116UD. I have already bought teo other universals.
    Thank you for your help
  • reeze Oct 22, 2008
    Where is the sensor and how do I fix it?? If the TV is hooked to the sattelite box shouldnt the sattelite remote control the TV? (which it doesn't)
    Thanks
    Sorry for the confusion. I can change channels thru the satellite box with the satelitte remote. The sattelite remote will not turn the TV on/off or allow me to add DVD player. I am pretty sure that I need to buy an original remote control so I can have that "input" button which will allow me to toggle between TV and DVD.
    thanks for all your help
  • kittycat2009 Dec 04, 2008
    Comment posted on Oct 20, 2008
  • kerrycorbett Dec 14, 2008
    I have the same problem. We ordered a new remote through Emerson, and we still can't switch to INPUT. Help!
  • Anonymous Dec 21, 2008
    ive tried the same thing. ive been through 3 remotes so far! they all work fine except for when I try to use the tv/input butons, also i cant do it manually on my tv! plz help!
  • Anonymous Jan 19, 2009
    I have a Sylvania TZ combo tv/vcr. The TV doesn't respond to my remote. The remote is new. Is it possible to fix the sensor inside the TV?
    Thanks
    Ed
  • Anonymous Jan 25, 2009
    I have the same problem with a Phillips TV.
  • jason May 11, 2010
    button
    no A/V botton on the tv?
  • 905 Answers
Have you tried this code? 030 with an RCA remote?
remote broken cant get tv to play a dvd - 3f159b2.jpg with this or any of RCA's remotes?
Posted on Oct 21, 2008
  • jason Oct 21, 2008
    if the other remote just quit working then you might have a dirty IR sensor on the tv or the remote sensor needs to be replaced on the tv
  • jason Oct 22, 2008
    the satellite remote will only control the sattelite channels , I thought you were trying to change the tv's video source and channels
    the tv remote sensor will be on the front of the tv , usually it has a circled tinted plastic over it , but it could be dirty from the inside of the tv.
    try the remote close up as well to determine if the IR sensor works or not
    you can also use a flashlight to look thru the plasic that is in front of the tv for the IR sensor to see if it is dirty in there
    electech
I have a sansui flat with build in DVD but don't have a remote the DVD will load but when push play it says operation not possible with disk what is this do I just need a univ.remote
First, check which input you have the TV set on. There may be an Input button on the side of the TV. (On the SLEDVD197, the button just below the DVD Eject button.) Just press Input and use the Channel Up/Down arrows to navigate the menu to change to the DVD. Press Input again to Enter the selected option.
With the TV in DVD mode, try pressing Play again. If you still have the error, check the region code for the disc. The "Operation not permitted" messages is usually that something on the disc is locked. Frequently, it's the result of using a different region code disc than the DVD player knows how to interpret. Try a different DVD.
If your TV doesn't have the Input button on the TV, you absolutely need a universal remote. However, you will want one that can match the TV/DVD button, the Input/Select button and the Menu button. Usually this requires a higher end remote; you also need a remote that was programmed at least 6 months after Sansui released the TV. If you do have the Input button on the TV, a universal remote may make using the TV easier.
I hope this helps.
Apr 13, 2015 | Sansui Televison & Video
VCR/DVD & Samsung TV: "weak or no signal"
Take the VCR remote, check VCR output settings ( scart1, scart2 , RCA) and signal format (PAL) etc
Jul 26, 2008 | Samsung TX-T3093WH TV
Tip
Acessing Menu with universal remote
We used a One4All model URC3021BOO remote. We programmed BOTH the TV function and the DVD/vcr button with code 0807.  To access the menu PRESS TV then MENU button then DVD/VCR button will allow you to change menu functions using left and right and select buttons. *TV button will access Menu screen BUT NO menu functions. * DVD/VCR button will NOT access menu screen but WILL control menu functions if menu is already displayed. May work with other sharp products, or other universal remotes? These original (RRMCG1330PESA) remotes run 38.00+ to buy new so try this FIRST!
on Oct 29, 2008 | Sharp 13VT-J100 13 in. Combo
I had DVD player hooked up to watch movies, I was trying to set a universal remote because I do not have one already. When I couldn't get the remote to work I pushed Menu on the front of the tv, chose...
Perhaps your dvd player output is set for channel 3 so you have to select that channel for the dvd player to play on your tv. Some older analog tvs have a separate input for dvd on the back or front. In that case you have to select that setting from the tv menu
Sep 17, 2013 | Televison & Video
I accidenltly gave a universal remote
Turn on the component, you want to program, press and hold the component key you need to change (VCR, DVD, TV, etc.) then press and hold the on.off button, wait until the light stays on, and release both buttons. Press the on.off button (wait 4 seconds between) until your component turns off. Then press the stop button to save the code.
Hope that helps
Mar 26, 2009 | RCA 3-Device Universal Remote with...
Lost remote were to get code for 1988 colortrack
cant get input to work to play dvd menu wont come up with universal remote
Dec 23, 2008 | RCA 27V520T 27" TV
Broken remote cant set to component
On most TV's you can select the source or input by going into the menu on the tv. It is usually under set up although all tv's vary. I hope this assists you and thanks for using Fix Ya. If you need further assistance please let me know.
Oct 09, 2008 | Emerson EWF2703 27" TV
Won't turn on or off.
got a remote for my tv. it is a universal remote , cant get the code for it. my tv is a white westinghouse. it shows 5 different codes for it. could you help me.
Aug 26, 2008 | RCA 3-Device Universal Remote with...
RCA F25645 25in TV.
I have this same TV. The DVD player is either hooked up to the video or s-video input. Go to the Menu (either through the remote or from the front of the TV) and select the Setup option. Go to the part where it asks if you want to use a DVD player. Select yes. Then select Video Input. Exit the Setup. When you hit the DVD button, it will switch to the Video input. The second step is to go into the Menu and select Channel, then go to Video Input Source. From there, select which input you are using for your DVD player, the S-Video or the standard Video (yellow composite cable).
Mar 06, 2008 | RCA F25645 25" TV
Emerson Spongbob tv broken remote...cant change input?
Then the only way to reach your tv is through coaxial antenna port. So you can buy an rf modulator ( very cheap) and connect your red yellow and white cables (rca cables from a dvd, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me.
Apr 17, 2007 | Emerson SpongeBob SquarePants TV
Emerson EWF2703 27" TV Logo
1,228 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
