Question about Gateway Solo 9300 Notebook
Trying to load win 98 but says setup was interrupted an cant load cab files. gateway 9300 solo
Solo 9300
Why is there no operating system found on my gateway solo 9300
Try to reinstall if you keep getting the same message. Hard drive failure, need a new one
Dec 17, 2013 | Gateway Solo 9300 Notebook
How do I change gateway solo 9300 to wireless.?
Best thing to do is to get a usb wireless adapter, here is an example of one that would work with your laptop:
http://www.walmart.com/ip/Netgear-WG111-Wireless-G-54Mbps-USB-2.0-Adapter/5148147?findingMethod=rr
There are many other at different prices and speeds, just know that it will plug into your laptop and you'll need to install the drivers that come with the adapter. Usually its just running a setup.exe file but read the documentation to be sure.
May 25, 2011 | Gateway Solo 5300 Notebook
How to open the case of a gateway solo 9300
Hi ,
open the case
(with screws removed). ... Disassembly the Gateway Solo 9300 ...
Jan 17, 2010 | Gateway Solo 9300 Notebook
Can not install windows 98 on my gateway solo 9300
ok first your gona wana disable that ios password cuz wat that does is it locks some stuff up tht are critical to the system and then go in to your boot seequence and selct first boot device as floppy then 2 cd 3 hard drive and screw the rest then it should work
May 24, 2009 | Gateway Solo 9300 Notebook
Gateway solo 40 gig will it work in tshiba laptop a45-s150
Yes you can, but most likely it will not work (you have to format it and install fresh copy of Windows (or Linux)).
Mar 28, 2009 | Gateway Solo 9300 Notebook
Looking for part gateway p/n 5501545
No one seems to be selling that particular part anymore, which laptop do you have? The Gateway Solo 9300? You may have to try to find an upgrade that's compatible as far as the motherboard connection is concerned.
Solo Series 9300 components are here.
Solo Series 9300VE components are here.
If you don't have a Solo 9300, you can look up your laptop model on Gateway's website; newer models can be found here and older models, also called "Legacy Notebooks," here.
Dec 22, 2008 | Gateway 8X DVD-ROM 5501545 (5501545)...
Gateway solo pro 9300 bios password is not remove
Go to your friend. Download and burn this cd http://www.9down.com/Hiren-s-BootCD-9-8-Keyboard-Patch-73110/
Boot your pc from it and use BIOS / CMOS Tools from it.This is a better way
Dec 15, 2008 | Gateway Solo 9300 Notebook
Gateway solo 9300
Sounds like the cable is not securely connected to the motherboard.
I would doubt the OS is responsible for this problem.
Nice little machine, the service manual is available for download for free. Might give a shot at refastening the cable.
If you're not that enthusiastic about taking a laptop apart, possibly an external mouse?
Put XP back on. If you have enough memory, it runs just fine.
Good luck
Nov 25, 2007 | Gateway SOLO 9300 PII 400 MHZ 128 RAM 6GB...
Gateway Solo 9300 Notebook Logo
64 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
