Question about HP PSC 2410 All-In-One InkJet Printer
Scanner lockup Pressed scan button on printer, scanner initiated but won't reset at end of scann. Scanner arm locked up far right with clicking sound. Is there a way to reset the whole thing? HELP!!!
  • 234 Answers
Remove both the ink cartridges from the All-In-One.
Unplug the power cord from the All-In-One as well as the power outlet.
Now move the carriage (carriage is the one which holds the cartridge) Too and Fro till you feel the carriage is moving smoothly.(You can apply little more pressure if it does not move easily)
Then insert the cartridges close the access door.
Plug the power cord directly to a wall outlet without surg protector.(If possible connect it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Now try printing a test page or make a copy
If it still makes a loud noise and the message comes up as scanner failure, then either the scanner or the scanner machanisum is bad, you may have to replace the unit
Good Luck
Posted on Oct 20, 2008
Scanner pro 93
reset it one more time and let the scanner boot before you do any thing else chill out for while dont be so egor
Sep 26, 2013 | Radio Communications
Scan says all channels locked out
Please try this,
If the scanner's display locks up or does not work properly after you connect a power source, you might need to reset or initialize it. If you have problems with the scanner, first try to reset it to retain the memory. Warning: Initializing the scanner will clear all channel memories and reverts it the state it was in right out of the box.To Initialize the scanner, turn off the scanner then turn it back on. Press 0 when the welcome screen appears. 'Please select factory tests. Exit if no key is pressed' will briefly appear. Then quickly press 1. 'Initialization clear all memory Enter to confirm Clear to exit' will briefly appear. Quickly press ENT to initialize. 'Initializing, Please stand by' then appears. Do not turn off the scanner while it is initializing. The display should then show M000 on the top line and Bank 0 CH 00 when finished.
Hope that helps!!
Happy Scanning
Nov 22, 2012 | Radio Shack Pro-97 Handheld Scanner
Reset scanner
Please try this:
Hope that helps.
Happy Scanning!!
Oct 24, 2012 | Radio Shack Pro-97 Handheld Scanner
Scanner problems Its stays on Auto-Scann and buttons dont work
Resetting or initializing the scanner may clear your problem.
To RESET the scanner:
- Turn the power OFF, then turn it ON again.
- Insert a pointed object (paper clip end, ballpoint pen tip, etc.) into the RESET opening on the side of the scanner, then press and release the button inside the opening.
If the above doesn't clear the problem, try the more drastic INITIALIZE procedure. NOTE: this step will erase all data that you have programmed into the scanner and restore it to original factory settings. To INITIALIZE the unit:
- Turn the scanner OFF then ON again. The scanner briefly displays the DSP boot version, then "Welcome to Digital Trunking" displays.
- Press "0". The scanner displays "System Tests Select Test Exits if no Key Press"
- Press "1". The scanner displays "Factory Unit Erase Memory ENTER if Yes CL to Exit"
- Press ENTER. The scanner displays "Initializing Clr Main Mem V-Scan is OK Please Wait"
- Do not power the scanner OFF until INITIALIZE is complete. When the process is complete the scanner will display "M0000" on the top line and "Bank 0 Ch 0" on the bottom line.
If neither of the above steps works for scanner I recommend that you take it to your nearest Radio shack and arrange certified repairs.
Need the manual for your scanner? You can download/print it here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-96/pro96.pdf
For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
Bill B
Apr 21, 2010 | Radio Shack Pro-96 Scanner
CANON MX 320 SCANNER PROBLEM
You need to control the scanner thru your PC with canon software that came with your scanner otherwise you cant scan anything..first open the printer/scanner software ,select scanner,then place your document and command "scan" on your PC..thats it..
Jan 05, 2010 | Canon PIXMA MX310 All-In-One Printer
I can't scann a document
Insert your disk and click explore instead of open. Then find the 'scan' folder and right click and open it. Look for a picture of a cd and something and try opening that. Otherwise you might want to reinstall your printer cd.
May 08, 2009 | Dell 924 All-in-One InkJet Printer
Radio Shack PRO-91 scanner keypad doesn't work
Try a master reset. You will lose all of your current programming but it resets the unit back to its original state when you purchased it. here are the directions from page 53 in your manual.
Resetting the Scanner
If the scanner's display locks up or stops operating
properly, you might need to reset the scanner.
Caution: This procedure clears all the information
you have stored in the scanner. Before you reset the
scanner, try turning it off and on to see if it begins
working properly. Reset the scanner only when you
are sure it is not working properly.
1. Turn off the scanner.
2. While holding down 2, 9, and Hold, turn on the
scanner. It takes about 3 seconds to initialize
and CLEAr appears.
elijam1
http://www.scannermaster.com/?Click=37131
Dec 25, 2008 | Uniden BC72XLT Handheld Scanner
Scanner doesn't scan or transmit document to pc
My printer does the same. And it's my third Canon printer and ever time when I try to scan a picture or etc. it just ends up saying that the printer can't communicate or that it's shut off. :(
Nov 14, 2008 | Canon PIXMA MP600 all-In-One InkJet...
The scanner doesn't want to scan?
When you first turn on the pro 95 and the dual trunking screen is still on insert (gently) a pin or straightend paper clip in the small hole just above and to the right of the external power plug. That will reset the radio. Once it is reset (wait until it finishes resetting) you may need to initialize it. Turn it off then back on, while it is still displaying the dual trunking screen press "0" and then the "1". Do not turn the radio off until the Initializing is finished.
Now re program your radio if you with to use the "SCAN" button. Other wise you should be able to use the "search" button to select the service you wish to listen to.
Hope this helps.
Nov 08, 2008 | Radio Shack Pro-95 Handheld Scanner
It's not scanning anymore!!
If your PC acknowledges your scanner and the scanner does not try to start (no sound or noise) you have a component failure. Without seeing it or knowing more details I cannot offer any more possibilities.
Sep 09, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP PSC 2410 All-In-One InkJet Printer Logo
111 people viewed this question
Ben Johnson
